Battery Not Charging! - JeepForum.com
 1Likes
  • 1 Post By Que89YJ
post #1 of 12 Old 10-18-2016, 10:43 AM Thread Starter
xlTravislx
xlTravislx's Avatar
This past weekend I did quite a bit of wheeling, lots of bouncing around, off camber hills ect.. I managed not to break anything! However,
On my ride home I got a cheek engine light on. Looked at my gauges and noticed my battery was at 12.4 while the engine was on (I have a digital volt gauge that is on 24/7 in cab). I typically run 13.5 at idle. I managed to make it home with the battery slowly draining down to 11. when I pulled into my driveway. I charged up the battery over night and its been 48 hours still holding its 12.7 charge.
My first guess was to cheek the 2 fuses that regulate the amps the alternator puts out. Both of those are fine.
I then cheeked my battery terminal connections and the connections on the alternator, including the grounds. all tight.
My battery and alternator are both less than 6 months old. (I know that doesn't make them immune to failing early).
Before I pull out the alternator to have it bench tested is there anything else that could possibly be a culprit? Does the PCM have any control of the alternator? Possibly a loose connection on one of the pins? Are they any external regulators or relays that would prevent the battery from charging?
Thanks for the help JF!
-White Jeep Club Member 231-
Replacing random parts on hunches spurred from other vehicles and peoples experiences with them is the safest bet.
xlTravislx is offline
post #2 of 12 Old 10-18-2016, 10:45 AM Thread Starter
xlTravislx
xlTravislx's Avatar
That cheek engine light code was 41. "generator field not switching properly"
post #3 of 12 Old 10-18-2016, 12:24 PM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
I don't do mud, but I've read that it can take out alternators.
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline
post #4 of 12 Old 10-18-2016, 01:28 PM Thread Starter
xlTravislx
xlTravislx's Avatar
I learned that about 5 years ago. Mud is the devil. My jeep hasn't seen mud in forever.
post #5 of 12 Old 10-18-2016, 01:29 PM
Que89YJ
You are not getting enough power out of the alternator. You checked the connections but did you clean them? If they really are clean then you have an alternator issue. Just a heads up, if you are wheeling it you need to get dielectric grease in all the electrical connectors. ALL of them. Hit the battery cables and connectors with real grease. If you have to replace the alternator go with the grand Cherokee alternator. It buttons right up but gives you 135 amps instead of the 90 stock.
bruinjeeper likes this.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #6 of 12 Old 10-18-2016, 07:37 PM
DirtKar
I pledge allegiance
DirtKar's Avatar
Good advice ^^^ And... If you do go with the 135a alternator (which I highly recommend) be sure to look up 'big three wiring upgrade' as well.
Luck Favours The Prepared
YJOTM JULY 2014
DirtKar is offline
post #7 of 12 Old 10-18-2016, 08:33 PM
TSEJEEPERS
TSEJEEPERS's Avatar
If you are still running stock cables I would start there.
As suggested look up the big three and make your own cables.
You are probably going to do it anyway if you go with the bigger alternator.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #8 of 12 Old 10-18-2016, 08:47 PM
Bigmaaty
1979 CJ7
I didn't see 'mud' mentioned in the original post but in Fla. that's a safe bet. My son destroyed two alternators in a year going mudding in his xj. Packs into the back and won't allow the alternator to cool. All good advice above, I would probably start with a bench test at your local parts store.
Bigmaaty is offline
post #9 of 12 Old 10-19-2016, 01:21 AM
Mr.B
Mr.B's Avatar
I guessed. 23 years old, living in Fl.
Maybe this video helped.
Ham license:
Everyone is Welcome
Mr.B is offline
post #10 of 12 Old 10-19-2016, 10:39 PM
DirtKar
I pledge allegiance
DirtKar's Avatar
Clowns, mud and rust. Not necessarily in that order. Well, the clowns stay in first place and the latter are interchangeable.
YJOTM JULY 2014
DirtKar is offline
post #11 of 12 Old 10-20-2016, 03:57 AM
bruinjeeper
bruinjeeper's Avatar
I dont mud often my friends, but when i do... i changed my transmission fluid.
Stop whining about the 'ride' - If your YJ ain't wrangling your soul free, then might I suggest you buy a stationwagon... at least you can fit all your bull**** in the back.
~YJOTM MAY '16~
~YJOTM JULY '19~
bruinjeeper is offline
post #12 of 12 Old 10-20-2016, 02:53 PM Thread Starter
xlTravislx
xlTravislx's Avatar
The alternator was dead. Not putting out anything at all.
I would love to do the WJ (or is it ZJ) alternator upgrade but my current alternator was under warranty so that was FREE.
I thought about simply paying the difference but even with a coupon and the difference on my old alt I would have been paying out about $120 for the 98 grand Cherokee v8 135A alternator..
Everything on my jeep is LED or low draw. There are only 2 things that I can think of that use a good amount of power.
1. My air compressor. (used daily)
2. Winch ( which is used rarely)
I desperately need to do the BIG 3 upgrade. Its been on my to-do list forever.
alternator , battery
