December 2018 YJOTM - Vote Now! - JeepForum.com
View Poll Results: Who is YOUR December 2018 YJOTM elect?
DaddyJeep87 2 7.41%
Awesome 5 18.52%
Paulhead 7 25.93%
bpounds 5 18.52%
Louie4 8 29.63%
Voters: 27. You may not vote on this poll
 18Likes
Closed Thread
post #1 of 45 Old 12-21-2018, 09:02 PM Thread Starter
bruinjeeper
bruinjeeper's Avatar
Voter Rules
1st rule of YJOTM is you do not vote for yourself.
2nd rule of YJOTM is you DO NOT VOTE FOR YOURSELF.
3rd rule of YJOTM is you do NOT solicit votes from outside JF or within JF. Investigations have been held, jeeps have been disqualified. DON'T do it!
4th rule of YJOTM is all nonsupporting members must post when you vote or it will not be counted. Paid members do not have to post when voting.
5th rule of YJOTM is all voters will remain public as to promote self moderation
Up for grabs: Bragging rights for December 2018 YJOTM and $200 gift cert. from Qtec (Thank you @Quadratec - you rock). REMINDER: All YJOTM winners are automatically entered for the chance at being voted for the illustrious title of YJOTY. Let's Git'r DONE!
Username: DaddyJeep87
1987 YJ
-Specifications and modifications
From the ground up...
35x12.50 Cooper STT's on cheap steelies
Late 70's ford radius arm Dana44
-extended radius arms and Ballistic Joints on the frame end
-4.56 gears
-Detroit True Trac
Late 70's ford 9"
-disk brake conversion
-Single Triangulated 4 link
-4.56 gears
-Detroit Locker
Custom built suspension, 5" or so higher than stock
-ADS 16" travel Nitrogen shocks all the way around
-Ballistic Fab shock hoops front and rear
-Rear lower links are 2"-1/4" wall DOM with Ballistic Joints on both ends
-Rear upper links are 1 1/2"-1/4" wall DOM with Ballistic Joints on both ends
-Wheel base stretched to 102"
Steering box moved forward 2"
Astro Pitman arm
High steer
ADS fuel cell behind the rear seat
Modified family style cage that is tied in to the rear shock hoops
Rear bumper built off of the frame with receiver hitch
Front bumper build out of 1/4" plate with integrated winch mount and Ballistic Fab D-ring mounts
Front fenders built out of 1 3/4"-.120" wall square tubing and 14 ga. plate
Trail Tubes stinger welded to front bumper and bolted to front fenders
Quadratec Q9500i winch
3/16" rocker guards bolted to the tub
'95 ish 5.7 TBI engine - stock, but cleaned up to look nice
'79 Turbo 350
'95 NP241C with ORD SYE kit
Custom built adapter from TH350 to NP241 (not complete yet)
Novak T-case shifter with XJ lever
Champion aluminum radiator
Optima red top
Custom built battery box
Home built drive shafts
Custom Krylon paint complete with old school hot rod flames. This was modeled after the Muscle Machines toy Jeeps if anyone remembers them
-Brief history of your jeep and how it came to be. (optional)
I originally bought this jeep in February of 1999. It ran like crap due to the stock carb, but that was soon replaced with a Holley 2 barrel. I put on a 4" Rough Country lift and some 31" BFG MT's and ran it like that for a lot of years. It eventually got a Howell TBI upgrade. After the frame rusted out and the tranny died it slowly got build into what it is today. I had a 5.2 rebuilt by my local VoTech school, but that didn't work out so well. I am now finishing up my GM drive train swap. Somewhere around 2001 is when It picked up the DaddyJeep name. My oldest son would hear me coming home from work and run to the door and say "DaddyJeep" so it kind of stuck.
Username: Awesome
1995 YJ
Specifications and Modifications:
4.0 I6
AX15, NP231 w/'True Neutral', Tummy Tuck True Flat Belly
TeraFlex Super Short Slip Yoke Eliminator
Tatton's Beefy Driveshafts front and rear
8.8, 4.10:1, Limited Slip, Disk Brakes, U-Bolt Flip
D30, WJ Knucles/Brakes, 1-ton Crossover Steering, CAD Delete, Aussie, 4.10:1
31x10.5x15" Duratracs (too small)
Custom front bumper, Rugged Ridge 8500lb Winch
Rear Tire Carrier Bumper, LED Reverse Light Bars
York On Board Air, Freightliner Air Horns
Bilstein 5100 Series longer-travel shocks, Custom shock extensions in the rear
Superlift 3.5" Springs, sagged to about 1.5"- maybe a bit more, Custom Shackles
1" Body Lift
Track Bar / Sway Bar Delete Mod
Ford Ranger Front Bench Seat Jeep seats 5
Custom Shifter Knobs
1976 Royce CB Radio ( no longer works )
Custom Security Storage Trunk
I've built the whole thing myself. A lot of time and effort went into building this Jeep. I don't have a dedicated build thread, but I've documented the major modifications in threads through the years. I purchased it when I was 17 at the behest of my dad, who owned a TJ Rubicon at the time. I've owned it for about 11 years now. I met my wife because of this Jeep (seriously), dated her in this Jeep, and I got married to her in this Jeep. Although it is no longer a daily driver and I live in an area where four-wheeling is scarce, I will keep it until one of my kids eventually wants it.
Pictures:
Username: Paulhead
1994 YJ
Been building this thing up for the last 3-4 years. Got it with 114K original miles 33's, 2.5" lift, winch and stock everything else. Moab seats are probably my newest mod, switched from RS's. Does a new girlfriend that I turned into a jeep head count as a mod? Tag her on then.
Build Thread
Details are as follows:
94 YJ 4.0 3spd with trans cooler, Rustys motor mounts, Optima Yellowtop, '95 booster/MC upgrade
Transfer Case NV241OR (4:1) Rubicon Rock Trac, Adams drive shafts front and rear
D30 , Yukon (Warn) hubs, Lockright, Beefy steering, Dynatrac u-bolt flip kit
Ford 8.8 w Yukon Grizzly locker, Superior Super 88 kit and Ruff Stuff spring under ubolt plates, 4.10 gearing
4 Zone springs,
35 General Grabber X3s
Smitty winch, Hi lift, homemade 5lb CO2
Armor, Barnes 2" belly drop, Rustys dif covers, CCFAB
tube fenders, rockers. Gas tank mod to add 5 gals.
Cushy Grant steering wheel and Corbeau Moab seats
Username: bpounds
1988 YJ
Original 4.2L
Howell TBI fuel injection
CRT HEI ignition
Retro-fit NEW AX-15 with external slave
Advanced Adapters SYE
True neutral TC mode shifter
Adams rear DC driveshaft
Brown Dog motor mounts
Zone 2" lift
Berzerks 1/2" boom shackles
No tracks, no sways, no problem
Dirtworx rear bumper and tire carrier
Warn M8274 Winch with remote SS relay
Mod'd battery tray with Optima Yellow
Military terminals
Custom HD battery cables
LED front fogs
LED rear backup lamp
Green LED dash cluster lights
22" light bar on custom mounts
14" Windshield Wipers mod
Late model TJ side mirrors
Custom mirror relocation
Rugged Ridge console and seats
In & out GOpro mounts
Custom Maglite Rack
Decals to cover scar tissue
Daily Driver
Cerro Gordo Ghost Town
Viking Mine
Swansea Road
Someday this will all be his.
Username: Louie4
1993 YJ Sahara
Specs:
-4.0L with 325,000 miles
-AX-15
-NP231 w/AA SYE
-Working A/C...yes this is worth listing.
-Tom Woods front and rear driveshaft
-Relatively New Black 15 x 8 Soft 8s
-35 x 12.5 BFG KM2s
-Front SOA w/stock YJ rear springs with added main
-Rear SOA w/stock YJ rear springs with added main
-Trail Master Front Shock Hoops
-Front and Rear 5100 Bilsteins
-Ruff Stuff stock length rear boom shackles
-Front Currie Tow Shackles
-Front HP D30 w/Yukon 4.10s & Lock-Right
-Rear Ford 8.8 w/4.10s & ARB Locker
-Stubby front bumper
-Modified Smittybilt rear tire carrier
-4" x 4" x 1/4" GS Rockers
-Ruff Stuff Spring plates
-Solid 8.8 diff guard
-Poison Spyder 3 DeFenders ~ Steel
-Rear TJ flares
-Softopper
-1982 Warn M8274 w/Stock Mount
-Teraflex Hi-Steer Knuckle
-HD tie rod & drag link from Ruff Stuff
-1 Daystar Body Lift
-Daystar Extended Bumpstops
-LED tail lights and reverse lights
-Exercise bike hand throttle
-Hayden power steering cooler
-New Quadratec Seats
I got my jeep when I turned 16 for $1,500, bone stock. My first vehicle and I still own it. It was in great shape and I drove it daily for around 7 years through high school and college. I did small mods throughout my college years as I could afford it. I've been able to go wheeling all over the Southeast. I drive it to every park I go to and so far I've been able to drive it back. I now live in Arizona and get to do some real wheeling. Hopefully, I get to Moab next year!
Stop whining about the 'ride' - If your YJ ain't wrangling your soul free, then might I suggest you buy a stationwagon... at least you can fit all your bull**** in the back.
~YJOTM MAY '16~
~YJOTM JULY '19~
bruinjeeper is offline
post #2 of 45 Old 12-21-2018, 09:13 PM
daddyjeep87
daddyjeep87's Avatar
1987 YJ Wrangler
I would love to get this group of Jeeps together to do some wheeling. Pretty similar bunch of Jeeps.
paulhead, shaggyjim and Awesome like this.
87 YJ, 5.7/TH350/NP241, Custom 4 link/ Radius Arms, ADS Nitrogen Shocks, 35" Cooper STT
daddyjeep87 is offline
post #3 of 45 Old 12-21-2018, 09:23 PM Thread Starter
bruinjeeper
Didn't manage to get any updated photos... and with work the way its been i didn't get around to putting in my leveling rear shackles or rear shock tower extensions.
So we ended up with 5 this month. A great group nonetheless. Short but Stout!
~YJOTM MAY '16~
~YJOTM JULY '19~
post #4 of 45 Old 12-21-2018, 09:42 PM
Awesome
Awesome's Avatar
After seeing some of these Jeeps I'm wondering if I should go to 35"s next year instead of 33"s.
Voted.
The 4th 5-seater YJ in the world.
Awesome is offline
post #5 of 45 Old 12-22-2018, 01:17 AM
paulhead
if it works fix it
paulhead's Avatar
Voted.
For me it was an inevitable step.
Trying to weld has honed my grinding skills
paulhead is offline
post #6 of 45 Old 12-22-2018, 06:45 AM Thread Starter
bruinjeeper
Voted.
You and I both.
~YJOTM MAY '16~
~YJOTM JULY '19~
post #7 of 45 Old 12-22-2018, 06:50 AM
jeep63
jeep63's Avatar
35s the new 33s!
95 YJ-Sold
YJOTM 05/15,05/18
jeep63 is offline
post #8 of 45 Old 12-22-2018, 07:28 AM
TSEJEEPERS
TSEJEEPERS's Avatar
Voted
Thanks Bruinjeeper for doing this!
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #9 of 45 Old 12-22-2018, 07:49 AM
shaggyjim
Joy can be found anywhere
shaggyjim's Avatar
Voted.
NO!
Originally Posted by bruinjeeper View Post
You and I both.
NO!
Originally Posted by jeep63 View Post
35s the new 33s!
NO! Gents 37's are the new 33's... except no substitutes!
Thats for all the great Jeep photos of YJ's from the participants in YJOTM this year*and bigger thanks to bruinjeeper for the time and effort he put into the contest!
timatoe likes this.
Jim...
"That's more fun than watching a hippie get mauled by a bear!"
......YJOTM June 18......
shaggyjim is offline
post #10 of 45 Old 12-22-2018, 08:44 AM
Awesome
Awesome's Avatar
Originally Posted by shaggyjim View Post
NO!NO!NO! Gents 37's are the new 33's... except no substitutes!
I still don't want to go SOA.
shaggyjim likes this.
Awesome is offline
post #11 of 45 Old 12-22-2018, 08:52 AM
shaggyjim
shaggyjim's Avatar
I'm not SOA and can fit 37's.
Jim...
post #12 of 45 Old 12-22-2018, 09:03 AM
Awesome
Awesome's Avatar
Oh wow, I naturally assumed you were SOA.
How much body did you chop in the rear?
Awesome is offline
post #13 of 45 Old 12-22-2018, 09:23 AM
shaggyjim
shaggyjim's Avatar
I have my flat fenders and TJ flare cut rears. I still get just a tiny bit of rub in the rear on heavy articulation but its not bad. I'm planning on a one inch body lift so I can run a flat skid like you do and at that time I can go to a 37. I wish I had gone 37's when I got my 35's but hind sight is what it is.
So now my question for the next set of tires is do I get Maxxis Creepie's or Trep's and in a 37x12.50r15 or 38x12.50r15?
Jim...
post #14 of 45 Old 12-22-2018, 09:52 AM
Awesome
Awesome's Avatar
I've gotta regear before I can think about going to tires that tall. Also gotta think about axles. I'm not ready for 37"s. Heck, I'm upsizing from 31"s!!
Bruin, before you get mad at us for hijacking, just think of all the free bumps we're giving you.
Awesome is offline
post #15 of 45 Old 12-22-2018, 07:42 PM
bgredjeep
bgredjeep's Avatar
1987 YJ Wrangler
Voted
bgredjeep is offline
Closed Thread
