Boomerang Shackles - JeepForum.com
post #1 of 46 Old 01-27-2009, 06:28 PM Thread Starter
lawson1273
Boomerang Shackles
Whats the opinion on these I am thinking of getting these and getting rid of my 2" shackles. Is it worth it?
lawson1273 is offline
post #2 of 46 Old 01-27-2009, 06:32 PM
jgillespie
jgillespie's Avatar
completely worth it. very good investment
'91 YJ 4.0 3/4'' Brandon Booms 31/10.50 BFG AT Herc'd CJ dash/tailgate CJ5 seats 4KCs cracked windshield
RED JEEP CLUB MEMBER 536
Originally posted by Crazyquadder:
a 6 foot puddle is approx half way up my doors
jgillespie is offline
post #3 of 46 Old 01-27-2009, 06:37 PM
Brandon_YJ
Brandon_YJ's Avatar
1987 YJ Wrangler
A set of ~3/4" boomerang shackles would compliment your 4" suspensionquite nicely.
Check the YJ Tech FAQ, there's a big thread in there about shackles.
Originally Posted by Mean Max View Post
I think I'll keep the YJ. But can I talk you into taking the wife?
DISCLAIMER: I (usually) browse the web using
in a (text only)
. Which means I do not have image viewing support. So if you get confused by my seemingly inability to comment on your pictures, emoticons, etc; now you know why.
If you're still confused
to see how I view the forum.
Brandon_YJ is offline
post #4 of 46 Old 01-27-2009, 07:11 PM
Tompatt
Tompatt's Avatar
1987 YJ Wrangler
exactly what brandonyj made for me... I ditched my 2" shackles and am almost done with the lift... rides nice in the front... get them.
Thomas
-1987 YJ
Tompatt is offline
post #5 of 46 Old 01-27-2009, 07:16 PM
chadroc
chadroc's Avatar
I have a set of them from brandonyj on both of my jeeps. Theyre nice!
chadroc is offline
post #6 of 46 Old 01-27-2009, 08:49 PM
4.7stroker
4.7stroker's Avatar
My understanding is that booms do nothing more than act as shackles on the front. Hole to hole is the lift the angle makes no difference.
On the back they will provide clearance to stop suspension binding and aid articulation.
This is not to say that they don't have some cool factor though.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #7 of 46 Old 01-27-2009, 08:51 PM
Brandon_YJ
Brandon_YJ's Avatar
1987 YJ Wrangler
Dwayne
For guys with 1" shackles or (gasp) even more, boom shackles do cut back on the Big Brown Bever look as well.
You are correct, there is no benefit of the "design" in the front over a well designed "H" style shackles, but if you have boomes in the back, and are getting new front shackles... might as well keep them the same.
in a (text only)
post #8 of 46 Old 01-27-2009, 09:28 PM
Axl Jack
Axl Jack's Avatar
To the OP, yes! Get rid of those shackles. Not only do they look awful, but more importantly the taller the lift shackle, the more is messes with your steering. So, when and if you do order some new shackles, do not go over 3/4" lift.
Booms do nothing on the front. So don't order a $100 set from MORE or somewhere similar because you think you need them. If you want them for the look, I suggest getting them from a certain someone who is posted above me. (I have a set of Brandon_YJ's on the rear and I like them. Helps let the back springs clear the rear crossmember more. And they look cooler too.)
94 YJ w/ stuff. All the work/money I put into it, and the comment I get most is my $20 mod: "Hand throttle?!? That's awesome."
Originally Posted by dmcanally View Post
You know you drive a YJ when it is no longer getting older, but slowly becoming brand new part by part.
Axl Jack is offline
post #9 of 46 Old 01-27-2009, 10:00 PM
MLJeeper
MLJeeper's Avatar
Originally Posted by Axl Jack View Post
Booms do nothing on the front. So don't order a $100 set from MORE or somewhere similar because you think you need them. )
I disagree, although the design does not serve the same function on the front as it does the back, the boom design with the bolt in the middle is excellent protection against spring inversion. Not super common on SUA rigs, but it only takes once to trash your spring.
Your limited slip differential sucks.
Any video of the sound?
MLJeeper is offline
post #10 of 46 Old 01-27-2009, 10:13 PM
bigsquat
bigsquat's Avatar
im running 6" booms on the front and 5" on the back. if the front werent booms ,they would look a lot worse. my steering is ok but im on stilts.
red 92 yj,4.0,dana 44 rear,xj driveshaft,rubi 4-1 tc,35"tires,smitty built winch,oba, 6" flares,hand throttle,aussie's front and back,posi-lock,6" lift.anti-wrap, hombrew bumpers, rack and sliders,cb,rear shock truss <>< ,MY BUILD:
Two fish swim into a concrete wall. One turns to the other and says 'Dam!'
bigsquat is offline
post #11 of 46 Old 01-27-2009, 10:34 PM
Brandon_YJ
Brandon_YJ's Avatar
1987 YJ Wrangler
You're right aboutthe spring inversion prevention... and unintended benefit of the shackle design.
Assuming the person does put a bolt in there.
I should ammend my previous post, how in the hell did I omit that?
But I'm lazy, so I'll leave it be.
in a (text only)
post #12 of 46 Old 01-28-2009, 08:32 AM
GrimJeeper91
GrimJeeper91's Avatar
I bent both front springs once when my shackles inverted. Now I have booms up there to prevent this. Besides the booms looking a little better they do serve a purpose.
'91 YJ 4.O, Auto, Rr. D60 w/ 35 Spline Alloy USA Axles & Detriot Locker, Fr. D30 True-Trac, 4.56's, 4.5" Deaver Springs, Bilstein 5100's, 1" BL, Rubi Flares, 35x12.50 MT/R's on MT classic II's, Detroit Locker, Vanco Big Brakes, Booster & Master, Warn 9000XDI, York OBA, AA SYE & TW's DS's, Teraflex Belly Up, Rocker Guards...
GrimJeeper91 is offline
post #13 of 46 Old 01-30-2009, 05:14 PM Thread Starter
lawson1273
So I got the boomerange shackles tonight and in the instructions it shows the rear shackle with the curve going to the out side. Well how about the front. Anyone got a pic of these things so I dont put them on backwards.
post #14 of 46 Old 01-30-2009, 05:37 PM
Jeffro06
Jeffro06's Avatar
My MORE booms....
Front
Back
Jeffro06 is offline
post #15 of 46 Old 01-30-2009, 05:41 PM Thread Starter
lawson1273
Thanks alot...
teraflex revolver shackles vs boomerang 5/8 more shackles jpringles YJ Wrangler Technical Forum 21 12-23-2010 02:35 PM
Boomerang Shackles with a SR kit DrifterX YJ Wrangler Technical Forum 1 02-08-2009 03:19 PM
Boomerang Shackles onlyinayj89 YJ Wrangler Technical Forum 4 10-22-2008 09:22 PM
Boomerang Shackles?? Goobersbro YJ Wrangler Technical Forum 9 10-17-2008 05:04 PM
Boomerang Shackles 4.3jeepyj YJ Wrangler Technical Forum 14 02-19-2007 06:26 PM
