Electrical Gremlins - JeepForum.com
 5Likes
post #1 of 37 Old 05-15-2019, 03:32 AM Thread Starter
G3R0N1M0
Electrical Gremlins
Hi guys 👋 new here on this forum working on a 1990 YJ tearing my hair out with electrical Gremlins I'm having an intermittent no start/stalling issue. cause no spark root of cause no idea distributor have been rebuild ie cap and rotor new coil new plugs and wires when there issue happens there is no spark coming from the coil where do I go from there any help won't be great thanks so much for
G3R0N1M0 is offline
post #2 of 37 Old 05-15-2019, 05:59 AM
Siva283
Siva283's Avatar
Check your crank sensor. If its bad or no signal it will kill spark
Ask me how I know...
Siva283 is offline
post #3 of 37 Old 05-15-2019, 06:15 AM
RenixJunker
RenixJunker's Avatar
1987 XJ Cherokee
Check the Crank Position Sensor. the harness is extra long on some aftermarket replacements and it falls onto the exhaust. After it gets crunchy the intermittent problems begin.
Tires Clear the Obstacle
Suspension Clears Your Tires
Build From the Bottom Up
RenixJunker is offline
post #4 of 37 Old 05-15-2019, 11:45 AM
Que89YJ
It would be nice to know your Jeep info to give you good advice. Crank sensor or a bad coil.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #5 of 37 Old 05-15-2019, 09:00 PM Thread Starter
G3R0N1M0
Sorry your right it's a 4.2 carburetored
G3R0N1M0 is offline
post #6 of 37 Old 05-15-2019, 09:01 PM Thread Starter
G3R0N1M0
Also could a bad crank sensor cause intermittent no start/stall?
G3R0N1M0 is offline
post #7 of 37 Old 05-15-2019, 09:14 PM
timatoe
timatoe's Avatar
There's no crank sensor on the 4.2.
Bad Ignition Control Module, rid yourself of that and order a HEI distributor from CRT.
timatoe is offline
post #8 of 37 Old 05-16-2019, 06:19 AM
Que89YJ
4.2 Carb'd. Has the Jeep been modifies and the nutter bypass done? Its a common mod that bypasses the emissions controls for the carb. Is it a stock carb?
So you're losing spark. The coil (ICM) and wiring is a common issue. Before you dump money into the ICM you need to answer the first 2 questions. If you have bypassed the vacuum nightmare then the answer is to get a HEI coil setup. The difference in reliability and better spark makes a work of difference and its much simpler.
timatoe likes this.
Fault codes:
No Start:
Que89YJ is offline
post #9 of 37 Old 05-16-2019, 01:54 PM Thread Starter
G3R0N1M0
All stock no bypass part number on the hei that works?
G3R0N1M0 is offline
post #10 of 37 Old 05-16-2019, 09:45 PM
timatoe
timatoe's Avatar
http://lmgtfy.com/?q=crt+hei
https://crtperformance.com/shop?olsP...-232258-42l-i6
timatoe is offline
post #11 of 37 Old 05-17-2019, 05:46 AM
Que89YJ
You really need to fill out your profile. Its hard to tell what you have on the rig and where you're at. Are you in an emissions compliant state. Will you have to smog your Jeep? If the answer is no then The nutter bypass can be ignored and you go to the MC2100 or the Weber 38 along with a HEI coil. These 2 things will bring your Jeep engine to life and eliminate so many of the issues that plague the early Jeeps. Together they are relatively inexpensive with a total under $500.00 for both you will be doing yourself a huge favor in the long run.
If you do need to meet compliance then you do the Nutter bypass. It will allow you to go back when you need to.
Fault codes:
No Start:
Que89YJ is offline
post #12 of 37 Old 05-17-2019, 08:52 PM Thread Starter
G3R0N1M0
So thanks to all who have replied it was infact the ICM cause those issues but now I have a new issue that popped up while I was waiting for the part to come in all the gauges went out except the speedo and the clock (if I wiggle it a bit) I checked the fuse it was fine I currently have the gauges out so I can clean up the ribbon but I'm not even getting any signal to the connector any one have any ideas where to go from here?
G3R0N1M0 is offline
post #13 of 37 Old 05-17-2019, 08:59 PM Thread Starter
G3R0N1M0
I'm in California and no smog on this Jeep it is a 1990 YJ w/ 4.2 i6 mated to a 5 speed 4x4 all stock no lift also it's not mine it's a family member who does not want to put it in the shop any more due to being screwed over to many times he wasn't interested in changing to hei or changing the carb so I gotta work with what I got also I did have to pull apart the carb today due to cruddy idle gonna clean out the lower end of it (idle mix) see if that helps any gosh this turned in to a long winded post 😂😂
G3R0N1M0 is offline
post #14 of 37 Old 05-17-2019, 09:09 PM
timatoe
timatoe's Avatar
Why do you have no smog on a '90 in CA? In an exempt county?
timatoe is offline
post #15 of 37 Old 05-18-2019, 12:34 PM Thread Starter
G3R0N1M0
Private ranch
G3R0N1M0 is offline
electrical gremlins 2 greydragon JK Wrangler Technical Forum 2 02-12-2019 10:47 AM
1999 WJ with multiple electrical gremlins tazdevl35 WJ Grand Cherokee Forum 4 01-15-2019 07:51 PM
Electrical gremlins...where to start Asmodai TJ Wrangler Technical Forum 4 06-24-2018 03:39 PM
Diagnosing Electrical Gremlins? RobGADV WJ Grand Cherokee Forum 0 03-26-2018 09:21 PM
Electrical gremlins in dash!! Help!! Kinardg7 Audio, CB & Ham Radios, GPS, & Electrical 0 03-26-2018 10:51 AM
