Chassis Saver vs Bedliner? - JeepForum.com
 1Likes
post #1 of 17 Old 02-04-2018, 10:28 AM Thread Starter
MigMan1313
Iím going to be using chassis saver to restore my frame. My question is for the bottom of the tub, and inside fenders, etc. should I use chassis saver there too or should I spray those with raptor-liner? I have no previous experience with either product so Iím not sure what would be best. I have read that some people use an under coat product on the bottom of the tub then top coat with bedliner. So thatís another option is to use both? What do you think is best?
Sent from my iPhone using Tapatalk
A kid with a dream.
MigMan1313 is offline
post #2 of 17 Old 02-04-2018, 07:10 PM
Towny72
Ask 10 Jeep guys and you will probably get 11 different answers.
I am doing the same thing currently, I am going to use chassis saver for my underside and firewall. If and I am not 100% sold chassis saver does what they say I think it will give great underside protection.
Socialism gave us the Yugo, I'll pass!
Towny72 is offline
post #3 of 17 Old 02-05-2018, 08:00 AM
timatoe
timatoe's Avatar
You'll want something under any liner, it's not meant to go to bare metal (if that's an issue).
I think for the under side Chassis Saver is probably just fine.
timatoe is offline
post #4 of 17 Old 02-05-2018, 10:11 AM
NHfireLJ
NHfireLJ's Avatar
Also, you'll want something smooth, even, high gloss as its sheds salt and debris better.. The chassis saver is a smooth finish... Flat paints tend to adhear the road grime a bit more...
AUDREY...95 YJ UNLIMITED LS
LUCY...2005 Unlimited "LJ" Rubicon Sahara #495
SOLD
BETTY...94, Stroker 4.6,35"s, SOLD
style intake
NHfireLJ is offline
post #5 of 17 Old 02-05-2018, 11:49 AM
crackedcornish
crackedcornish's Avatar
I did mine about ten years ago, I did the entire thing in chassis saver, then a primer, then bedliner, then finally for the outside I used rustoleum
Azhunter1 likes this.
Orange Jeep Club #88
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
crackedcornish is offline
post #6 of 17 Old 02-06-2018, 05:37 PM
fishadventure
fishadventure's Avatar
+1 chassis saver
[size=ď3Ē]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
post #7 of 17 Old 09-16-2020, 08:15 AM
rpwils
Does anyone have experience with using chassis saver on a frame that has part rust and part painted surface? I dont have a sand blaster but they claim you can use sand it with 60 or 80 grit sandpaper. Has anyone use sandpaper on the painted surfaces?
rpwils is offline
post #8 of 17 Old 09-16-2020, 09:40 AM
bruinjeeper
bruinjeeper's Avatar
If I were going this deep.
I'd go all the way and flap the entire frame and then chassis saver it.
It all depends on how much Mojo u got into this.
You could always just quick flap the painted areas or sand and coat over it.
~YJOTM MAY '16, JULY '19~
bruinjeeper is offline
post #9 of 17 Old 09-16-2020, 10:52 AM
rpwils
dumb question - what does flap mean? is that take it to bare metal?
rpwils is offline
post #10 of 17 Old 09-16-2020, 11:23 AM
rpwils
found it - "flap wheel" on your grinder.
rpwils is offline
post #11 of 17 Old 09-16-2020, 12:16 PM
bruinjeeper
Yep. Makes quick work of whatever you would have on there.
post #12 of 17 Old Yesterday, 07:02 AM
rpwils
have you applied chassis saver to bar metal after using a flap wheel? I read a LOT of mixed reviews about applying it to bar metal. My frame is not that bad, just a few rust spots
rpwils is offline
post #13 of 17 Old Yesterday, 07:51 AM
bruinjeeper
I did it to my bare drivers floorboard.
And some sections of my bare tub when I stripped it for monstaliner.
What were the mixed reviews?
post #14 of 17 Old Yesterday, 07:52 AM
bruinjeeper
So then dont flap it. Clean up the rusted out areas.... I know you can slap chassis saver over rust. And dont worry about the non problem areas.
It will save ya cost and time.
You're thinking too hard on this lol.
It's good thick stuff. Clean up what ya can and slap on the chassis saver.
post #15 of 17 Old Yesterday, 08:00 AM
fishadventure
Read the directions - I would clean up the frame, and use rust converter, then apply the chassis saver. It is a very thick-build polyurethane paint so it seals very well. It will stop rust from continuing because it seals out air and is a very durable finish to keep it intact for a long time.
My opinion is that it does not ‘convert’ rust like two-part epoxy paint can or like rust converter does. Complaining people who say it flakes off from what I’ve seen with my own eyes are people who did little prep, no primer, and expected the miracle of de-flaking rusty metal.
I’d say it is as good and I think better than POR15, another polyurethane paint product people expect miracles from.
Fluid film inside a prepped and clean, dry frame is the next logical step.
Bedliner isn’t required- in the rust belt it may aid rusting when salty winter road applications creep under the bedliner and does its thing.
