Dash wiring assistance - JeepForum.com
post #1 of 6 Old 04-24-2016, 10:08 PM Thread Starter
jbolt
So I am currently trying to wire in a CJ dash into my 95 YJ. What I need help with is the sending units. I know the ohms and amps are different for the oil pressure, fuel gauge, and temperature. So, the YJ has an oil pressure sending unit like the one in my first attachment and the cj's is similar to the second. how can I wire in a CJ gauge such as the oil pressure gauge in my yj? Can I use a cj sending unit and not mess with the yj's internal computer? just looking for a little guidance. Thanks!
jbolt is offline
post #2 of 6 Old 04-24-2016, 11:29 PM
Michaelgoesrawr
Michaelgoesrawr's Avatar
Swap the sending units.
Michaelgoesrawr is offline
post #3 of 6 Old 04-25-2016, 05:23 AM Thread Starter
jbolt
And swapping the sending units won't mess with the engine or check engine code lights?
For swapping the temperature sending unit as well- will that effect the computer and check engine light either? Thanks
jbolt is offline
post #4 of 6 Old 04-25-2016, 05:48 AM
fishadventure
fishadventure's Avatar
I can't see your jeep specs with the jeepforum app, but iirc the oil pressure senders are not tied to the ecu functions, for one, and for another, I think the sending units are different looking but have the same electrical potentials; I think they swap but I don't think there's a need to? Others may have better info...
The difference is in the external canister unit the 'ground' is achieved through the threads into the block with a single wire that sees the resistance value of the ground as varied by the oil pressure while the other one carries its own ground in the pigtail. The gauge responds to the ground signal variance. The signal *may* be monitored by the computer to not trigger spark until it sees oil pressure but I can't remember if this is the case or not. But if you're using the pigtail anyway and all you are doing is feeding the harness, the gauge should work fine.
The temp sensor is a different story in one aspect- the computer needs to see the temp to do its thing. But again, the gauge is merely reading the volts as varied by the temp sensor so your gauge may read fine. I think it will. I believe the gauge temp pickup comes from the t-stat sensor and the computer looks at a sensor at the rear of the block, or vice versa, I can't remember specifically. You won't hurt anything by wiring the gauges up and starting it. If they read like they always did, carry on. That's what I would do.
Now that I've written all that from random memory, I think there are a couple of good threads in the 'stickies' that mention these issues with gauges. The threads are titled, "CJ Dash Swap" or the like. I'd recommend spending the 20 minutes it would take to scan through those threads. There may be a speedo issue to attend to as well depending on what year/tranny/tcase you have.
[size=3]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
post #5 of 6 Old 04-25-2016, 09:34 AM
Michaelgoesrawr
As far as I know the oil pressure has nothing to do with the computer but I do not know for sure
post #6 of 6 Old 04-25-2016, 10:20 AM
timatoe
timatoe's Avatar
Here's a CJ circuit.... http://home.sprynet.com/~dale02/gageoil.htm
I don't know what the '95 ECU looks at but it can't really look for oil pressure pre-ignition as there wouldn't be any, so unless there's a fail safe in there that kills it with no pressure after it's running I don't think there's anything to be concerned with.
timatoe is offline
cj , dash , sending unit , YJ
