Driveshaft issue - JeepForum.com
post #1 of 8 Old 03-24-2019, 08:11 PM Thread Starter
Perdido1
Perdido1's Avatar
Driveshaft issue
Iíve attached a picture of my driveshaft with the Jeep sitting on the ground and it looks way too short. Since this YJ is a bitsa at best Iím not too surprised...it drives and rides well, but this canít be the right shaft. Thoughts?
Thanks, Perdido
93 Wrangler YJ, 4.0, 5 speed...running, driving and the kids and grandkids are having a ball!
Perdido1 is offline
post #2 of 8 Old 03-24-2019, 08:45 PM
Awesome
Awesome's Avatar
Looks normal to me.
If you want a longer driveshaft, get a super short slip yoke eliminator.
The 4th 5-seater YJ in the world.
Awesome is offline
post #3 of 8 Old 03-25-2019, 05:49 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Looks stock to me too.
By the looks of things, you may want to check to see what the transfer case fluid level is at & top-off or change it as necessary. There's a good chance the slip yoke seal and possibly bushing is bad causing the leak & fluid being thrown on the tub & dripping. Easy enough fix though.
Here's a seal & bushing replacement write-up: https://www.jeepforum.com/forum/f37/...eak-fix-82091/
Joe Dillard is offline
post #4 of 8 Old 03-25-2019, 06:35 PM
bruinjeeper
bruinjeeper's Avatar
also worrisome colour to that oil.
where is the red?
Stop whining about the 'ride' - If your YJ ain't wrangling your soul free, then might I suggest you buy a stationwagon... at least you can fit all your bull**** in the back.
~YJOTM MAY '16~
bruinjeeper is offline
post #5 of 8 Old 03-25-2019, 08:57 PM Thread Starter
Perdido1
Perdido1's Avatar
The seal and bushing need replacing along with all the fluids. What do you mean by red?
Thanks, Perdido
Perdido1 is offline
post #6 of 8 Old 03-25-2019, 09:45 PM
timatoe
timatoe's Avatar
He means ATF is red and that's what should be in the t-case.
I agree, looks completely normal as far as a stock driveshaft looks.
timatoe is offline
post #7 of 8 Old 03-26-2019, 04:55 AM Thread Starter
Perdido1
Perdido1's Avatar
Thanks again! It looks and smells like GL5 to me and Iíll drain everything and replace it with the proper lube. Any particular brands of ATF and lube for the TC and diffs?
Perdido
Perdido1 is offline
post #8 of 8 Old 03-26-2019, 10:27 AM
timatoe
timatoe's Avatar
I don't use any particular brand, just normal gear oil for the diffs and ATF+4 for the t-case (well that's what I used when I had stock stuff) I use Redline MT90 in the AX15.
timatoe is offline
Cut rear driveshaft and install at the front Fernando ZJ Grand Cherokee Forum 5 02-04-2019 07:39 PM
92 YJ 3rd driveshaft loss TReese1097 YJ Wrangler Technical Forum 11 10-10-2018 07:14 PM
Driveshaft slip length questions fishadventure YJ Wrangler Technical Forum 1 09-04-2018 09:51 AM
Can I drive my Compass without the driveshaft? Sperron Jeep MK Compass & Patriot Forum 0 08-28-2018 10:25 AM
Odd sputtering issue (long and kinda rambling but need help) Lkfool TJ Wrangler Technical Forum 10 12-29-2017 09:50 AM
