Carb swap and HEI - JeepForum.com
post #1 of 3 Old 06-01-2020, 10:25 PM Thread Starter
biziedizie
Carb swap and HEI
I want to swap over to the 2100 and do the HEI as well. I have the carb and the plate so that's all ready but the HEI is still a few weeks wait. Can I swap the carb now without any issues? Can I just unplug the stepper and install the 2100 without any issues?
biziedizie is offline
post #2 of 3 Old 06-02-2020, 11:01 AM
bpounds
bpounds's Avatar
I don't see why not. You will have to set your timing manually, and then you'll have to do it again when you get the HEI distributor. So extra work, but not a big deal. Your ICM will continue to work. You should nutter it, so the PCM cannot vary timing, but I think it will play nice regardless. I would not bother going through the nutter for a couple of weeks worth of run time.
Bill
1988 Wrangler,4.2L I-6, Howell EFI JP-1,CRT HEI Ign,AX15 ext slave conversion, Zone 2" lift + 1" BL + 1/2" booms, BFG 31 x 10.5, Bestop.
bpounds is offline
post #3 of 3 Old 06-02-2020, 09:03 PM Thread Starter
biziedizie
Awesome, thanks for the reply. It'll be nice to get rid of that annoying idle issue when everything is done.
