Difference between High Pinion and Low Pinion? - JeepForum.com
post #1 of 10 Old 04-09-2008, 03:25 PM Thread Starter
Brads_nky_yj
Brads_nky_yj's Avatar
I am just wondering whats the difference between high pinion and low pinion differentials? I thought I knew but I was just reading a thread and obviously I dont know. I know the High pinion is in reverse rotation, but what exactly are the differences? Thanks
93 YJ - SOLD
Brads_nky_yj is offline
post #2 of 10 Old 04-09-2008, 03:46 PM
MLJeeper
MLJeeper's Avatar
not reverse rotation, reverse cut.
The HP gears have the load being put on the "drive" side of the gears when going forward, this is significantly stronger than the coast side.
vice versa, going in reverse makes the hp 30 weaker than the lp
Your limited slip differential sucks.
Any video of the sound?
MLJeeper is offline
post #3 of 10 Old 04-09-2008, 04:46 PM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
High pinion = Just that, the pinion leaves the diff towards the top end of the diff
Low Pinion = Just that, the pinion leaves the diff towards the bottom end of the diff.
Excuse the crude drawing but you get the idea:
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #4 of 10 Old 04-09-2008, 04:56 PM Thread Starter
Brads_nky_yj
So how do you change it to a high pinion? Just rotate the diff?
93 YJ - SOLD
post #5 of 10 Old 04-09-2008, 05:04 PM
pat8942
pat8942's Avatar
Like MLJeeper said.
Taken from therangerstation.com.
"The low pinion axle is an indication of a standard cut ring gear and the high pinion axle is an indication of a reverse cut ring gear. Often mistakenly referred to as 'reverse rotation', the term 'reverse cut' is perhaps the single most misunderstood term used by off-roaders and even many in the axle business. A reverse cut housing is not just like a standard cut housing turned upside down. It is a specially designed housing for front driving axles. Contrary to popular belief, it does not turn backwards or in reverse. The term 'reverse cut' actually refers to the direction of the spiral cut in the ring gear.In a reverse cut axle, the spiral on the ring gear is opposite from a standard cut ring gear. The idea behind reverse cut is to strengthen the operation of the gear when it is used for a front axle application.The bottom line is that reverse cut gears (front axle style) and axle assemblies are inherently stronger for front axle use because of the way the gear mesh when moving the vehicle forward direction. They also provide better driveline angles because the pinion is located above the centerline of the axle."
All other things being equal, the simplest solution is the best.
Ich liebe meinen Jeep!
pat8942 is offline
post #6 of 10 Old 04-09-2008, 05:16 PM
jason m
Nothing but the facts
jason m's Avatar
no the axle will want to drive backwards and you cant put LP gears in a HP housing to try to correct direction/rotation, jason.
1993 YJ 4.0 60 Front, Rear steer 60, bolth spooled, 5.38's, 700r/241 39.5 iroks and beating it like it owes me money.
And on the 8th day, God created the 14 bolt...
The happiest people don't have the best of everything, they make the best of everything.
jason m is offline
post #7 of 10 Old 04-09-2008, 05:30 PM Thread Starter
Brads_nky_yj
Ok great info thanks guys, next question.. Where can I get a hp 30 then?
93 YJ - SOLD
post #8 of 10 Old 04-09-2008, 05:44 PM
Brokagain
Guest
Probably the same place as a hp60 if you're lucky. If you're going to spend money, move up at least to a d44.
Brokagain is offline
post #9 of 10 Old 04-09-2008, 06:06 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
If you have a stock YJ, it already has a HPD30 for the front axle stock from the factory.
Or, you can find them in any YJ front axle unless somebody swapped it out.
Joe Dillard is offline
post #10 of 10 Old 04-09-2008, 06:26 PM
schitzangiggles
King of Macastan
schitzangiggles's Avatar
You can also find them under an XJ, but you will need to cut/ weld on some new spring perches.
"Axeheads are supposed to be sharp, but you are one blunt tool."
FLynes
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline
Pinion inner bearing size difference on HP dana 30? linexrandy TJ Wrangler Technical Forum 1 01-29-2011 06:01 PM
pinion angles: is 8 degrees difference too much mikaus TJ Wrangler Technical Forum 21 09-22-2009 07:26 PM
What is the difference/benefit of a high pinion axle compared to a regular axle? bhicks TJ Wrangler Technical Forum 7 09-10-2008 04:32 PM
XJ high pinion and TJ low pinion gears are different right? quitelifted TJ Wrangler Technical Forum 3 11-06-2006 10:19 AM
Locked Dana 30s and Bad Pinion Bearings/Leaky Pinion Seals 97TJGUZZY TJ Wrangler Technical Forum 3 03-15-2006 06:46 AM
