Electrical gremlins, curioser and curioser - JeepForum.com
 1Likes
  • 1 Post By fishadventure
post #1 of 7 Old 07-27-2021, 04:26 PM Thread Starter
jay-h
I've noticed that gradually my dashboard volt meter was often reading 1.5-2 volts low especially when driving long distances with lights on, I checked the lighter and got similar results. However the actual voltage at the battery and in the engine compartment as a whole was healthy.
So it probably was bad connection, which may get worse as wiring heats up.
Anyhow after poking around (thinking possibly the ignition switch) I removed the large plug by the brake unit that engages the back of the fuse block.
to my surprise it was full of thick, sticky, gooey stuff. Kind of like pine sap. All over all the connections. Don't know what it can be...the outside of the connector is not at all sticky, just normal underhood dust, so I don't think it came from outside. I wound up spending about an hour or so just cleaning--mineral spirits, q-tips, wood chopsticks, scooping out the gunge. Finally cleaned with contact cleaner, applied anti-oxidizing paste, and put it back together. Much improved.
But what the hell was it? The plastic connector seemed undamaged. Was there a rubber gasket in there at one point? Doesn't really look like it. Wasn't grease, even old grease.
So, I have no clue what it was, or how it got there. Maybe ectoplasm... maybe there really is a ghost in the machine
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
post #2 of 7 Old 07-27-2021, 06:49 PM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
That gooey stuff is normal, old school corrosion preventative.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" Patagonia M/Ts, AX15, NP231+4:1+SYE+2LO, York OBA.
Web Admin for
JeeperDon is offline
post #3 of 7 Old 07-28-2021, 05:38 AM Thread Starter
jay-h
Well in that case, I replaced it with new school preventative.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
jay-h is offline
post #4 of 7 Old 07-28-2021, 06:55 AM
fishadventure
fishadventure's Avatar
Fluidfilm? That’s what I’d use. Or, to begin with, I’d not have removed the jeep’s cosmoline 🙂
The voltage wonkiness in the cab is usually the gauge trace ‘wiring’ printed on that plastic, the main 60-pin connector has an issue somewhere, or the block-to-firewall 50A braided flat cable is no longer viable. Replace the motor/firewall cable with 8 or better 6ga, and make ceremoniously clean the dipstick ground point and connectors.
That is probably something you should do anyways and it might fix it
[size=3]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
post #5 of 7 Old 07-29-2021, 12:18 PM
cobra30689
Originally Posted by fishadventure View Post
....or the block-to-firewall 50A braided flat cable is no longer viable. Replace the motor/firewall cable with 8 or better 6ga, and make ceremoniously clean the dipstick ground point and connectors.
Thank you for that, as I didn't know what the current capacity was of that braid. When I swapped in my 4.8, I attached the ground strap, the 12AWG main ground wire from the Jeep harness, and one of the GM engine harness grounds to a bolt behind the block (those who know these engines well know which one I am referring to), but not before scuffing up the bolt, block pad, and all the lugs from the harnesses. Have a 105A alternator and converted to a GM side terminal battery. Bought a 5.7 Cadillac positive cable with 1 4AWG starter lead, 1 6AWG alternator charge wire, and 1 6AWG lead to the PDC/starter relay. 4AWG negative from block to battery, with a 10AWG pigtail tied to the firewall. Might just replace that braid with something larger, but as of now the charging system doesn't even flinch. We'll see when the stereo and whatnot goes in later lol
cobra30689 is offline
post #6 of 7 Old 08-01-2021, 07:42 AM Thread Starter
jay-h
... Replace the motor/firewall cable with 8 or better 6ga, and make ceremoniously clean the dipstick ground point and connectors.
In my brain it had failed to register that on body-frame vehicles, chassis ground<>body ground. Ran a new ground cable, everything great now.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
jay-h is offline
post #7 of 7 Old 08-02-2021, 05:19 AM
fishadventure
That is awesome.
I love it when it’s simple &#x1f642;
Several years ago- still 2.5 then- I burned a recently rebuilt alternator and boiled the battery due to bad cables. Like 11pm on I-81. Limped to a parking lot near a parts store and slept in the heep. I bought a new everything including cables and battery at 7am.
Magic; all my gauges worked right after that. Other than temp and clock they never had before!
jay-h likes this.
