Differential fluid change - JeepForum.com
post #1 of 17 Old 04-14-2006, 08:00 AM Thread Starter
bryris
bryris's Avatar
Gonna do a fluid change this weekend. I have some Amsoil GL-4 80w90 synthetic gear lube left over from a tranny fluid change in my Nissan. Will that same stuff work for the differentials on the Jeep?
Also, is it better to just get some liquid gasket or actually get the custom cut gaskets from the parts store?
bryris is offline
post #2 of 17 Old 04-14-2006, 08:08 AM
RoverJeep90
My dad and I are in the midst of the same project, only my bearings were shot so that delayed the project a bit. We accidentally put the pumpkin back on with "Permatex" prematurely. Let me tell you, that s.o.b. held on pretty well. So, yeah, go for the goop - skip the plastic.
1990 Red YJ 2.54 L (Rebuilt) 5 Speed with 94 rollbar | Dynomax Exhaust | Luk Clutch
2.5" Old Man Emu over 31x10.50 BFG MTs on 15x8 AR 767s | 1" Daystar Body Lift
Two Tops | Full and Half Doors | KC Daylighters | Hella 5500 | OME Steering Stabiliser
Sony CDX-GT300 | Kicker ZX500.1 | Kicker ZX350.4 | Kicker ZX200.2 | Kicker L5 Solobaric Sub | Kicker 6x9's | Apline 6.5's | Boston 4x6's
Truckstop CB Antenna | Class 3 Hitch
RoverJeep90 is offline
post #3 of 17 Old 04-14-2006, 08:44 AM
samahi72
I just changed mine and I used the Amsoil 75w90. I choose that weight because it is going to Alaska and I wanted some gear lube that will flow when the temps are below zero. I bought the pre-cut gasket, coated both sides with gasket sealer and no leaks.
samahi72 is offline
post #4 of 17 Old 04-14-2006, 08:52 AM
RockWoRM
RockWoRM's Avatar
RTV black or grey gasket sealer is what most 4x4 shops use, or buy a gasket if U so chose, but the RTV works quite well.
WoRM
'05 LJR, 6sp, RC long arm w/MC 6" coils, 5.13 D44's w/chromo shafts, MetalCloak fenders/sliders/body armor, 37x12.50 MTR's, Warn 9.5, RockHard swing out w/full spare. <><
RockWoRM is offline
post #5 of 17 Old 04-14-2006, 08:59 AM
dell2028
dell2028's Avatar
I used the goop on mine. Holds the oil just fine. The oil sounds good to me too.
95 YJ, D30/8.8 w/ 4.88s, SOA, 35x14.50x16.5 Pit Bull Mud Dawgs, 101" Wheelbase, Custom Front Bumper, Winch, Custom Rear Tow Points, Traction Bar, Aussie Locker in front, 20 Gal. Gas Tank modification, Hurculiner Tub, Custom Rear Bumper, SYE and CV shaft, BTF Cross-over Steering, RCI 2191 fuel cell, BTF Rockers, RE 1.5" SOA springs up front and XJ springs in the rear
Down the line a bit...engine swap, the list goes on.
dell2028 is offline
post #6 of 17 Old 04-14-2006, 10:12 AM
ToGtherWeBJeepi
Guest
Rvt
PLEASE!!!!!! don't buy the pre cut gaskets. If ur gonna do that u might as well fold up sum napkins and put on it as gaskets . There junk. Trust me i work at a parts store and believe u me i have saw some screwed up stuff when it comes to diff gaskets. Go buy yourself some blue RVT silicon and just clean up the surfaces really well. It will hold forever...
steve
ToGtherWeBJeepi is offline
post #7 of 17 Old 04-14-2006, 11:37 AM
RealJeep
get ultra black, no other....
1992 Wrangler Sahara, 4.0L HO, Dynomax exhaust, Kc daylighters, 4" pro comp suspension lift, 33x12.50 BFG MT's, 15x10 rockcrawlers, hurst shifter, Off-road bumpers, SYE, 2-10's, MM 8000 Winch, ARB Snorkel, MORE Boomerangs, CB
RealJeep is offline
post #8 of 17 Old 04-14-2006, 04:02 PM
Just dune it
Believe it or not I used to cut my gaskets from cereal boxes. Not anymore go for the goop. I use a little brake cleaner on the mating surfaces stick it together and good to go. Last week while wheeling I had to replace the oil pan on the trail, gooped it up and no leaks!
Just dune it is offline
post #9 of 17 Old 04-14-2006, 04:05 PM
got_4_lo
excelent instructions here:
http://www.stu-offroad.com/misc/diff-1.htm
i used Blue RTV 6B, no leaks with Mobile 1 75W-90 for the rear and castrol 75-90 for the front.
-Shayan A.K.A: Sean
Originally Posted by DesertTJ
I came home to be spit on and protested against in Boulder, Colorado. Most of the people have no clue. And that's why we do what we do. We give up our freedom so they can enjoy their freedom.
got_4_lo is offline
post #10 of 17 Old 04-15-2006, 07:11 PM Thread Starter
bryris
bryris's Avatar
I just changed the fluid in the rear differential with the afore mentioned fluid and I noticed after the fact that right on the bottle it says "Not recommended for differentials and other applications requiring GL-5". Doesn't the Jeep manual recommend GL-5?
bryris is offline
post #11 of 17 Old 04-15-2006, 08:32 PM
jeffy
jeffy's Avatar
My YJ never used a gasket from the factory. They used red RTV. I've been using Ultra Blue for a while. You get the bright blue ring around the diff. Most install kits come with regular blue. If you're not wanting that then you can always go with black or ultra black.
*** www.4BangerJP.com ***
jeffy is offline
post #12 of 17 Old 04-16-2006, 09:10 AM
iwishihad1
hey everybody
i desperately need to change my gear oil... but i had a few questions. how do you know when the differential is full, and where do yall buy these suction guns
thanks
iwishihad1 is offline
post #13 of 17 Old 04-16-2006, 10:10 AM
pyro9862
Originally Posted by iwishihad1
hey everybody
thanks
It's a differential seal, grab whatever RTV is cheapest it will hold up fine.
To fill the differential just pop out the fill plug and fill it untill oil is splling out the fill plug, then you know it's full.
You don't need a suction gun. Just put a drain pot under the rear, remove the ten bolts then smack the cover with a hammer and it will fall right off. Let the fluid drain out, if you want to go nuts reach in with a paper towel and scrape the bottom to remove any heavy particals that might now have come out with the fluid. Clean both the mounting surface of the cover and the differential, apply a thin bead of RTV, bolt it back up and fill.
pyro9862 is offline
post #14 of 17 Old 04-16-2006, 08:16 PM
Ryanpowell167
Does it need to be filled all the way or just up to the fill plug. I have a d35 in the rear with the rubber plug and i just fill it up untill it comes out that hole. It just seems like it will only be half filled. It just doesnt seem right.....
Black 1992 wrangler, 40" creepy crawlers, d60/14b 350tbi/700r4/np205, spring over on 4" springs.
2011 Ford F-150 Raptor, whipple supercharged...
Ryanpowell167 is offline
post #15 of 17 Old 04-16-2006, 08:30 PM
Tshark299
Tshark299's Avatar
1987 YJ Wrangler
It's only supposed to be filled to the bottom of that fill hole. As the gears spin fluid is splashed around inside.
- 4.0L, AX-15, NP231, 4.10s: 3.5" BDS, 31" Muds
- Donated drive train to the YJ, Parted out the rest
- Buick 225 V6: Painless Wiring Harness, Warn Overdrive & Hubs, 2" Lift, 31" Muds
Tshark299 is offline
How do you change your differential fluid? TJShadow TJ Wrangler Technical Forum 16 11-29-2009 06:58 AM
Differential Fluid Change FourbyFour TJ Wrangler Technical Forum 6 06-25-2007 01:12 PM
differential fluid change mfm22 TJ Wrangler Technical Forum 9 12-26-2006 12:19 PM
Differential Fluid Change 04TJTOM TJ Wrangler Technical Forum 3 05-16-2006 08:46 AM
Differential Fluid Change linux24 TJ Wrangler Technical Forum 15 12-06-2004 09:18 AM
