ECM SwappAroo & What is this? - JeepForum.com
 1Likes
  • 1 Post By Boojo35
post #1 of 8 Old 08-02-2021, 06:15 PM Thread Starter
ZGYJ
Long story...
A mechanic told me my ECM in my YJ was bad so I grabbed one from Rockauto and I’m putting it in. Anything I need to watch out for while digging in here? My manual has disappeared so I’m working by feel.
Also, found this little thing hanging free... anyone know what it’s for?
Thanks!
ZGYJ is offline
post #2 of 8 Old 08-02-2021, 06:30 PM Thread Starter
ZGYJ
Also, how do you get to that second screw at the back? I searched but found nada. Or do I just undo the tiny torx to remove it? I don’t have that size, so...
ZGYJ is offline
post #3 of 8 Old 08-02-2021, 06:31 PM
Boojo35
1987 YJ Wrangler
It is the optional solar feed wire to the battery backup system of the flux capacitor.
Ok. Being a wise guy here but your pic does no justice to where exactly this is on the Jeep..
I will stick with my first answer until you get more specific. LOL.
Awesome likes this.
If you cannot fix it with a hammer then it has to be an electrical problem.
Boojo35 is offline
post #4 of 8 Old 08-02-2021, 06:37 PM Thread Starter
ZGYJ
It’s directly to the left of the ecm, beside it. I’ll draw a diagram of the entire jeep with arrows for you, would that help?
I figured since everyone here are Jeep savants and I was talking about the ECM, folks would read my mind and know what I was talking about. 🤟🏻
ZGYJ is offline
post #5 of 8 Old 08-02-2021, 07:30 PM
Jjgator
Jjgator's Avatar
What year model do you have? Torx to replace a ECM does not sound right. Should be 3 bolt that are a 5/16 socket. 2 bolts on top and 1 on the bottom.
Jjgator is offline
post #6 of 8 Old 08-02-2021, 07:54 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
1986 MJ Comanche
you won't believe me, but that connector is for the Daylight Running Lamps on the Canada export models.
91 YJ "Alice"
YJOTM Sept. 2017
05 LJ Rubicon "Ghost" SOLD
Luck Favours The Prepared
Luuca is offline
post #7 of 8 Old 08-03-2021, 10:02 AM
timatoe
timatoe's Avatar
Being the ECM is under the dash behind the glovebox on the 4.2, I'd assume your pic is looking under the dash???? That connector could be a lot of different things, can't see the wire colors etc. in the pic. If you pull the glovebox out the ECM is super easy to get to.
timatoe is offline
post #8 of 8 Old 08-03-2021, 11:30 AM
fishadventure
fishadventure's Avatar
My ‘91 parts tub had three coarse-threaded torx drive screws that threaded into plastic inserts in the firewall iirc
I can’t remember if I used those or the 5/16” from the other 91 parts heep.
What year is your heep?
Depending on whether I imagine where I’m seeing in the pic is located that could be the optional hood lamp plug-in or the horn feed or the MAP sensor plug-in
…or luuca’s right
[size=“3”]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
