Clutch locking up? - JeepForum.com
post #1 of 10 Old 07-30-2011, 01:48 AM Thread Starter
devoX13
I have a '94 YJ with the 4.0L/AX-15 combo. Every now and then the clutch pedal locks up while driving down the road. I'm not sure what the problem is and the only solution I see is to just replace the clutch. Has this happened to anyone else?
devoX13 is offline
post #2 of 10 Old 07-30-2011, 02:06 AM
monkeyhouse
pedal locks up as in stays at the floor after you push it in to change gears? if so, can you still continue to that next gear even though, the pedal seems to be not working? what happens afterward?
First Jeep was an 1989 YJ, I've also had a Grand Cherokee. Currently, I have a 99 XJ.
monkeyhouse is offline
post #3 of 10 Old 07-30-2011, 02:07 AM
MJMPC
MJMPC's Avatar
The return spring in the clutch master may be broke
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #4 of 10 Old 07-30-2011, 10:02 AM Thread Starter
devoX13
Pedal locks up as in I can't depress it. Lately it's to the point where I dont even bother using the clutch other than in first gear and to slow down
devoX13 is offline
post #5 of 10 Old 07-30-2011, 01:19 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
This is DEFINITELY your problem. Replace the master cylinder, or replace the entire hydraulic system, either way your master cylinder is the cause of your issue.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #6 of 10 Old 07-30-2011, 09:53 PM Thread Starter
devoX13
Thanks! I'm not familiar with any hydraulic clutch systems. Either way, thanks a lot.
devoX13 is offline
post #7 of 10 Old 08-01-2011, 01:33 AM
jayvando707
jayvando707's Avatar
Max
Yep! Apparently the rod inside the MC creates a groove and eventually catches and wont allow you to depress the clutch... Super common with Plastic MC's !!! I went to the part store and they offered a REMAN (plastic) or a NEW one (metal) with a Lifetime warranty for only 10 bucks more! No brainer, right?!
Also, it is super easy to replace.... the hardest part is getting the roll pin to come off the line on the MC....
Good Luck!
It is better to be tried by 12 than to be carried out by 6....
jayvando707 is offline
post #8 of 10 Old 08-01-2011, 03:19 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Not the rod. What happens is that the coiled spring breaks in two and the jagged end binds between the master cylinder wall & the piston. I've had it happen with both the metal & plastic body style master cylinders, but as you stated, it is definitely more common for the plastic version.
The FAQ's list a link for my master cylinder replacement writeup to assist anyone who might need it.
Max
Mean Max is offline
post #9 of 10 Old 08-01-2011, 03:22 PM
jayvando707
Max
Always had my suspicions... A broken springs seems more plauasible! Thanks, I've learned something new!
post #10 of 10 Old 08-01-2011, 03:37 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Yep, that's it. I've personally experienced it twice in my own Jeeps, and I've had a few duplicates come through my Jeep/4X4 shop as well with the same condition. Always the same problem.
Max
Mean Max is offline
