Axle Breather Help - JeepForum.com
 3Likes
  • 2 Post By jbolty
  • 1 Post By shaggyjim
post #1 of 8 Old 09-18-2021, 07:34 AM Thread Starter
Towny72
Axle Breather Help
Next problem popped up the other day.
Went to remove the breather fitting on my D30 before sending to the blaster and it cracked in half. I put a dowel on the end from inside the pumpkin and one hit with a hammer and pow!
I have come across a few threads, OEM fitting long discontinued, then a JK part that would have been a upgrade, discontinued for about a year now.
So anybody with a suggestion on what/how to get my axle breathing again
Socialism gave us the Yugo, I'll pass!
Towny72 is offline
post #2 of 8 Old 09-18-2021, 08:21 AM
93YJ4FUN
93YJ4FUN is offline
post #3 of 8 Old 09-18-2021, 08:43 AM
jbolty
Administrator
jbolty's Avatar
I threaded mine and screwed in a regular barb fitting.
timatoe and shaggyjim like this.
jbolty is offline
post #4 of 8 Old 09-18-2021, 12:38 PM
devildog80
devildog80's Avatar
1981 CJ5
Get a small engine fuel filter, and will keep the bugs out.
This one runs about $5.50 on Amazon, but can be found cheaper and size like you want at most FLAPS/Small Engine Shops.
Edit myself......read it again and realized the problem is to fix the fitting on the axle, not at the top end of the hose. Oh well, this filter will work on the top end
devildog80 is offline
post #5 of 8 Old 09-18-2021, 03:16 PM
shaggyjim
I did what jbolty did when I installed my ARB. I wanted to use the breather hole for my airline so I drilled and tapped the diff for a new breather fitting.
timatoe likes this.
shaggyjim is offline
post #6 of 8 Old 09-18-2021, 08:19 PM Thread Starter
Towny72
Not a bad idea
Towny72 is offline
post #7 of 8 Old 09-19-2021, 07:24 PM
bruinjeeper
Moderation in Moderation
bruinjeeper's Avatar
why would you put this filter at the end of a vent hose? Not trying to sound like an @$$, i'm legitimately curious.
~YJOTM MAY '16, JULY '19~
bruinjeeper is offline
post #8 of 8 Old 09-20-2021, 05:36 AM
fishadventure
fishadventure's Avatar
to keep dust and bugs and dirt and stuff out. The factory ‘valve’ fitting sorta does that preventative but not really but it probably does better at stopping water.
[size=“3”]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
