Check Engine Light but no codes - JeepForum.com
 2Likes
post #1 of 35 Old 10-06-2021, 12:52 PM Thread Starter
brandonse24
brandonse24's Avatar
I have her to a point that I can drive her but when I'm accelerating the check engine light comes on. There is not loss of power and if I let off the gas it goes away seems to do it in the 3-4k rpm range no matter the gear. I replaced the crank sensor, map sensor and the plugs but no change. I checked for codes but none are stored. I was thinking of doing the cap, rotor, wires and Coil but I don't want to just shoot the parts cannon as it is getting close to Christmas time. Anyone run across this before?
Black Jeep Society Member #348
Nightcrew #159
brandonse24 is offline
post #2 of 35 Old 10-06-2021, 03:58 PM
bruinjeeper
Moderation in Moderation
bruinjeeper's Avatar
is it possible that your shift light is plugged into the wrong slot or something along those lines?
...or... did this just occur spontaneously without changing anything at all prior to its first occurrence?
~YJOTM MAY '16, JULY '19~
bruinjeeper is offline
post #3 of 35 Old 10-06-2021, 04:55 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
1986 MJ Comanche
Interesting.
Hows your oil pressure at those RPMs?
91 YJ "Alice"
YJOTM Sept. 2017
05 LJ Rubicon "Ghost" SOLD
Luck Favours The Prepared
Luuca is offline
post #4 of 35 Old 10-06-2021, 04:55 PM
jbolty
Administrator
jbolty's Avatar
is a 92 OBD2? if it is, a leaky gas cap can throw an evap code that clears pretty quick
jbolty is offline
post #5 of 35 Old 10-06-2021, 05:06 PM
fishadventure
fishadventure's Avatar
Without a swap to cherokee or tj 91-95 YJ is OBD1
[size=“3”]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
post #6 of 35 Old 10-06-2021, 06:36 PM
Boojo35
1987 YJ Wrangler
This was my first thought.
If you cannot fix it with a hammer then it has to be an electrical problem.
Boojo35 is offline
post #7 of 35 Old 10-06-2021, 06:51 PM
bruinjeeper
the OP did note in another thread he just recently picked this Jeep up.
it's a decent first thought, sir
post #8 of 35 Old 10-06-2021, 07:21 PM
Boojo35
1987 YJ Wrangler
Nope. It is more than decent. It made me very proud of my North of the border buddy. You are a thinker. You have a clue...
Boojo35 is offline
post #9 of 35 Old 10-06-2021, 08:54 PM Thread Starter
brandonse24
Yeah I have no idea what was done to this thing before I got it. I know it has a salvage yard motor because of the paint markings. I ended up have to buy a reman trans for it (yea its still an AX5) because the main shaft was snapped and 2 of the gears were blown apart. I wasn't aware the 92s had a shift light. Could they have crossed a wire so the shift light and the check engine light both use the same bulb?
Nightcrew #159
post #10 of 35 Old 10-09-2021, 08:02 AM
fishadventure
Originally Posted by brandonse24 View Post
Yea. Could they have crossed a wire so the shift light and the check engine light both use the same bulb?
Hard to do with the molded plug, if I recall correctly but anything is possible with folks.
post #11 of 35 Old 10-10-2021, 10:38 AM
jsawduste
2006 YJ Wrangler
The CEL comes on with the ECM grounding the circuit. Wiring issue or an ECM that is wonky.
jsawduste is offline
post #12 of 35 Old 10-18-2021, 03:52 PM Thread Starter
brandonse24
Ok, Messing around online and with the jeep it seems like my cluster is different or not right?
From what I can see online the shift light should be on the bottom left in the panel with the check engine next to it and the left turn light above it.
well the bottom left corner is where my Check engine light is. anyone got any Ideas?
Nightcrew #159
post #13 of 35 Old 10-18-2021, 04:41 PM
bruinjeeper
it may have been a switched up face display by the OP.
You said it was bottom left, and the shift light is bottom left in other photos you observed.
See where i'm going with this?
p.s have to do it - Let's Go Brandon!
post #14 of 35 Old 10-18-2021, 04:49 PM Thread Starter
brandonse24
I went out there and took the cluster out and completely apart. Its not original either as its got a junkyard part number on it. (from what I can find it has to be atleast from a 94 because it has an ABS light, and this one has the shift light bottom middle) I did find however that 1/2 the bulbs were missing (thank goodness I had some new ones in packs). Did not realize I had a check engine and a maintenance light. but regardless I was actually able to pull codes since the maintenance required light flashed for me and not the check engine light. so now I get to play hunt the codes Progress
Nightcrew #159
post #15 of 35 Old 10-18-2021, 04:58 PM Thread Starter
brandonse24
12*: Battery or computer recently disconnected within the last 50 start cycles). This is a very common code. Will not trigger a "Check engine light". (Ok put 17 miles on it since most drives are tests)
22**: Coolant temperature sensor signal above or below acceptable voltage. (new temp sensor but still not reading on the gauge so makes sense)
23**: Intake air temperature sensor signal above or below acceptable voltage. (maybe the problem with the light coming on when rpms are up under load?)
33*: Air conditioning clutch relay circuit open or shorted. If your Jeep doesn't have AC you will always get this code. Will not trigger a "Check engine light". (No A/c dang it)
55*: PCM has finished telling you the codes. This means you are done reading codes.
Any Ideas on my progress and what to check or look at next?
Nightcrew #159
