Cranks but nothing - Page 3 - JeepForum.com
 10Likes
post #31 of 36 Old 10-18-2020, 11:45 AM
Wabatuckian
Wabatuckian's Avatar
Originally Posted by BrkCaddy View Post
Here’s what happen. Was driving then stopped running. Cranked and nothing. Has new coil, distributor and wires. Jeep has no spark no fuel and no cel. I google drive those symptoms and read it was the capacitors in the écu so I changed them out.
I'd really check the CPS and the pickup inside the distributor, whatever they're calling it.
Josh
Wabatuckian is offline
post #32 of 36 Old 10-18-2020, 12:27 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
1986 MJ Comanche
It is possible you have several issues that are presenting at the same time.
IMO change the Crank Position Sensor and go from there. Generally, its a $75 part and could get the jeep running again.
If that doesn't fix the running part, I'd be surprised.
CEL could be blown bulb or malicious cutting of the wire by PO to hide issues from prospective buyers.
I'm not the guy to talk about electronics with. Searching for cranks but no start - no spark, netted me nothing but CPS repairs for both YJ and XJ. I like to keep it simple and try and handle one issue at a time. IMO it probably always had a no CEL issue that you only recognized once the CPS went bad.
if you can live with a running Jeep with no CEL for a bit until you truly diagnose the CEL, change the CPS and report back. It's two 10MM bolt on the driver's side upper bell housing. Be careful not to drop two 10 mm sockets into the bell housing. ask me how I know.
91 YJ "Alice"
YJOTM Sept. 2017
05 LJ Rubicon "Ghost" SOLD
Luck Favours The Prepared
Luuca is offline
post #33 of 36 Old 10-18-2020, 12:28 PM
Luuca
Luuca's Avatar
1986 MJ Comanche
Josh
Crank Position Sensor is on the bell housing.
Cam Position Sensor is inside the distributor cap.
91 YJ "Alice"
YJOTM Sept. 2017
Luuca is offline
post #34 of 36 Old 10-18-2020, 02:07 PM
RandyNight
Make sure you have power to coil. Our 93 YJ had a problem with a bad wire/connection
Sent from my iPhone using Tapatalk
RandyNight is offline
post #35 of 36 Old 10-18-2020, 04:45 PM Thread Starter
BrkCaddy
Thanks everyone ill try these and let you all know
BrkCaddy is offline
post #36 of 36 Old 10-18-2020, 04:52 PM
Wabatuckian
Correct.
I was finding several different names for the cam sensor. I wasn't sure what terminology I should be using for this year Jeep. The diagrams I'm finding call it the "sync signal generator."
Josh
