Clutch pedal stuck in the up position. - JeepForum.com
post #1 of 6 Old 07-26-2009, 06:02 PM Thread Starter
tomurphjr
My wife calls and tells me that the jeep clutch pedal is stuck in the up position and she can't push it at all. I'm on my way over to her girlfriends house now to look at it.
What do you think coukd be the problem? Master cylinder? Slave cylinder, clutch?
tomurphjr is offline
post #2 of 6 Old 07-26-2009, 06:08 PM
88YJtoCJ
if it doesnt move at all, i would guess binding on the linkage (follow the pedal up to the Master and see if it looks ok).
otherwise a seized master cylinder.
88YJtoCJ is offline
post #3 of 6 Old 07-26-2009, 06:09 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Linkage binding.
Joe Dillard is offline
post #4 of 6 Old 07-26-2009, 06:26 PM Thread Starter
tomurphjr
Ok, I can move the clutch pedal. One push and it seems fine, another push and it pretty hard to push. Master cylinder maybe? I really hope it's not the slave.
Is there any way to test the master?
post #5 of 6 Old 07-26-2009, 06:32 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
AHA! Sonavabich! Finally it happened to somebody else!
That's exactly what my '91 did! The spring inside the master cylinder broke about 1/3 of the way from one end. The break left a sharp point that would dig into the side of the OE plastic cylinder & bind the pedal up as hard as a rock.
You need a master cylinder. Try www.rockauto.com for a low price on a new one.
After replacing it, open up the old one & post up a pic of the spring if you can please. I never got a pic of mine.
Here's a write-up I did on master cylinder replacement.
https://www.jeepforum.com/forum/showthread.php?t=728960
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #6 of 6 Old 07-26-2009, 06:39 PM Thread Starter
tomurphjr
Max
Thank you sooo much! This is a great forum!
I'm going to get the master tomorrow and post pics of the springs when I get it out.
Clutch Pedal soft, no resistance, does not engage clutch. Shivam YJ Wrangler Technical Forum 25 02-20-2017 04:10 PM
Question about destroying clutch plate WITH CLUTCH PEDAL DEPRESSED JeffB TJ Wrangler Technical Forum 12 07-20-2009 11:29 AM
P0122 TPS/Pedal Position....?? 03_X TJ Wrangler Technical Forum 1 03-16-2008 01:07 PM
clutch pedal stuck bananamane YJ Wrangler Technical Forum 18 11-28-2005 03:32 PM
clutch pedal stuck to the floor natedawg87317 YJ Wrangler Technical Forum 14 11-15-2005 10:32 AM
