Charcoal canister - JeepForum.com
post #1 of 3 Old 12-20-2004, 02:04 PM Thread Starter
TSEJEEPERS
TSEJEEPERS's Avatar
Charcoal canister
Will the engine run right without it? I am getting blow by. I know I can fix it by replacing some of the lines but just curiuos. Can you plug it off and go without it?
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #2 of 3 Old 12-20-2004, 02:10 PM
EABiker
The charcoal canister is there to absorb gas fumes before they vent into the atmospere, so yes, you will run fine without it as long as you plug all the vacuum lines. Blow-by , on the other hand, is caused by worn pistons/cylinder walls, and there is nothing you can do external to the engine to fix that!
EABiker is offline
post #3 of 3 Old 12-21-2004, 12:42 PM
Wif
Wif's Avatar
... or a blocked PCV valve system . check the valve and tubing for blocking .. test engine fuming by using clear/transparent tubing between the valve and inlet manifold to gauge the amount of fumes are being drawn thru (you can only do this when the engine is cold .. the suction will colapse the tubing when hot).
If you suspect worn engine, test the compression of each cylinder.
Wif is offline
Charcoal canister? mike240 YJ Wrangler Technical Forum 3 11-07-2008 07:10 PM
Charcoal canister? Redskybri YJ Wrangler Technical Forum 11 02-20-2008 10:37 AM
Charcoal Canister in 98 TJ splitz TJ Wrangler Technical Forum 0 04-09-2007 01:09 PM
charcoal canister ???? jeepinjc YJ Wrangler Technical Forum 2 02-17-2006 02:30 PM
Charcoal canister todnshay YJ Wrangler Technical Forum 3 10-01-2003 08:51 AM
