Can the dana 35 handle 33's ? - JeepForum.com
post #1 of 43 Old 03-15-2012, 02:44 PM Thread Starter
87wheeler
1987 YJ Wrangler
Hey guys i am trying to figure out if my jeep still has the stock dana 35 in the rear, or if it was upgraded to a bigger axle. it only has disc brakes in the front drums in rear. I have not been able to find any sort of sticker or tag on the axle indicating what it is. I bought the jeep back in september it came with 33"superswampers 15.5"wide, which the jeep has no problem at all pushing forward, and i do not feel any lack of power whatsoever, very good throttle response. I have the stock 4.2L engine and the TF999 3 speed automatic. Hopefully you guys can chime in as to which axle ive most likely got under there. Thanks appreciate it.
87wheeler is offline
post #2 of 43 Old 03-15-2012, 02:47 PM
Yury
Yury's Avatar
take a pic. if ts a oval cover with a rubber plug then its a dana 35
Home is where the couch is......
Yury is offline
post #3 of 43 Old 03-15-2012, 02:47 PM
dillonjm
dillonjm's Avatar
2013 WK
You most likely have a 35.
Straight off google images (sometimes its quicker to google than make a post FWIW):
Reference the other couple posts on the front page here regarding its strength. This topic has been beat to death.
JEEPLESS
Past Jeeps: 13 GC, 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #4 of 43 Old 03-15-2012, 03:05 PM Thread Starter
87wheeler
1987 YJ Wrangler
heres a pic
post #5 of 43 Old 03-15-2012, 03:32 PM
idskot
It has the same bolt pattern as a D35 / same pumpkin shame. From what I can tell from that picture, at least.
As far as handing 33"s. I have a D35 with 33x12.5 (Not as wide as your behemoth 15.5" tires), and all I can say is that my spider gears are starting to pit. I don't think that's from the strain of the tires.
Members on this forum say it can handle 33"s and lower, but don't go higher because it'll lower the life of the axle by a lot.
However, from my experience with 33"s, it works.
idskot is offline
post #6 of 43 Old 03-15-2012, 04:03 PM
MiNiSaBa
MiNiSaBa's Avatar
That looks like a 35, but that's not the rubber plug they come with. How about a picture of the whole pumkin.
MiNiSaBa is offline
post #7 of 43 Old 03-15-2012, 04:09 PM
dillonjm
dillonjm's Avatar
2013 WK
The older ones have a metal fill plug.
It looks like a dana 35
Edit:
I'm not sure which years, did some searching and didn't come up with much, but I know some years came with metal plugs not rubber.
JEEPLESS
dillonjm is offline
post #8 of 43 Old 03-15-2012, 04:13 PM
MiNiSaBa
MiNiSaBa's Avatar
Cool, I learned something today.
MiNiSaBa is offline
post #9 of 43 Old 03-15-2012, 04:32 PM
zeus87gn
zeus87gn's Avatar
1987 YJ Wrangler
The early versions of the 35 have a stronger housing and larger brakes - and no c-clips!
If you wanted to upgrade any 35, it would be the one to do it to.
Most people decide to replace it completely because of the history.
I swapped the 35 from my 87 (just like yours) into our 92 when I regeared the 87 to 3.55 and put in the 8.25 Chrysler.
We re-geared it to 4.10 with some used gears out of a 4cyl.
It's been behind that 4.0l and AX15 for almost 3 years now pushing 15x10" rims and 33x12.5" tires since the re-gear.
It's been off road numerous times.
No issues whatsoever.
BUT, it's an open carrier - no locker.
I would put a TruTrack in it, but not without some larger axles.
HTH
Handicapped license plates are not for mentally handicapped people -
"Man has not yet evolved an inch from the primordial slime that spawned him." Mark Blankfield, Jekyll & Hyde... Together again
zeus87gn is offline
post #10 of 43 Old 03-15-2012, 05:37 PM
giggityjeeper
I run 33 TSL on my 35 for the last 7 years, so it is capable of doing it, but most of them wont.....
I am NOt hard on it.... I know its limits.. and 33 is about it
Started with some rust repairs ended in a SOA...
family roll bar swap/upgrade..
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline
post #11 of 43 Old 03-15-2012, 07:06 PM
609thomasm
we ran the 35 with a loc-rite, in our 1991 with the TF 999 trans for a year with 35" x 10.50 boggers and had no problem. The automatic trans probably is a little easier on the driveline. Looks like the tag is on the rear still, in the picture i think i see the bottom edge of the tag just under the bolt on the left side.
609thomasm is offline
post #12 of 43 Old 03-15-2012, 07:15 PM
cycleguy04
cycleguy04's Avatar
Originally Posted by 87wheeler View Post
heres a pic
She needs a good scrubbin with wire brush and simple green. Looks like it's caked in oil and grit. Reseal it with black RTV. All in all it ain't pretty. I keep my undercarrage very clean.
'98 Wrangler Sahara - SOLD
'91 Ranger XLT 2WD - 4.0 V6, A4"hell"D, contemplating twin turbo 5.3
'79 C10 Big Ten 2WD - 350, TH350, contemplating rebuilding to 355ci with supercharger and programmable EFI
'12 Subaru Forester (AKA: Arctic Cat) - 2.5, non-CVT, wife's, still begging her to let me get an exhaust system
'01 SV650 - snorkelectomy, ebay slip-on, cam swap and re-jet in the near future
cycleguy04 is offline
post #13 of 43 Old 03-15-2012, 08:20 PM
YJeeps
YJeeps's Avatar
The dana 35 in my 88 YJ looks the same as the one from your picture. (no rubber plug). Mine is the non c-clip 35. I have had 33" bfg a/t's on it for 8 years with no problem. Only thing I have broken is the pinon yoke. I broke it twice. Surprisingly, the axle has held up good. (so far)
YJeeps is offline
post #14 of 43 Old 03-15-2012, 08:59 PM
idskot
I try. I really try. But the second I go off road in South Florida, it's mud. And I don't have a pressure washer strong enough to get that mud off! My pressure washer just gets it wet... haha. It sucks.
idskot is offline
post #15 of 43 Old 03-15-2012, 09:02 PM
mrmark
mrmark's Avatar
Everyone says no, I have 35's on mine with a 4.88's and a Detriot locker and it has held up for well over a year so far and I beat the snot out of it at times. No problems .... yet...
Wave as you pass me :D
The problems of owning 2 Jeeps ... I never know which one to work on or which YJ gets the next mod ...
mrmark is offline
Can Dana 44 handle 37's... larubie TJ Wrangler Technical Forum 66 10-05-2011 10:32 PM
How Does the 6-speed Handle 33's w/3.73 gears? 1badxj TJ Wrangler Technical Forum 36 02-13-2010 04:14 PM
How will my dana 35 handle a locker with 33's renegadeyj YJ Wrangler Technical Forum 10 05-01-2006 02:08 AM
Can the 4-Banger Handle 33's? kdavis TJ Wrangler Technical Forum 14 05-27-2003 06:41 PM
Can Dana 44's handle 38s? Renagade1213 YJ Wrangler Technical Forum 3 01-27-2002 10:55 PM
