Budget Shock Swap.. Help Please - JeepForum.com
post #1 of 7 Old 04-05-2012, 07:28 PM Thread Starter
ashland82391
ashland82391's Avatar
So 5 months ago I purchased new shocks for my jeep and now I want to do a lift. I bought the shocks from autozone, Gabriels I think. I'm going to do an s10 bastard pack lift which should give me about 3 inches. I have a friend at autozone that will let me swap my shocks for longer truck shocks that are the same price. So I will basically be getting longer shocks for free.
What I need to know is what shocks can I replace the stock ones with that will be 3 - 4 inches longer.
I will not be purchasing shocks from anywhere else I just want to trade my shocks so it won't cost me extra.
ashland82391 is offline
post #2 of 7 Old 04-05-2012, 08:12 PM Thread Starter
ashland82391
bump..
post #3 of 7 Old 04-05-2012, 08:26 PM
scubamc
No response after 44 mins. Have a little patience. To get the correct length shocks you should take some measurements after the lift is installed. If you just want to guess just pull up the specs on your shocks and find something that gives you more up and down travel.
Horsepower is like a hot girl with STDs. You know you want to hit it but you're afraid of the consequences.
scubamc is offline
post #4 of 7 Old 04-05-2012, 08:35 PM
Louie4
Louie4's Avatar
1935 CJ2A
This is what I used when I replaced my shocks. I sized them up from the Monroe catalog and matched the mounting codes with the extended and compressed lengths (which I measured on my jeep when I flexed it out). I got my shocks at Autozone and they just cross referenced the part number to come up with the Gabriels.
http://www.monroe.com/assets/downloa...engthSheet.pdf
I actually helped my buddy size up some Gabriel's on his CJ-7 about 3 weeks ago. Three out of his 4 shock mounts broke so he moved them. I actually found the extended and collapsed lengths on the Gabriel website but I can't find it now.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #5 of 7 Old 04-05-2012, 09:52 PM Thread Starter
ashland82391
ok cool, for those that may have my question as well ill post my findings thus far.
Based on this web site(as posted above) http://www.monroe.com/assets/downloa...engthSheet.pdf
I have found that 1997 ford f150 rear shocks for the front on the yj are just about perfect and mounting is almost exactly the same, but ill be using Gabiral shocks so the lengths very a little from the monroes. I especially like the fact that the f150 shock has 12.03 inches of travel!
YJ stock specs: Compressed 14.5 in
Extended 24.375 in
Travel 9.8 in
(Gabriel Pro Guard Shocks)
97 F150 specs: Compressed 16.3 in
Extended 28.3 in
Travel 12.03 in
Now ill look to see what I can find for rear shocks
-Update-
Here is what I found for the rear. 1974 ford F250 shocks will mount up perfectly and have the exact lengths I want as well.
YJ stock specs: Compressed 11.8 in
Extended 18.3 in
Travel 6.5 in
(Gabriel Guardian Shocks)
74 F250 specs: Compressed 13.8 in
Extended 23.2 in
Travel 9.3 in
I'm happy with these specs and it will be free so I will go good with my budget bastard pack lift. Thanks for everyone's help. I will post how it rides when I get them installed.
post #6 of 7 Old 04-06-2012, 04:00 PM Thread Starter
ashland82391
Got the 97 f150 shocks today, fit perfectly! I have to wait untill tomorrow or monday to get the 74 f250 shocks because they were special order. I also found out today that I will be making money by switching to truck shocks!!! ha All 4 of the yj shocks cost 24.99 and the f250 shocks only cost 16.99 so ill get like 16 bucks back! cant beat that.
here is a picture of the shocks compressed and extended. The compressed one can go down about 2 more inches its held down by the retainer strap.
post #7 of 7 Old 04-09-2012, 12:09 AM Thread Starter
ashland82391
Got the 74' f250 shocks in today and they fit like a glove!!! I am super pleased with the truck shocks and the fact I made 17$!!! from doing this swap! here is some pictures. I will be creating a thread just for this to make it easier to find. Wish there would have been one for me so im sure someone will be able to benefit from it.
second picture is collapsed and extended length
100_1905 (800x600).jpg   100_1906 (800x600).jpg   100_1908 (800x600).jpg   100_1907 (800x600).jpg
Budget axle swap help JJeeper09 TJ Wrangler Technical Forum 10 09-27-2010 05:53 PM
Stock Shock and budget boost help Zeusismyonlygod TJ Wrangler Technical Forum 4 09-13-2010 06:06 PM
Stock shock life expectancy with a budget boost? IBreakStuff TJ Wrangler Technical Forum 1 01-31-2010 08:56 PM
Rough Country Budget Boost no front shock extension ??Why?? Mike_Motorbike TJ Wrangler Technical Forum 9 12-09-2009 01:56 PM
RE Budget boost shock bushings jmasin3 TJ Wrangler Technical Forum 2 08-02-2009 06:12 PM
