Axle gear for 33” tires - Page 2 - JeepForum.com
 19Likes
post #16 of 35 Old 06-04-2018, 01:51 PM Thread Starter
Hardhead69
Originally Posted by timatoe View Post
Call a shop and get a quote on doing a re-gear.
Just decided to do the regear to 4.10 thanks!
Hardhead69 is offline
post #17 of 35 Old 06-04-2018, 04:17 PM
Chrisnvegas
Chrisnvegas's Avatar
Use the Grim Jeeper gear and axle calculator to help decide what will work for you.
http://www.grimmjeeper.com/gears.html
You plug in your numbers and it will calculate your RPM at a given speed in a certain gear.
A Law repugnant to the Constitution is void. Marbury vs. Madison 1803 I'm talking to you, Virginia...
Chrisnvegas is offline
post #18 of 35 Old 06-04-2018, 04:22 PM
fishadventure
fishadventure's Avatar
Originally Posted by Waternut View Post
I sold my rear D35 for $250 and a lot of junkyards sell axles for more than that so $400 for both is super cheap
That’s sorta funny. I’ve got 4.10 D35 and D30 on Craigslist right now for $300 for the pair and everyone is trying to talk me down. Just last night I told someone I’d do $275 and he texted back at like 3AM and said he’d “have to pass” whatever that meant. Good luck on buying ‘em cheaper is all I can say.
Regearing two axles is like $1200+ minimum, isn’t it?
[size=“3”]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
post #19 of 35 Old 06-04-2018, 05:36 PM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
Cool! I have a 76 to 1 crawl ratio in 1st gear 4lo.
Chrisnvegas and fishadventure like this.
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline
post #20 of 35 Old 06-04-2018, 06:11 PM
shaggyjim
NARF!
shaggyjim's Avatar
Your doing it wrong my friend.... Pull your add and relist them for $600 and let them "talk" you down to three.
Jim...
SGT USMC.
......YJOTM June 18......
shaggyjim is offline
post #21 of 35 Old 06-04-2018, 06:34 PM
Chrisnvegas
I paid 250 bucks for a nice clean set that had newish brakes.
I replaced all our axles to the older non c-clip.
If I break an axle, don't need the hassle of rigging up a log sled to drag my jeep home.
I HATE c-clip axles.
Even when I finally go to an 8.8, will need the c-clip removal kit.
c-clips are for Miata's not jeeps.
mickcollinsb16b likes this.
post #22 of 35 Old 06-04-2018, 06:39 PM Thread Starter
Hardhead69
The parts are $650. I can do the regear myself, i have a shop with seven mechanics. Rather have the new internals then spend $400 on 25 year old axles
post #23 of 35 Old 06-04-2018, 06:51 PM
Chrisnvegas
I'd be looking to scrap the axles you have and find an older set of non c-clip at the very least.
The older axles are semi-floating and are bolted in and somewhat held in by the axle bearing.
What that means is if you break an axle, chances are you'll make it off the trail with all 4 wheels still under your jeep.
With the c-clip axle, if it breaks, the axle WILL walk right the hell out from under you.
My axles are from an 87'
post #24 of 35 Old 06-04-2018, 09:46 PM Thread Starter
Hardhead69
Yeah i will look into that
post #25 of 35 Old 06-04-2018, 11:43 PM Thread Starter
Hardhead69
Here is a picture of my yj before i switched out the tires. Going to throw the soft top on her and got to paint the half doors i bought.
Sent from my iPad using Tapatalk
bruinjeeper likes this.
post #26 of 35 Old 06-04-2018, 11:56 PM
RockWoRM
RockWoRM's Avatar
Well, I can tell you from experience if you do the 4.56/33's you will essentially have a 3 sp. You will shift 1st, 3rd, 5th. But it really helps in low range!
However, everyone 'says' they will only go 33's. If you gear to 4.56 you can still run 35's at just a tad under stock ratio.
Of course the down side to that is... I would never run 35's on a turdy 5!!
shaggyjim and mickcollinsb16b like this.
'05 LJR, 6sp, RC long arm w/MC 6" coils, 5.13 D44's w/chromo shafts, MetalCloak fenders/sliders/body armor, 37x12.50 MTR's, Warn 9.5, RockHard swing out w/full spare. <><
RockWoRM is offline
post #27 of 35 Old 06-05-2018, 07:25 AM
fishadventure
Here is a picture of my yj before i switched out the tires. Going to throw the soft top on her and got to paint the half doors i bought.Sent from my iPadCrap using Tuppertalk
Nice jeep.
post #28 of 35 Old 06-05-2018, 03:51 PM
Waternut
Waternut's Avatar
Don't do it. C clip eliminators in an 8.8 aren't really meant for the shear forces of abusive rock crawling that might actually break one of these axles. If you get the disc brake version of the 8.8, the disc brake rotors keep the wheels on if you snap one anyway. That or just get a ford 9"...
shaggyjim and Chrisnvegas like this.
Waternut is offline
post #29 of 35 Old 06-05-2018, 04:04 PM
timatoe
timatoe's Avatar
...Regearing two axles is like $1200+ minimum, isn’t it?
Yeah, that's why I said....
...I can do the regear myself, i have a shop with seven mechanics. ....
Should've started off with that information, that's a whole different situation.
timatoe is offline
post #30 of 35 Old 06-05-2018, 06:30 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Hopefully what he meant was he was going to swap to one of the copy-cat Super 88 kits.
If that's the case he has nothing to worry about.
Joe Dillard is offline
