Dana 44 front axle configuration questions - JeepForum.com
 2Likes
  • 1 Post By Waternut
  • 1 Post By TSEJEEPERS
post #1 of 8 Old 06-17-2021, 06:25 PM Thread Starter
Waternut
Waternut's Avatar
I know this isn't really a YJ specific question but I also know that plenty of people on here run D44 front axles.
One of my biggest problems with the non unit bearing style of bearings is the greased bearings and keeping them clean/dry. No matter what seal I try to run, I can't ever seem to keep grease in the needle bearings (circled in blue). Subsequently, the needle bearings typically seize up in a matter of months despite being stored in a garage and driven less than 50 miles (mostly offroad though). The inner wheel bearings (circled in red) don't seem to have a very good seal either but those have significantly more grease so it takes longer for a problem to occur. Lastly, the oil seal (circled in yellow) isn't really applicable since I'm running RCV's...maybe that's the root cause but I suspect all RCV owners aren't having the same issues or there would be a lot of feedback regarding it.
What am I missing?
Waternut is offline
post #2 of 8 Old 06-17-2021, 07:12 PM
TSEJEEPERS
TSEJEEPERS's Avatar
Do the RCV have a snap ring at the end of the stub shaft?
By using the oil seal circled in yellow with the snap ring it keeps the dirt out.
I use these spindle bushings rather than the spindle bearing.
https://www.wildhorses4x4.com/produc.../bronco_Dana44
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #3 of 8 Old 06-17-2021, 07:15 PM Thread Starter
Waternut
Waternut's Avatar
I like that concept. Sounds like the seal behind that isn't even really even recommended so it must do a decent job.
TSEJEEPERS likes this.
Waternut is offline
post #4 of 8 Old 06-18-2021, 06:00 AM
grandboost98
grandboost98's Avatar
I use those style bushings on my D60 and they seem to work well
04 Grand Cherokee Overland
72 Chevy Nova-in progress
grandboost98 is offline
post #5 of 8 Old 06-18-2021, 08:19 AM Thread Starter
Waternut
Waternut's Avatar
Cool I purchased a set earlier this morning. Thanks for the help
Waternut is offline
post #6 of 8 Old 06-18-2021, 09:21 PM
timatoe
timatoe's Avatar
That's a great idea, I should pick up a set of those. How long have you been running them? Just curious on longevity.
timatoe is offline
post #7 of 8 Old 06-19-2021, 08:22 AM
TSEJEEPERS
TSEJEEPERS's Avatar
Gosh I do not know. Many years.
timatoe likes this.
post #8 of 8 Old 06-19-2021, 01:32 PM
timatoe
timatoe's Avatar
That's good to know, I was concerned it would become routine maintenance item.
timatoe is offline
