bigger tires, the right gear ratio vs. speedo gear - JeepForum.com
post #1 of 4 Old 07-13-2008, 05:36 PM Thread Starter
krafalco
on my 93 yj, I installed 33x10.50's and removed the 307 gears and installed 4:11 gears. Now that should put me back to stock.Now finding a 34 tooth speedo gear is giving me the fits, but cruising down the road it seems like the correct speed. Shouldn't changing the ring and pinion to match the tire size put the speedometer back to stock speedometer reading? Why would you have to change the speedo gear? Now everyone set your beer down and think about this one.Can't use your opinion after the 24th beer.
krafalco is offline
post #2 of 4 Old 08-16-2011, 11:09 AM
g_oneill
g_oneill's Avatar
g_oneill is offline
post #3 of 4 Old 08-16-2011, 11:15 AM
Tom95YJ
Tom95YJ's Avatar
If you changed the Gearing in the axles to the proper ratio for your tire size you wont need to change the speedo gear
'89 YJ The Smurf Yjoty 2016
'99 XJ Black Betty
Tom95YJ is offline
post #4 of 4 Old 08-16-2011, 06:58 PM
timatoe
timatoe's Avatar
What is the tooth count on the gear in there now? Tom's right if the stock tire and gear ratio is equivalent to the current tire and gear ratio the speedo shouldn't really change.
timatoe is offline
2?'s Which speedo gear and actual gear ratio maxum3300 TJ Wrangler Technical Forum 6 01-15-2010 06:40 AM
bigger tires... re-gear??? ishkaban JK Wrangler Technical Forum 10 10-19-2008 11:09 AM
Help with gear ratio and speedo gears.. simplybao TJ Wrangler Technical Forum 5 05-13-2008 05:59 PM
Anybody have 3.21 gear and added bigger tires? Slenny JK Wrangler Technical Forum 2 11-10-2007 05:28 PM
GEARING RATIO/Speedo gear... Bheleu33 YJ Wrangler Technical Forum 16 04-15-2006 05:04 PM
