A/C Air Scoop? - JeepForum.com
post #1 of 4 Old 08-03-2006, 11:50 PM Thread Starter
90yjkrawler
A/C Air Scoop?
Has anyone purchased an A/C Air Scoop. Its says that it will improve air flow with your A/C and Heater. My A/C does not work too great when I'm running down the road very fast, but it almost blows ice when I'm sitting still. And can it be painted?
http://www.quadratec.com/products/pr...hp?kw=13006.12
Until They All Come Home!
90yjkrawler is offline
post #2 of 4 Old 08-04-2006, 06:47 AM
Fixins13
I've got one. I faced mine in the backwards direction as I did not want to pound water down into the intake everytime it's raining. I don't have AC so I can't attest to improvements on that but as far as inproving the flow of the heat? None. You want more heat? Do the Blazer blower motor mod. http://www.jeeptech.com/body/heater.html
I love sleep. My life has the tendency to fall apart when I'm awake, you know?
Ernest Hemingway
Fixins13 is offline
post #3 of 4 Old 08-04-2006, 07:07 AM
SHARPMACHINE
Wow sweat upgrade for cold weather!
SHARPMACHINE
1989 YJ RE 4" STD., 33X12.5X15 COOPERS ON BLACK CRAGER STEELIES, BESTOP BAKINI TOP. DRIVETRAIN = AMC 360 TF/727, NEXT = WINCH, TUBING AND AXLES????
other toys =
2002 YAMAHA KODIAC 4X4, 2001 400EX MODDED
2006 SKIDOO MXZX600SDI HO MODDED
1996 DODGE 4X4 12V CUMMINS MODDED
SHARPMACHINE is offline
post #4 of 4 Old 08-04-2006, 07:35 AM
Jeepfreak81
Jeepfreak81's Avatar
It didnt affect the flow of air at all... I installed mine so that water would not blow past the seals when I dumped the soft top out, or hard rains would put it on my feet as well... mine faces forward and I have NEVER had water come through the vent since the Cover was put on.
I didnt do it for added airflow as I knew it wouldnt work, I strictly put it on to keep the water out.
My YJ's heater would sweat me out with the 2.5L, the 355 burns my feet. Never had to mod for more heat.
mine looks like this, only in a smoked plastic look
94 V8 YJ, SOA, H1's, 37's, HP D44, D60, 4.88's, winch and some other goodies
1946 CJ2A, 225 V6, T98 D18, Warn OD, D30/D44. Dual winches mild lift & 34's
1966 M416 1/4 ton Military Trailer Expo Trailer
Full Page Club member #004
Green Jeep Club Member #005
Jeepfreak81 is offline
air scoop DGoodman111 YJ Wrangler Technical Forum 34 10-31-2013 02:27 PM
Hood scoop vs AC Scoop vs RunCool (( what are you running on your hood? )) gamer0 YJ Wrangler Technical Forum 7 04-12-2009 07:01 PM
Scoop adp5025 TJ Wrangler Technical Forum 0 09-28-2005 03:33 PM
Air Scoop?? Anyone?? Drunc YJ Wrangler Technical Forum 20 12-25-2002 07:46 AM
Air Scoop? aerobat52 TJ Wrangler Technical Forum 19 11-18-2002 08:57 AM
