The build that was never going to happen - Page 3 - JeepForum.com
 67Likes
post #31 of 98 Old 07-02-2020, 09:46 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Right-on, Jeff It's getting there.
Joe Dillard is offline
post #32 of 98 Old 07-03-2020, 09:07 AM Thread Starter
jbolty
jbolty's Avatar
I have been still working and taking a few pictures.
tapped in bolts for steering stops, I ground that boss flat so the bolt hits straight Mocked up the tie rod. cut off the rear frame and built a back porch. I need to find or make an 8" pitman that has the same splines. Now that the steering box is all mounted it just occurred to me that I probably could have swapped in a ford box, too late now.
jbolty is offline
post #33 of 98 Old 07-03-2020, 05:15 PM
92 Green YJ
92 Green YJ's Avatar
You gonna stretch the body to match that rear frame extension Jeff?
92 Jeep Wrangler Unlimited +
Tons, 40s, tons of mods
92 Green YJ is offline
post #34 of 98 Old 07-03-2020, 08:11 PM Thread Starter
jbolty
jbolty's Avatar
eventually. but not before everything is done I need for wheeling it/
92 Green YJ and NHfireLJ like this.
jbolty is offline
post #35 of 98 Old 07-17-2020, 09:50 AM Thread Starter
jbolty
jbolty's Avatar
Had a few hot days here so been moving slow and nothing exciting to report. Adding gussets and fish plates isn't sexy.
Started mocking up my high steer bracket though. Pretty happy with it so far.
Planning to finally sling the rear axle under tomorrow and get it back on all fours
also managed to fumble the cut off wheel.
NHfireLJ and bruinjeeper like this.
jbolty is offline
post #36 of 98 Old 07-17-2020, 06:47 PM
bruinjeeper
bruinjeeper's Avatar
Yikes.
The jeep may not last forever... but that scar will be a keeper.
Really beefy stuff! Liking it and look forward to the progress.
NHfireLJ likes this.
~YJOTM MAY '16, JULY '19~
bruinjeeper is online now
post #37 of 98 Old 07-18-2020, 07:11 AM
NHfireLJ
NHfireLJ's Avatar
Dang.... To the laceration and the beefy parts... A sewing needle / thread and back to work?
AUDREY...95 YJ UNLIMITED LS
LUCY...2005 Unlimited "LJ" Rubicon Sahara #495
SOLD
BETTY...94, Stroker 4.6,35"s, SOLD
style intake
NHfireLJ is offline
post #38 of 98 Old 07-20-2020, 09:13 AM Thread Starter
jbolty
jbolty's Avatar
this finally happened this weekend, got it down on all fours. I'm pretty happy with the ride height.
now the detail work starts.
drive shafts
brakes
shocks
steering
tub
The high steer bracket from last week was a colossal failure. I was not even drunk but for some reason did not consider it fitting inside the rim and I also did not consider the drag link hitting the spring when turning to the left. I set it all up with everything straight and did not look at the turning angles. Live and learn.
92 Green YJ and bruinjeeper like this.
jbolty is offline
post #39 of 98 Old 07-20-2020, 09:28 AM
bruinjeeper
Looks like a MAJOR oversight here.
Now that I am looking at it, how in the heck do you plan on tipping it and driving while the weight of the vehicle is balanced on your driver's door? Don't tell me you plan on driving with all 4 wheels on the ground, say it isn't so!
*grin*
post #40 of 98 Old 07-20-2020, 09:41 AM Thread Starter
jbolty
jbolty's Avatar
*grin*
lol
I guess most of the future pics will be either mostly level or far more dramatic.
bruinjeeper likes this.
jbolty is offline
post #41 of 98 Old 07-21-2020, 01:18 PM
'92 vegas YJ
'92 vegas YJ's Avatar
Man that sure is a good stretch. What did your WB end up at?
'92 vegas YJ is offline
post #42 of 98 Old 07-21-2020, 01:48 PM Thread Starter
jbolty
jbolty's Avatar
have not measured since I got the axle in but should be 112, I'll check later
jbolty is offline
post #43 of 98 Old 07-22-2020, 08:59 AM
RockWoRM
RockWoRM's Avatar
Originally Posted by jbolty View Post
Swore up and down I was never going to tons. Too much money. Too close to retirement. Too lazy.
THAT would have stopped me right there!
Looking good! Your welds look waaaaay better than mine. The older I get the worse my welds get... go figure. ?
'05 LJR, 6sp, RC long arm w/MC 6" coils, 5.13 D44's w/chromo shafts, MetalCloak fenders/sliders/body armor, 37x12.50 MTR's, Warn 9.5, RockHard swing out w/full spare. <><
RockWoRM is offline
post #44 of 98 Old 07-22-2020, 09:22 AM Thread Starter
jbolty
jbolty's Avatar
True story. I have been using walmart cheater reading glasses for a few years and it suddenly dawned on me to put them on when welding. It was a game changer, I kept thinking the lens was dirty. I have always like to get right up close when welding and probably way closer than when reading a book. #slowlearner
RockWoRM likes this.
jbolty is offline
post #45 of 98 Old 07-26-2020, 06:18 PM Thread Starter
jbolty
jbolty's Avatar
helping a friend get ready to move cross country so not much progress this week. hooked up steering hoses and worked on re engineering the high steer bracket. No pix tho.
I did put in the cj tailgate for a test fit and it's perfect. Anyone know what this is from? Cj6? 7? 8? Need to order a gasket
jbolty is offline
