Bad Wheel Bearing?? - JeepForum.com
post #1 of 12 Old 07-02-2020, 06:00 PM Thread Starter
Johndj32
Bad Wheel Bearing??
Can a wheel bearing be bad and have no noise or vibration while driving?
I just replaced the front passenger axle seal on my Dana 30 through the CAD hole, what a PIA that was. I finally got it after 3 destroyed seals.
After putting the tire back on while it was still on jack stands, I noticed that the tire has a wobble. Almost like the lug nuts are not tightened. It wiggles in all directions. My first thought was ball joints, but they are tight and it is not the whole knuckle that is moving but just the axle itself. I thought maybe the nut was loose, but it is tight. I'm afraid to over tighten it so I left it where it was. When I drive it, there is no wobble or vibration that I can feel. When the jeep is sitting on the tire I cannot wiggle the tire at all.
I guess I don't really know what to think. It does not make any noise around corners like most bearings that I have experience with being bad. I'm afraid that if I just leave it, the seal may go out again.
Anyone have any suggestions?
Johndj32 is offline
post #2 of 12 Old 07-02-2020, 06:07 PM
Louie4
Louie4's Avatar
1935 CJ2A
Bad Wheel Bearing??
Sounds like a bad wheel bearing. I went through a many when I had a D30. Most never made noise just had wobble/movement. I assume you jacked up one wheel and moved it back and forth?
Sent from my iPhone using Tapatalk
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #3 of 12 Old 07-02-2020, 06:20 PM Thread Starter
Johndj32
Yes I had it on a jack stand under the frame, only one tire off the ground. After I installed the tire, I wiggled the tire and to my surprise it wiggled. It seems like a bearing, but I have had a couple go out on a RAM I used to own and they always made noise when turning. Weird.
Is there any way to check it for sure?
Johndj32 is offline
post #4 of 12 Old 07-02-2020, 08:00 PM
Louie4
Louie4's Avatar
1935 CJ2A
Bad Wheel Bearing??
Pull the unit hub bearing off and spin it. Or just pull it the rotor off and move It.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #5 of 12 Old 07-05-2020, 04:35 PM
Boojo35
1987 YJ Wrangler
It sounds like your wheel to hub surfaces are rusted and your wheel did not really draw on the hub all the way, thus you still have a loose wheel. Your axle nut is not torqued properly which does not keep your wheel bearing together properly. The axle nut torque is pretty damn tight. It holds the bearing together. Your bearing is really bad and just not noisy yet. It can happen. Or your bearing hung up on tightening into the C or knuckle on assembly and is loose. Or, you missed another loose front end part. A drag link, tie rod end. etc. If you can wiggle it, you should be able to see where it really moves. It may take a friend to help you.
If you cannot fix it with a hammer then it has to be an electrical problem.
Boojo35 is offline
post #6 of 12 Old 07-07-2020, 03:48 PM Thread Starter
Johndj32
With the tire on, only the tire and drive shaft itself wiggle, I can't see anything else moving. When I take the tire off, only the part of the hub that has the lugs on it and the driveshaft wiggles.
I think it has to be the bearing so I ordered a new hub assembly. I just have not ever had one go out without it making noise.
Johndj32 is offline
post #7 of 12 Old 07-08-2020, 10:29 AM
Louie4
Louie4's Avatar
1935 CJ2A
None of my bad ones made noises. Just had play in the bearing.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #8 of 12 Old 07-08-2020, 03:53 PM Thread Starter
Johndj32
Thanks, I'll change it. It was my first instinct, glad to hear sometimes they don't make noise.
Johndj32 is offline
post #9 of 12 Old 07-09-2020, 04:48 AM
fishadventure
fishadventure's Avatar
If the stub axle shaft wiggles it is the wheel bearing.
Don’t just tighten the nut after you get the new bearing in: torque it properly.
The nut torque actually insures (assures?) the one- or two-ten-thousandths of grease/debris get taken up so the only the bearing preload has potential/eventual movement.
[size=3]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
post #10 of 12 Old 07-09-2020, 05:35 PM Thread Starter
Johndj32
Will do. Do you know the torque specks off the top of your head? No biggie if you don't, I'll just look it up. Thanks again for the help.
Johndj32 is offline
post #11 of 12 Old 07-10-2020, 06:40 AM
fishadventure
post #12 of 12 Old 07-11-2020, 10:03 AM
bruinjeeper
bruinjeeper's Avatar
while you were in there that deep, it is never a terrible idea to change out the ball joints/u joints at the wheels if you dont know or cant recall when they were last done.
~YJOTM MAY '16, JULY '19~
bruinjeeper is offline
