D30 housing trashed - JeepForum.com
 3Likes
  • 1 Post By Waternut
  • 1 Post By Awesome
  • 1 Post By 80cj
post #1 of 12 Old 10-05-2021, 10:51 AM Thread Starter
NotmyJK
D30 housing trashed
Last summer put in a 4.10 8.8 and 4.10 front gear with a Spartan locker. Now putting in 4.88 gears with an ARB in the rear. Rear setup went fine but front had a large chunk laynig in the bottom of the housing. Guessing the housing was broken but the bearing was fine until I installed the locker. Now with the race unsupported and the locker, the race couldn't hold up.
244282661_560915108468472_2655441743977177836_n.jpg   243461567_424958578965785_3698850516113208909_n.jpg   244074318_565474434878364_3453390473959449719_n.jpg
2000 TJ sport
2008 Dodge dually
1972 Kaiser Jeep deuce and a half
2008 JK unlimited (wifes)
2001 Boxster (wifes)
1995 Ford F350 dually flatbed (wifes)
NotmyJK is offline
post #2 of 12 Old 10-05-2021, 11:44 AM
Waternut
Waternut's Avatar
So this is the 8.8 you're concerned with or the D30? I'm confused between the pictures, description, and title. Either way, I'm pretty sure that gap in the 8.8 housing is normal and it certainly doesn't look broken given the clean edges. I suspect the chunk missing is from the bearing race that fell out when you pulled the diff assembly.
Waternut is offline
post #3 of 12 Old 10-05-2021, 04:57 PM
Awesome
Awesome's Avatar
Yeah that's clearly an 8.8 and not a D30. Your D30 is probably fine.
The race probably broke because you had too much preload on the bearings. Check it more carefully next time.
The 4th 5-seater YJ in the world.
Awesome is offline
post #4 of 12 Old 10-06-2021, 05:35 AM Thread Starter
NotmyJK
Lol, was just saying I put gears in both front and rear and found on the front housing the casting was broken where the bearing race sits against on the passenger side. Anywho picked up a replacement axle housing last night.
243720313_1740722776122464_346931464683254289_n.jpg   243252842_2978265482396129_150515757484821293_n.jpg
2000 TJ sport
2008 Dodge dually
NotmyJK is offline
post #5 of 12 Old 10-07-2021, 12:48 PM
Waternut
Waternut's Avatar
My money is on that missing notch being in the replacement axle as well as it looks too clean to be broken.
timatoe likes this.
Waternut is offline
post #6 of 12 Old 10-07-2021, 09:02 PM
bruinjeeper
Moderation in Moderation
bruinjeeper's Avatar
what ball joints are those?
~YJOTM MAY '16, JULY '19~
bruinjeeper is offline
post #7 of 12 Old 10-08-2021, 05:39 AM Thread Starter
NotmyJK
Rare parts dula loading ball joints
2000 TJ sport
2008 Dodge dually
NotmyJK is offline
post #8 of 12 Old 10-08-2021, 06:17 PM
Awesome
Awesome's Avatar
Holy wow those are expensive.
Surprised you didn't go with Eaton E-lockers front and rear with what you paid for ball joints.
bruinjeeper likes this.
Awesome is offline
post #9 of 12 Old 10-08-2021, 09:27 PM
Boojo35
1987 YJ Wrangler
If you cannot fix it with a hammer then it has to be an electrical problem.
Boojo35 is online now
post #10 of 12 Old 10-08-2021, 10:36 PM
shaggyjim
LMAO! Ive been looking at the photos for days trying to figure out what you guys were talking about on the casting and I finely got it tonight. The detent in the casting above the axle seal is the oiler for the carrier bearing. It directs oil in the bearing from splash off the ring gear and bolts. Now how the race failed is beyond me...
shaggyjim is offline
post #11 of 12 Old 10-08-2021, 10:50 PM
80cj
80cj's Avatar
1980 CJ5
You're not the only one. The OP has a way of confusing things. If his concern is the front axle, why the hell does he include pictures of, and start talking about his 8.8?
Awesome likes this.
80cj is offline
post #12 of 12 Old 10-20-2021, 08:24 AM Thread Starter
NotmyJK
Casting that is broken
2000 TJ sport
2008 Dodge dually
NotmyJK is offline
