Body and suspension lift - Page 2 - JeepForum.com
 1Likes
post #16 of 28 Old 04-12-2017, 04:40 PM
Chrisnvegas
Windows95
Chrisnvegas's Avatar
33's will make your Jeep one inch taller.
33's will be one inch closer to your fender flares.
So if you add a 1" body lift, you're back to where you are now.
33's will change your gearing some though, so expect slower acceleration and a further change in speedometer accuracy.
They'll also increase the likelihood of damaging your rear axle so be warned.
End the Ethanol Rip-Off
Chrisnvegas is offline
post #17 of 28 Old 04-13-2017, 04:32 AM
fishadventure
fishadventure's Avatar
Originally Posted by NachoYJ
So a body lift would be a better solution but just a little more expensive?
Not necessarily. What I said was lifting was a system of numerous parts. A combination of different parts approaches used to get the overall lift you need avoids the potential negatives of a single solution lift. I mentioned a few things with the front end earlier, tall lifts usually have needs to address rear driveshaft also. None of which is groundbreaking. What makes a lift "more expensive" isn't an a+b=c answer. The factory suspension is a system with one component depending on another and working in concert with it. If you change one factor of that system, most often other systems are effected, too. So that requires other parts. Hence more money...
Someone else's post just above here mentioned gaining an inch with body lift to do what you need. I'd start by looking into that.
That's the closest you're going to get to the a+b=c answer in this context.
[size=“3”]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
post #18 of 28 Old 04-13-2017, 06:15 AM Thread Starter
NachoYJ
Thanks for the help, I'm kinda new to all this haha.
NachoYJ
NachoYJ is offline
post #19 of 28 Old 04-13-2017, 06:17 AM Thread Starter
NachoYJ
So basically an extra 1" body lift with 33s is the same as a 2.5"suspension lift with 31s?
NachoYJ
NachoYJ is offline
post #20 of 28 Old 04-13-2017, 06:18 AM Thread Starter
NachoYJ
Originally Posted by mike134 View Post
What lift do you have? not all 2.5" lifts are actually 2.5". For example, a OME 2.5" lift will often fit 33's out of the box. Some need 1" more of body lift. Others need a little bit of shackle lift in addition to both.
Do not put more than 1" of body lift on.
Well I have a 2.5 rough country, I was told that I could only fit 31s so i don't know what type of lift I have or exactly how tall it is
NachoYJ
NachoYJ is offline
post #21 of 28 Old 04-13-2017, 06:19 AM Thread Starter
NachoYJ
Originally Posted by johnboy68 View Post
I was thinking the same thing. Pics or it doesn't exist. Plus, pics would help us solve your problem.
Told my friend to put in information for me while I was on vacation and he screwed up..
NachoYJ
NachoYJ is offline
post #22 of 28 Old 04-17-2017, 07:59 AM Thread Starter
NachoYJ
Cmon now I need help haha
NachoYJ
NachoYJ is offline
post #23 of 28 Old 04-17-2017, 09:31 AM
Randonexplosion
Randonexplosion's Avatar
Are you going to wheel it or is it going to be a mall crawler? There are a lot of variables and every Jeep is different. Hard top/full doors? Soft top? No top?
The best recommendation I can give is going to be a combination of several things that @jbolty already posted. Small body lift, small shackle lift and trim some metal from your fenders.
Randonexplosion is offline
post #24 of 28 Old 04-17-2017, 12:00 PM Thread Starter
NachoYJ
I'm only 16 so I can't do much
NachoYJ
NachoYJ is offline
post #25 of 28 Old 04-17-2017, 12:01 PM Thread Starter
NachoYJ
But I do a fair amount of wheeling, not very much rock crawling. Mainly just trailing and muddling. Soft top with full doors most of the time doors aren't on when weather is nice. No fender flares at all. With that being said what do you think. Randonexplosion
NachoYJ
NachoYJ is offline
post #26 of 28 Old 04-18-2017, 07:31 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
Originally Posted by NachoYJ View Post
I was wondering if I could get that clearance just by shackles or if I need a whole body lift, because I'm not looking to spend too much on this.
None of this is cheap. Your best approach is keep what you have until you can get the bucks to do it right, a 4" lift. Then you will likely need a SYE, a drive shaft, and steering work. What new people don't realize is that Jeep was OEM designed as an integrated system, all things matched. When you come along and alter one thing, other things then don't work right. You are then back here asking why your steering isn't right, why you get vibrations when accelerating, etc.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #27 of 28 Old 04-18-2017, 09:57 PM
Mgut94
I am currently in the same situation as you, when I was in high school I put a 2.5 inch lift and 31s, it's starting to sag and I'm also moving up to 33s. I've considered a few options, first just to swap out the suspension with a new 4" lift, the second a 1 inch shackle lift with a 1 inch body lift, and the third, to add TJ flares and either the body or shackle lift I mentioned before.
I'll probably go with the new 4" just to ditch the sagging springs.
I think that it is really up to you to decide what you want to do based on what you use it for. Whatever it is, it's probably gonna be a little pricey. We are in an expensive hobby after all......
Mgut94 is offline
post #28 of 28 Old 04-20-2017, 12:31 AM
Bigmaaty
1979 CJ7
All good advice above. If you decide to go with a body lift I can hook you up with an inexpensive solution. I have had this on my '89 YJ for two years now and it is holding up well. Take a look. If you are interested send me a pm.
https://www.jeepforum.com/forum/f12/w...t#post26289850
Bigmaaty is offline
suspension , tires , YJ
