6Likes
post #1 of 25 Old 03-10-2019, 07:05 PM Thread Starter
[email protected]
April11@1969's Avatar
Cranks but will not start
Hello Everyone,
This is my first post, so please be gentle. I have a 1993 Jeep Wrangler 2.5 liter 5 speed manual transmission and I just completed an engine swap. However, It will not start, so here are the symptoms, and things I have done. But before I go into all of that, I can pull start it, and it fires right up, and runs beautifully!! So when trying to start normally, it just cranks over, and has no spark.
I have replaced all the plugs, wires, the coil, distributor, & CPS, I have also had the starter tested, and checked all fuses and PDC. the ECU is fairly new, and so is the fuel pump. Battery is good as well. So I am at a loss.
As I said, every time I pull start, it fires right up and runs beautifully, it idles well, and takes off as it should down the highway, but when I shut it off, just cranks over. Perhaps I missed a wire somewhere? Summer is coming and I need my baby!!
Thanks in advance.
Brian
Take the road less traveled, who knows what awaits?
post #2 of 25 Old 03-10-2019, 07:33 PM
GTS225
I'm not knowledgeable enough yet, but I wonder if there is a clutch safety switch not acting correctly?
Roger
GTS225 is offline
post #3 of 25 Old 03-10-2019, 07:46 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
SO Key On and in RUN, it will roll start and idle. This tells me that it will provide spark with the key in RUN. It is not providing spark with the key in START or the starter is not popping out enough to turn the flywheel.
Verify this by turning the key to RUN, trans in neutral, and wheels chocked, jumper the starter with jumper cables and verify it will start and idle. If that is the case, you need to double check your ignition wiring. moving the harnes out of the way for the swap may have damaged a line from the ignition to the ECM.
Chrisnvegas likes this.
91 YJ "Alice"
YJOTM Sept. 2017
05 LJ Rubicon "Ghost"
Luck Favours The Prepared
Luuca is offline
post #4 of 25 Old 03-10-2019, 09:51 PM Thread Starter
[email protected]
Hello Roger,
If I am to believe what research I have done, there is no Neutral Safety Switch...... Unless of course I am wrong..
post #5 of 25 Old 03-10-2019, 09:52 PM Thread Starter
[email protected]
Thank you for the suggestion.. I shall try that tomorrow.
post #6 of 25 Old 03-10-2019, 09:57 PM
fishadventure
fishadventure's Avatar
I can’t help here. Luuca has it covered anyway.
In my jeep on the passenger side I have a little red plastic box that was oem on a 1960s Johnson boat motor. The hinged cover is moulded with the words, “EMERGENCY STARTER ROPE”
That’s all I could think of when I read “pull start.”
Boojo35 likes this.
[size=“3”]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
post #7 of 25 Old 03-11-2019, 09:13 AM
jtec
2014 JK Wrangler
Be careful testing trans in N clutch depressed.
A test light on + terminal of ign coil..... does light come on in RUN?
I believe from your description it will be ON .
Move switch to START - engine will crank did test light come on?
I suspect ther is an ign switch issue. this will test for that.
The diagrams for this era jeep is mickey mouse and a tough read even for me.......
Boojo35 likes this.
jtec is online now
post #8 of 25 Old 03-11-2019, 09:52 AM
timatoe
timatoe's Avatar
You're on the right track.
I just thought it was odd your username shows as [email protected], never seen that in the 13 years I've been on here.
timatoe is offline
post #9 of 25 Old 03-11-2019, 11:28 AM
stephencbrinson
ME TOO! I've pull started many an outboard motor.
Maybe just run the pull cord to a hole in the drivers side. Then before you jump in just give her a yank.
I have nothing useful to add except make sure you have spark and fuel while cranking.
Sent from my SM-G930U using Tapatalk
1992 YJ, 2.5L, AX5, D30, D35, 2.5 RE lift
Daniel 3:18
Ephesians 2:1-12
stephencbrinson is offline
post #10 of 25 Old 03-11-2019, 04:44 PM
Boojo35
Roger
YJ's do not have a clutch switch. Also. OP says it cranks. This would eliminate a clutch switch as they inhibit the starter circuit.... you know.... the thing that makes it crank.
If you cannot fix it with a hammer then it has to be an electrical problem.
Boojo35 is online now
post #11 of 25 Old 03-11-2019, 04:47 PM
Boojo35
Me too. I was trying to visualize where he wrapped the rope and just how big of a dude he is to pull it off.
post #12 of 25 Old 03-11-2019, 05:20 PM
Chrisnvegas
Knowitall Wannabe!
Chrisnvegas's Avatar
Using all the same ignition and computer parts?
If so, it should run now like before. So a wire was probably damaged along the way. All the plugs are different so it isn't improperly wired.
Have a partner crank over while you check for 12 volts + at the coil while cranking.
If yes, give it a squirt of starting fluid and crank it. If no start, then the fuel pump is shutting down when the switch is turned to crank.
This should narrow it down without buying parts.
If neither does anything, we'll dig deeper.
End the Ethanol Rip-Off
Chrisnvegas is offline
post #13 of 25 Old 03-11-2019, 05:33 PM
Boojo35
Some of the worst diagrams ever. Have to skip from page to page. Write notes when doing it to pick up where things left off. Have to draw own schematics from time to time to make sense of it all. Then there are the schematics that don't necessarily account for all options available on a vehicle. Headlights with or without DRL is a great one to trace..... The pins at the headlamp switch alone. Pin 4 and pin 6 specifically... if I recall the correct numbers. The switch diagram does not clearly show crap. Just stuff out in space.... Love it!
Rant over.
post #14 of 25 Old 03-11-2019, 08:10 PM
fishadventure
Originally Posted by Chrisnvegas View Post
If yes, give it a squirt of starting fluid and crank it. If no start, then the fuel pump is shutting down when the switch is turned to crank. This should narrow it down without buying
Chris is prettybsharp. I think he meant, “If (it has spark and starts with starting fluid), then the fuel pump is shutting down when the switch is turned to crank”
post #15 of 25 Old 03-11-2019, 09:21 PM Thread Starter
[email protected]
Hello Luuca,
I have not had enough time to do what you have sugesested yet. had to fix brakes on truck, but will keep you posted.
2002 Overland Cranks strong but won't start JSMCO WJ Grand Cherokee Forum 12 10-13-2018 12:35 PM
2002 TJ Cranks no Start - my Daughters JEEP Jeepers-Creeper TJ Wrangler Technical Forum 34 09-17-2018 10:52 AM
HELP! 92 2.5L Cranks but won't start stephencbrinson YJ Wrangler Technical Forum 18 07-25-2018 10:30 AM
4.0 TJ cranks fine intermittent no start RossL TJ Wrangler Technical Forum 4 05-29-2018 02:18 PM
Cranks but won't start tcmault TJ Wrangler Technical Forum 6 01-04-2018 03:54 PM
