change motor from 4 cylinder to 6 cylinder - JeepForum.com
post #1 of 10 Old 01-21-2010, 07:02 PM Thread Starter
rhutch
i have an 1989 wrangler with a 4 cylinder and was wondering how hard of a job it would to switch to a 4.0 6 cylinder???
rhutch is offline
post #2 of 10 Old 01-21-2010, 07:04 PM
Fhajad
Fhajad's Avatar
Not too hard. Most of the stuff is the same, just add in wiring for two more injectors, get the ECU and some other things. It's one of the easier swaps.
Fhajad is offline
post #3 of 10 Old 01-21-2010, 07:07 PM
choeyreplied
choeyreplied's Avatar
you need to weld new engine mounts and you will need a new trans
1997 TJ Wrangler Red, 4 banger 5-spd
Viking Soft-top, Half Doors with sliders
32" BFG MT, 2.5" Rough Country Lift
choeyreplied is offline
post #4 of 10 Old 01-21-2010, 07:11 PM Thread Starter
rhutch
ok so a 4.0 wont bolt up to my trans i got now?
rhutch is offline
post #5 of 10 Old 01-21-2010, 07:21 PM
Fhajad
Fhajad's Avatar
Correct, the AX-5 you got will barely hold as it is, muchless anything with roughly twice the power.
AX-15 is a good swap that you'd find with the 4.0 in any manual Jeep.
Fhajad is offline
post #6 of 10 Old 01-21-2010, 07:28 PM Thread Starter
rhutch
ok so probably my best bet is to find a parts jeep with good motor and trans what would be a good year jeep? would it be better with another wrangler or cherokee?
rhutch is offline
post #7 of 10 Old 01-21-2010, 08:55 PM
Fhajad
Fhajad's Avatar
As long as you don't grab a 96+ up Cherokee I think you're ok.
Someone else double confirm this for me?
Fhajad is offline
post #8 of 10 Old 01-21-2010, 10:23 PM
choeyreplied
why wouldn't a 96+ cherokee work?
post #9 of 10 Old 01-21-2010, 11:42 PM
Fhajad
Fhajad's Avatar
OBD-II would be opening up a whole other can of worms and bring in more head aches from what I've seen people do.
Fhajad is offline
post #10 of 10 Old 01-22-2010, 12:16 AM
bigbelman2009
89 is tbi not mpi so he would need the whole harness
bigbelman2009 is offline
Removing center console lock cylinder from latch cylinder Dstompe TJ Wrangler Technical Forum 11 06-27-2009 07:01 PM
4 cylinder head change per year Mack90 TJ Wrangler Technical Forum 0 07-27-2008 06:49 AM
Cylinder 2 misfire dead cylinder plenty of fuel Mel16m TJ Wrangler Technical Forum 10 11-27-2007 10:52 AM
Clutch, Master Cylinder, and Slave Cylinder replaced and problem not solved.... loudog3114 TJ Wrangler Technical Forum 7 08-31-2005 08:37 AM
anyone change out a lock cylinder? hmk_21 YJ Wrangler Technical Forum 3 06-17-2004 01:49 PM
