Code 41 Not Charging w/ CEL on...will this work? - JeepForum.com
post #1 of 8 Old 03-14-2019, 02:15 PM Thread Starter
ybody
Found many posts discussing the no charging situation AKA: Code 41 with Check Engine Light on.
Tried 3 different ecm's and new alternator with no luck...before I go the external regulator route was thinking of just eliminating the field connector (B&C only) then:
Cutting the ECM Pin #20 wire and running a wire directly to Terminal B on the field from the ecm. Then running a 12v "key on" circuit to Terminal C on the field.
This is related to a 95 Wrangler 2.5
ybody is offline
post #2 of 8 Old 03-14-2019, 02:49 PM
jtec
2014 JK Wrangler
did you check the voltage on the field circuit?
KOEO (Key On Eng Off)
what is the voltage o the 2 indicated wires and what is voltage on PCM terminal
jtec is offline
post #3 of 8 Old 03-14-2019, 02:52 PM
jtec
2014 JK Wrangler
forgot this one PCM #20 what is voltage?
jtec is offline
post #4 of 8 Old 03-14-2019, 06:14 PM Thread Starter
ybody
Jtec...thanks for the response..I can't get back to the Jeep until tomorrow AM.
I do remember that terminal C is not getting voltage with key on or running. I did try supplying it with a 12v jumper and still no charging.
In the meantime is my idea of rerouting the wires a possibility? FYI: The Jeep was charging great before I installed another 2.5 engine....now the charging problem started. Might have broke a wire someplace during the engine swap.
ybody is offline
post #5 of 8 Old 03-15-2019, 07:38 AM Thread Starter
ybody
Just checked it..no voltage at either terminal with KOEO
ybody is offline
post #6 of 8 Old 03-15-2019, 03:55 PM
jtec
2014 JK Wrangler
the wiring diagram to the field circuits show where 12v originates. The Dk/GR wire supplies field voltage, could the connector on alt be bad? maybe open taped harness and probe wires.
This computer was my daughters SO that explains "linda' in attachment
jtec is offline
post #7 of 8 Old 03-15-2019, 05:19 PM Thread Starter
ybody
10-4 on the breaks or bad connector...
I just realized that I have the all of the Jeep wiring diagrams noted in a link at the bottom of my truck forum at: www.3500HD.com Under the 95 Jeep diagrams the info I need is on page 5 of 25. It shows the path from Pin#20 and all of it's splices and connections.
Found that link on this forum someplace and just included it on my truck forum.
Thanks
ybody is offline
post #8 of 8 Old 03-16-2019, 02:12 PM Thread Starter
ybody
Got it...the "black box" connector was bad...just cut it out and ran dedicated (soldered) wires to Terminal B&C. It was hard doing the wiggle test by myself and finally made a set of alligator clips to complete the connections for the ohm meter while I moved the wires around. Appears that at the point where the wires entered the connector there were broken strands (internally).
In any event I'm charging again..Thanks for jumping in.
ybody is offline
12 Things You Can Do When Your ZJ Stalls ZeeJay1997 ZJ Grand Cherokee Forum 447 02-02-2019 10:42 PM
'06 Rubicon - Headlights don't work Nielubie TJ Wrangler Technical Forum 2 01-12-2019 03:28 PM
when i connect battery cel lights up Frank Farace YJ Wrangler Technical Forum 11 01-11-2019 05:22 PM
HELP...2001 TJ 4.0. Limp Mode, P0305 Code Herkybird70 TJ Wrangler Technical Forum 8 10-28-2018 05:15 PM
Help with a trans code Reech WJ Grand Cherokee Forum 1 06-17-2018 12:57 AM
