Carrier question - JeepForum.com
post #1 of 10 Old 11-30-2019, 09:43 PM Thread Starter
ChernabogYJ
Carrier question
This probably is a dumb question big its tripping me up. Im building a rock crawler YJ and am in the process of putting the tons under it. So to go to 5.38s I need different carriers. So in the 14 bolt they have spools that say "4.10 and higher" does that mean higher number/lower gear, or higher gear/lower number? Thanks in advance.
ChernabogYJ is offline
post #2 of 10 Old 12-01-2019, 08:03 AM
fishadventure
fishadventure's Avatar
. It has to do with the configurations of the gears and carriers. So 4.10 and higher a.k.a. 4.10 and up generally means 4.56 or whatever.
[size=“3”]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
post #3 of 10 Old 12-01-2019, 09:59 AM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
What crawl ratio are you shooting for, and what's the rest of the driveline consist of (engine, tranny, transfer case and tire size)?
5.38's could be a poor choice depending on the rest of the driveline, tire size and crawl ratio you aim to achieve.
Joe Dillard is offline
post #4 of 10 Old 12-01-2019, 11:52 AM
timatoe
timatoe's Avatar
Yes, "higher" means numerically higher and ratio lower.
timatoe is offline
post #5 of 10 Old 12-01-2019, 12:09 PM Thread Starter
ChernabogYJ
thank you
post #6 of 10 Old 12-02-2019, 10:51 PM
80cj
80cj's Avatar
1980 CJ5
High ratio carriers have the ring gear flange positioned closer to the pinion since the diameter of the pinion will be smaller. Low ratio carriers are just the opposite with the the ring gear flange positioned further away since the pinion diameter is larger.
80cj is offline
post #7 of 10 Old 12-04-2019, 03:15 PM Thread Starter
ChernabogYJ
that in no way, had anything to do with my question
post #8 of 10 Old 12-06-2019, 02:54 AM
80cj
80cj's Avatar
1980 CJ5
Just information that I thought you might be interested in. It explains the differences between carriers. Isn't this a technical forum? Sorry if you feel insulted.
80cj is offline
post #9 of 10 Old 12-06-2019, 10:05 AM
DRLExpress
DRLExpress's Avatar
WOW, I guess some people don't want to learn anything.
DRLExpress is offline
post #10 of 10 Old 12-06-2019, 12:35 PM
80cj
80cj's Avatar
1980 CJ5
There's a lot to be learned on these forums. I know I've learned a lot. You just need to have an open mind. Another thing is that even if you're the OP, this is a public forum and many others read what is posted also.
80cj is offline
