Battery drain caused by alternator exciter plug - JeepForum.com
post #1 of 10 Old 07-12-2020, 02:48 PM Thread Starter
Wassabi
Troubleshooting a parasitic battery drain. I found out I was getting a 4 amp drain from somewhere. I finally found when I unplug the exciter cable from the alternator the drain goes to 0. Anyone know how to troubleshoot this exciter cable? I attached a photo of the plug I detached from the alternator that was causing the drain when plugged in.
Wassabi is offline
post #2 of 10 Old 07-12-2020, 03:19 PM
jtec
jtec's Avatar
2014 JK Wrangler
likely bad diodes in the Alt.
I see you have a DVOM - google 'how to check alt diodes' there will be some youtube tutorials to help - easy fast to check... let us know
next I would be checking at the regulator - external if applicable.
jtec is offline
post #3 of 10 Old 07-12-2020, 03:32 PM Thread Starter
Wassabi
I did diode test by unplugging the exciter plug and the power cable at the rear of the alternator. I put positive lead of multimeter on alternator casing and read voltage and then reversed the leads. According to the you tube videos one of the readings will show about .500 and the other should be 0. Which tests to make sure voltage only goes in one direction which is the purpose of the diodes. And it seems ok.
Wassabi is offline
post #4 of 10 Old 07-12-2020, 03:38 PM Thread Starter
Wassabi
Correction , red test lead on alternator casing and black test lead on rear of alternator where power cable was connected. Then reversed test.
Wassabi is offline
post #5 of 10 Old 07-12-2020, 03:40 PM
jtec
jtec's Avatar
2014 JK Wrangler
what year jeep?
jtec is offline
post #6 of 10 Old 07-12-2020, 03:48 PM Thread Starter
Wassabi
1990 yj
Wassabi is offline
post #7 of 10 Old 07-12-2020, 03:49 PM Thread Starter
Wassabi
4.2 6 cylinder
Wassabi is offline
post #8 of 10 Old 07-13-2020, 12:18 AM Thread Starter
Wassabi
I think for a 1990 Jeep yj the voltage regulator is built into the alternator.
Wassabi is offline
post #9 of 10 Old 07-13-2020, 06:14 AM
fishadventure
fishadventure's Avatar
You can get an alternator shop to install a self-exciting module in most alternators.
I had to do that for a 1989 Grand Cherokee/AMC 360 I was working on that had a pesky battery drain.
It was cheap ($35 with labor?) and solved a 900mA I couldn’t find but unfortunately I got a lay-off notice before I could solve a remaining 65mA mystery.
[size=3]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
post #10 of 10 Old 07-15-2020, 03:37 PM Thread Starter
Wassabi
Looks like the voltage regulator in the alternator was bad. Replaced alternator and battery doesn’t drain anymore.
Wassabi is offline
