Crazy Noise 92 YJ 4.0 AX15 - JeepForum.com
 1Likes
  • 1 Post By Jeepsr4me
post #1 of 10 Old 04-26-2019, 08:19 AM Thread Starter
specks5149
Can anyone tell me what they think this noise is in the video? Here is a link the a video I made of the noise
. It occurs over 50mph. I think it may be either the TOB or pilot bearing. There is a noise before it gets as loud and I think it is the same noise but something is making it screech. Any ideas?
specks5149 is offline
post #2 of 10 Old 04-26-2019, 11:19 AM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
1986 MJ Comanche
Throw out bearing would be making noise all the time. If I had to guess, I would think its either in the transmission or the TC Chain since it only appears under load.
91 YJ "Alice"
YJOTM Sept. 2017
05 LJ Rubicon "Ghost" SOLD
Luck Favours The Prepared
Luuca is offline
post #3 of 10 Old 04-26-2019, 02:21 PM Thread Starter
specks5149
Thanks Luuca, that is what I am guessing as well. You wouldnt happen to know what caveats there are to replacing a 92 AX15 with one out of a 95?
Thanks,
Mike
post #4 of 10 Old 04-27-2019, 01:18 AM
Dubsack Johnson
Just a heads up, Aisan still makes the AX 15 brand new. W/ all the upgrades since the 90’s. Got one shipped to my door for 1500 bucks. Have about 30k miles on it now. Not sure how much you are paying for a used one, but I couldn’t be happier w/ the brand new unit.
Dubsack Johnson is offline
post #5 of 10 Old 04-28-2019, 04:26 PM
Luuca
Luuca's Avatar
1986 MJ Comanche
Thanks,
Mike
If you already have an external slave, no difference at all. Should swap without any issues.
91 YJ "Alice"
YJOTM Sept. 2017
Luuca is offline
post #6 of 10 Old 04-28-2019, 04:54 PM
Boojo35
1987 YJ Wrangler
Differentials can make noise that is only on acceleration or on decel. Worn pinion bearings or gear back lash for instance. I agree with @luc ca that it could be in the T-case also.
Does it matter what gear it is in when it makes the noise? If it goes away in a different gear than it most likely a transmission noise.
I also agree that the release bearing would be noisy all the time or change when the clutch is engaged or disengaged.
If you cannot fix it with a hammer then it has to be an electrical problem.
Boojo35 is online now
post #7 of 10 Old 04-29-2019, 08:12 AM
Jeepsr4me
Hope you checked the fluid in the rear and trans... That soulds like dry teeth eating each other up..
Luuca likes this.
Jeepsr4me is offline
post #8 of 10 Old 04-30-2019, 01:48 PM Thread Starter
specks5149
Fluids have all been changed. And it does sound like gears without lube. Could be that the transfluid isnt getting to 4th and 5th gear but since the gear are linear I dont know exactly how that would be.
post #9 of 10 Old 04-30-2019, 01:51 PM Thread Starter
specks5149
@Luuca , are you talking about the clutch master cylinder that is in the engine compartment? I am only asking because the trans I got has a centerforce clutch and TOB. Will I be able to use those components?
post #10 of 10 Old 04-30-2019, 04:02 PM
Luuca
Luuca's Avatar
1986 MJ Comanche
The Slave Cylinder down at the ToB. An Internal sits inside the bell housing an External sits outside. Tyoe of clutch doesn't matter if you swap AX-15 for AX-15
91 YJ "Alice"
YJOTM Sept. 2017
Luuca is offline
Rebuilt 4.0 Valve train noise...... Mousejockey Engines & Drivetrain 9 12-15-2019 04:31 PM
92 YJ AX15 transmission/clutch noise Patsfan12 YJ Wrangler Technical Forum 13 03-30-2019 09:44 AM
Crazy Whine Noise Recon26 TJ Wrangler Technical Forum 5 03-13-2019 10:04 AM
4.0 engine noise piston slap, timing chain slap? jarrodblake TJ Wrangler Technical Forum 28 02-21-2019 01:07 PM
AX15 noise (whine) blkdrgn42 YJ Wrangler Technical Forum 22 09-04-2018 01:46 PM
