LinkBack | Thread Tools |
Some pics I found online with some comparisons on pinion size between standard D44 and 98+ Rodeo/Passport/JK D44
-DJC
Sponsored Links | |||
Originally Posted by Headingout
View Post
2ed Gen Troopers also have this axle, 4.56 and 4.30 I believe, there is an early and late version, the later is slightly wider, look at the fire wall tag for the G80 option, if the tag has the G80 code it's a limited slip.
from here it gets rough
Big Red Jeep is getting the inside scoop on all the corporate knowledge of these Dana 44's from Japanese trucks........
I sense a run on the Junkyards.......I have passed at least half a dozen of these up before, maybe I'll go get one.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by 40dog
View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep
View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
-DJC
Originally Posted by bgredjeep
This is not a Dana 44. Troopers run a drop out rear axle. It is comparable in strength, but in no way the same able as the passports and rodeos run. If you need a 4.56 axle it's a good option but there are limited ratios available last I checked. The 4.30 axle from the later years has a stronger gear set on part with a Dana 60, but no other ratios available. The 4.56 and 4.30 axles do not interchange parts.
-DJC
I looked into these about 6 years ago, I think its a good swap, But the big draw back for me was the 6 lug pattern, I don't think the axles can be easily re-drilled to 5 on 4.5 due to the large center register. It may require custom axles and brakes to stay 4.5 bolt circle.
Custom shafts from Moser, Superior Axle, etc?? Of course that would eat somewhat into the financial benefit of yanking a Junk yard axle, but another solution.
I am reading 93 and 94 Rodeo had the D44 only if you had the V6, otherwise it's GM 10 bolt. 95+ on all have D44, coil sprung version starts with 98. Also are 4.10 or 4.30 if out of a 4WD. I suppose all this needs to be confirmed though. Amigos from 98 on all had D44 but coil springs, easy to cut off cups and weld on spring perches though.
Anyone have access to JP magazine back issues? Somewhere around Oct 2001? I understand there was an axle article in there with some Rodeo/Amigo D44 axles but I don't have a subctription.
View Post
View Post
Custom shafts from Moser, Superior Axle, etc?? Of course that would eat somewhat into the financial benefit of yanking a Junk yard axle, but another solution. I am reading 93 and 94 Rodeo had the D44 only if you had the V6, otherwise it's GM 10 bolt. 95+ on all have D44, coil sprung version starts with 98. Also are 4.10 or 4.30 if out of a 4WD. I suppose all this needs to be confirmed though. Amigos from 98 on all had D44 but coil springs, easy to cut off cups and weld on spring perches though. Anyone have access to JP magazine back issues? Somewhere around Oct 2001? I understand there was an axle article in there with some Rodeo/Amigo D44 axles but I don't have a subctription.
-DJC
I found numerous posts where Jeepers said they had theirs drilled, with mention of having to spend only $100 for it, which would indicate that they did have this done, then there were other posts where Jeepers were saying merely that it could be done, but not offering up any evidence. There were not photo articles on this, mainly just "aside commentary." I'd like to see photos. It is likely there is a forum out there of Isuzu Rodeo fanatics who may have all this information in their FAQ that could be tapped into.
View Post
View Post
View Post
-DJC
Somehow I had figured you had already checked in to those type forums, sad to come up dry. The JP article you had found, was it the one I was trying to cite? Or was it a different article perhaps?
View Post
View Post
Here is the original article http://www.fourwheeler.com/how-to/tr...dana-44-axles/
-DJC
OK here's where it gets weird. I asked the guy at work about his axles, he said the rear is out of a Mitsubishi Montero, 1991 they chose that year because it had disk brakes and the bolt pattern matched the waggy front. No idea on the width tho.
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
Feel free to cut and paste my PM to you , into this thread. I tried to, my phone wouldn't let me.
IIRC my Isuzu 44 was a coil spring axle , I cut all the brackets off, it is now in a SOA leaf sprung.
I would add, I've used the axle 3 times in Moab, twice on Prittchett canyon. This is with 36" bias IROCS at 4 psi. I've also used it at the Superlift park and Wheeling world in Arkansas, SMORR IN Missouri . And the Black Hills in South Dakota.
TSEJeepers can attest to the abuse I've given this axle.
Bill
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
Originally Posted by lucdog
Originally Posted by ghetdjc320
Were trying to get some definitive info together in the YJ section on the passport/rodeo dana 44's. Someone mentioned you swapped one into your cj. Do you have any specs on this axle? Looking for info like WMS to WMS, Locker options, Brake line fiottings, e-brake setup, tube diameter/thickness, axle shafts ect. Would realy appreciate the input. Here is a link to the post https://www.jeepforum.com/forum/f12/d...-44-a-3006465/ Thanks
On the E brake, OEM is in the hat of the rotor. I adapted the CJ E-brake lines to work. They work great.
The calipers use metric fittings for the lines. I used the OEM short hoses and used the metric hard line fittings on the stock 3/16" lines.
As far as lockers, I welded my spiders, so I didn't even check into lockers. Randy's ring pinion can give you choices.
The axle uses standard seals/bearings and races of a Dana 44. My axle came with 4.30 gears, I'm still using them. Randy's told me 4.56 was the lowest ratio that would fit. In talking with guys in the know in the CJ section, any ratio for a 44 will work.
My axle has a cast iron center section with a aluminum diff cover, and 44 cover will fit. You do not want the axle with the aluminum center section.
The lug pattern is 6 on 5.5 on all the Isuzu and Honda axles. I am using a GM 10 bolt for the front so same lug pattern.
-DJC
Previous Thread
Next Thread
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Posting Rules | |
