Dumb Warn Hub Question - JeepForum.com
 7Likes
post #1 of 28 Old 08-18-2019, 06:48 PM Thread Starter
Louie4
Louie4's Avatar
1935 CJ2A
Putting together my D44 from a Ď79 Ford and I think the stub shafts are too long?
When I put the end snap ring on then the locking hub and tighten the bolts, I canít turn the locking mechanism. If I loosen the bolts I can. I took it apart and determine the snap ring is interfering with it causing it to bind. See pics for reference. If I take the snap ring out it works fine.
Sent from my iPhone using Tapatalk
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #2 of 28 Old 08-18-2019, 08:06 PM
shaggyjim
NARF!
shaggyjim's Avatar
Mine have two groves Louie but they are chevy outer stubs. Do yours only have the one grove?
Jim...
......YJOTM June 18......
shaggyjim is offline
post #3 of 28 Old 08-18-2019, 08:50 PM
timatoe
timatoe's Avatar
Mine only have the one groove, but I do remember seeing somewhere a difference in stub shaft lengths for the Ford D44, maybe between the HD 44 and non HD??
timatoe is offline
post #4 of 28 Old 08-18-2019, 08:51 PM Thread Starter
Louie4
Louie4's Avatar
1935 CJ2A
I have two grooves as well. It must be my Chevy outers and Ford spindle
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #5 of 28 Old 08-19-2019, 08:50 AM
TSEJEEPERS
TSEJEEPERS's Avatar
Try hitting the stub shaft with a dead blow hammer and see if it moves in any.
The snap ring should be right up against the body of the lock hub.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #6 of 28 Old 08-19-2019, 05:50 PM Thread Starter
Louie4
Louie4's Avatar
1935 CJ2A
Iíll give it a swing.
Another dumb question, what are the consequences of not installing that snap ring?
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #7 of 28 Old 08-20-2019, 06:29 AM
paulhead
if it works fix it
paulhead's Avatar
If you use a Ford spindle you should use a Ford outter and vise versa with a Chevy spindle. I think not using the snap ring may be ok but don't quote me on that.
Trying to weld has honed my grinding skills
paulhead is offline
post #8 of 28 Old 08-20-2019, 01:22 PM
hofferwood
hofferwood's Avatar
Try a c-clip (like the pic) instead of a snap ring.
If it aint broke---fix it till it is
hofferwood is offline
post #9 of 28 Old 08-20-2019, 03:53 PM Thread Starter
Louie4
Louie4's Avatar
1935 CJ2A
I tried using one like that but the hub just fits over the shaft. I might can grind the snap ring down so it can slide over but it may be too close.
Iím not sure what the repercussions are if there is no snap ring. If the hub is bolted in, it would hold everything in. Even if it fails, I would not lose the wheel bearings unless they overheat and fail themselves. I just donít see what would be impacted without that snap ring.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #10 of 28 Old 08-20-2019, 04:09 PM
StanF
I think that snap ring holds the axle shaft in place, and keeps it from walking back towards the pumpkin. And keeps the seals on the other side of the hub working properly.
I think you want that snap ring.
I'm not sure exactly what part you need to change out to get it to fit properly. If it's a Chevy hub, you may need to use a Chevy outer axle shaft.
There's definitely a combination of parts to make everything work together. What exact parts are you using now?
Reid Knuckles - Ford or Chevy?
Ford or Chevy outer axle shaft?
Ford or Chevy hub and spindle?
Are you sure that the Warn hubs you have will fit your combination of parts? There are several different types of them for various axles. I went all Ford with my Dana 44 setup.
StanF is offline
post #11 of 28 Old 08-20-2019, 04:12 PM
StrippedTorx
StrippedTorx's Avatar
HD outers Are longer. That’s a fact.
And you can safely run without that snap ring. Where is the hub going to go?
Sources: experience
paulhead and timatoe like this.
StrippedTorx is offline
post #12 of 28 Old 08-20-2019, 04:15 PM
paulhead
if it works fix it
paulhead's Avatar
He stated he has Chevy outers and Ford spindles. I googled some stuff and it seems people have gotten away without using the snap ring but I think it's a matter of how much the stub is gonna float. I'd call East coast gear or Dennys drive shafts just to be sure.
paulhead is offline
post #13 of 28 Old 08-20-2019, 07:44 PM
timatoe
timatoe's Avatar
I've pulled mine apart before and had the snap ring fall out, so it ran quite awhile without it before pulling it apart and finding it. I think you'd be ok, but if it could slide into the diff it could theoretically damage the locker, but I'd think you'd have a greater risk of damaging stock spider gears.
timatoe is offline
post #14 of 28 Old 08-20-2019, 08:22 PM
wizekrakr
Your picture might be deceiving but to me it looks like you have room between the snap ring and the inner hub components. So if the stub axle is going to float in towards the differential that space should have been eliminated when you took the soft blow to it. I have a similar set up. Chevy knuckles, small bearing chevy spindles, chevy 19 spline stubs and 78/79 ford hubs and i'm using Warn manual locks. I went out and took off a Warn manual hub and put a straight edge across the end of the wheel hub. The stub axle only sticks out past the straight edge about .020. Yours looks like it sticks out alot further. Like I said it could be the picture illusion. Thats something you can look at. Are any of your Ford parts from a full size Ford Bronco. I found out the hard way that FS Bronco Dana 44 parts will not work because of length differences.
wizekrakr is offline
post #15 of 28 Old 08-20-2019, 08:35 PM
wizekrakr
One more thing. If you are not using the outside diameter snapring that goes on the outer diameter of the wheel hub to retain the manual hub assembly The only thing that is holding your manual hub in the wheel hub is that snap ring on the stub axle. Right?
