Bolt in Cruise Control? - JeepForum.com
 4Likes
  • 2 Post By Luuca
  • 1 Post By RockWoRM
  • 1 Post By EABiker
post #1 of 11 Old 06-10-2021, 10:46 AM Thread Starter
Mercenary911
Hey folks. Does anyone know of a direct bolt in Cruise Control system for our YJ's? I'd love to add CC to mine.....
Mercenary911 is offline
post #2 of 11 Old 06-10-2021, 11:23 AM
timatoe
timatoe's Avatar
Don't know of one specific to the YJ, but I had an older motor home that a PO had added a generic cruise control to, so it's likely available out there.
timatoe is offline
post #3 of 11 Old 06-10-2021, 11:25 AM
jbolty
Administrator
jbolty's Avatar
I added a cruise control to one of my cars back in about 1980. it had a magnet taped to the driveshaft as a speed sensor and a vacuum motor to pull on the throttle. worked pretty well.
https://www.google.com/search?q=add+...4dUDCAk&uact=5
jbolty is offline
post #4 of 11 Old 06-10-2021, 11:43 AM
Awesome
Awesome's Avatar
Yes. The Cherokee cruise control will bolt in.
The 4th 5-seater YJ in the world.
Awesome is offline
post #5 of 11 Old 06-10-2021, 01:09 PM Thread Starter
Mercenary911
Really eh? Is there a write up on this somewhere?
post #6 of 11 Old 06-10-2021, 02:01 PM
Awesome
Awesome's Avatar
I can't find a write-up, but I'm sure there was one at some point. If you went to a junkyard it'd be pretty straightforward to pull the Cherokee stuff out and then stick it in your YJ.
If not, there are other options.
https://www.jeepforum.com/forum/f12/...62/index2.html
https://www.jedi.com/yj-cruise-control/
https://www.thecruisecontrolstore.co...e-control-kit/
Awesome is offline
post #7 of 11 Old 06-10-2021, 04:52 PM
skjeep
if it an fuel injected engine (post 90) then cruise from an XJ will bolt on
If its carbed 4.2 then iŽd look for some universal aftermarket solution
current 2x XJ, 2x JK-U, SJ, M38A1, WJ
gone XJ, TJ, XK, ZJ
skjeep is offline
post #8 of 11 Old 06-10-2021, 05:20 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
1986 MJ Comanche
Lockable hand throttle - we die like men.
timatoe and Mercenary911 like this.
91 YJ "Alice"
YJOTM Sept. 2017
05 LJ Rubicon "Ghost" SOLD
Luck Favours The Prepared
Luuca is offline
post #9 of 11 Old 06-10-2021, 06:47 PM
RockWoRM
RockWoRM's Avatar
Had that on the YJ... never really felt comfortable using it that way. lol.
On the other hand... the LJ has cruise... hardly EVER use it. But then again, it's not a DD either.
Luuca likes this.
'05 LJR, 6sp, RC long arm w/MC 6" coils, 5.13 D44's w/chromo shafts, MetalCloak fenders/sliders/body armor, 37x12.50 MTR's, Warn 9.5, RockHard swing out w/full spare. <><
RockWoRM is online now
post #10 of 11 Old 06-10-2021, 07:21 PM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
I put one of those in to raise the idle while airing up with the York. I've used at times for a cruise control, mainly on the interstate where hills are minimal.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" Patagonia M/Ts, AX15, NP231+4:1+SYE+2LO, York OBA.
Web Admin for
JeeperDon is offline
post #11 of 11 Old 06-11-2021, 06:48 AM
EABiker
I had the digital version back in the day, which also monitored fuel consumption. The coolest feature was the fact that you could punch in the speed you wanted the cruise control to be set to. I would cause some concern to my passengers when I would punch in 999mph, and hit engage!
Mercenary911 likes this.
EABiker is offline
