broke windshield hinge - JeepForum.com
 1Likes
post #1 of 16 Old 04-13-2019, 02:15 PM Thread Starter
04TJ-jeeper
04TJ-jeeper's Avatar
took the jeep out for a little run yesterday at local ORV park, went to fold down the windshield once it started warming up and broke the driver side hinge. picked up a new one on the way home. I got the bolts out of the windshield frame but the bottom bolts are just spinning. is there a nut somewhere inside the dash?
1987 YJ 4.2 / 1990 YJ 4.2 / 1995 YJ 4.0 / 2014 JKU / 2019 JLU
04TJ-jeeper is offline
post #2 of 16 Old 04-13-2019, 02:28 PM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
Yes, there are nuts high up under the dash.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #3 of 16 Old 04-13-2019, 02:42 PM Thread Starter
04TJ-jeeper
alright, is it something I can get a socket to or do I need to take the dash apart
post #4 of 16 Old 04-13-2019, 03:00 PM
Waternut
Waternut's Avatar
Depends on which ones. You're more likely to get an open ended wrench on them but they usually have sealant on the nuts so they can be a pain. You can drill them out as well if you're struggling with the sealant but you'd still have to get new ones back on.
Waternut is offline
post #5 of 16 Old 04-13-2019, 03:04 PM Thread Starter
04TJ-jeeper
gotcha so it can go either way, i'll tackle it tomorrow. hoping there's no sealant
post #6 of 16 Old 04-13-2019, 06:58 PM
fishadventure
fishadventure's Avatar
vise grips
[size=“3”]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
post #7 of 16 Old 04-13-2019, 08:14 PM
jbolty
jbolty's Avatar
there is usually a big goop of body sealer sprayed up in there. Not so bad if you pull back the dash or have small hands. take out the front seat so you can lay and look up underneath
jbolty is offline
post #8 of 16 Old 04-14-2019, 01:51 PM
Boojo35
Here is what you are looking for. I am sure what is so hard about it. Mine are right out in the open..... Then again... My dashboard and tub are not even in the same building right now.
If you cannot fix it with a hammer then it has to be an electrical problem.
Boojo35 is offline
post #9 of 16 Old 04-14-2019, 06:27 PM
zrickety
zrickety's Avatar
I know you already have another hinge, but did you consider welding it? MIG got mine back together.
1988 Jeep Wrangler Laredo
zrickety is offline
post #10 of 16 Old 04-14-2019, 07:08 PM
StrippedTorx
StrippedTorx's Avatar
Getting the nut off is the easy part, shoving your hand up there to start the nut is the hard part. I ended up putting tape on the wrench to help get it started without dropping it 20 times.
StrippedTorx is offline
post #11 of 16 Old 04-15-2019, 07:19 PM Thread Starter
04TJ-jeeper
Update time. I got the dash mostly torn apart to realize i had stripped bolts everywhere from previous owners, so I replaced as I went. I didn't get to the three I needed for the hinge since I got tired of drilling out 30 year bolts/screws. I did find my nutsert tool and now I'm wondering if I can drill out the bolts, insert a nut and future proof this thing if I have issues again. Anyone ever do this for the hinge?
post #12 of 16 Old 04-15-2019, 07:42 PM
Boojo35
They are a simple nut on the back side. Loosen up or pull the dash for access.
Boojo35 is offline
post #13 of 16 Old 04-16-2019, 03:45 AM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
Nut sert should work. If you have access to a welder I would make a small 16ga plate that spans over both holes weld nuts to the plate and tack weld the plate to the body. It would suck again if your nutsert started to spin down the road. Definetly a couple of ways to skin that cat.
YJUnlimited stretch, Links, SBC, Tons, Lockers, and stuff
March 2017 YJOTM/ 2017 YJOTY
87TPIYJ is offline
post #14 of 16 Old 04-16-2019, 06:49 AM Thread Starter
04TJ-jeeper
i cant get my hands through the dash so I tried pulling it which resulted in a weekend of extracting and replacing stripped bolts and nuts. 2 solid days of jeep time and I still haven't gotten the dash out yet. which is why i'm looking at other options instead of sinking anymore time into extracting the rest of the dash
post #15 of 16 Old 04-16-2019, 08:45 AM
Boojo35
^^^^^ that suks. My dash only had one fastener that was stubborn up by the windshield. A little heat worked. I guess I was lucky.
Boojo35 is offline
95 YJ Windshield Hinge troywoolery95yj YJ Wrangler Technical Forum 4 09-19-2018 02:40 PM
Windshield hinge mangomankw YJ Wrangler Technical Forum 14 05-20-2018 06:23 PM
Wiring your lights to a Windshield Hinge Bracket-Like a pro! Overland61 TJ Wrangler Technical Forum 7 05-12-2018 03:31 PM
Broke door hinge weld Beat-93azxj XJ Cherokee Technical Forum 1 03-05-2018 05:47 AM
windshield hinge rehab lthays YJ Wrangler Technical Forum 14 12-27-2017 11:12 AM
