AX-15 Grinding - JeepForum.com
 6Likes
post #1 of 19 Old 10-06-2019, 12:28 PM Thread Starter
Awesome
Awesome's Avatar
AX-15 Grinding
Normally I wouldn't start a new thread for this, but maybe it will help other people too.
Recently, when I put the Jeep in reverse the transmission will sometimes make a whirring or light grinding noise. If I take it out of gear, the noise will continue unless I let off the clutch.
Only happens in reverse.
I'm guessing that my clutch probably isn't disengaging all the way. Any other guesses?
The 4th 5-seater YJ in the world.
Awesome is offline
post #2 of 19 Old 10-06-2019, 12:34 PM
letitloose06
letitloose06's Avatar
It it was an issue with the clutch, I would suspect you would hear the noise in forward gears as well. Maybe sometime in the reverse shift fork/linkage is worn causing the reverse to not fully engage/disengage?
I'm assuming this noise is in addition to the normal gear noise in reverse?
1992 YJ 4.0L, AX-15, 4" RE Standard Lift, 35x12.5R15 Maxxis Bighorn MT's, Grizzly Locked 8.8 Rear, HP44 with Spartan, 4.10's, Smittybilt Armor, JCR Off road Stage 2 Front Bumper, Custom Rear Bumper
1966 M416 1/4 Ton Cargo Trailer --
1951 CJ3A Restomod Project
letitloose06 is offline
post #3 of 19 Old 10-06-2019, 04:45 PM Thread Starter
Awesome
Awesome's Avatar
Yes. It's like a spinning whirring/grinding sound, and it happens when I'm not moving. The clutch pedal is on the floor.
Awesome is offline
post #4 of 19 Old 10-08-2019, 08:17 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
Hi Awesome,
We're sorry to hear about your experience. I understand you are reaching out to your fellow forum members for advice. However, should you be unable to remedy this on your own and decide to visit your dealer, feel free to send us a private message. We would be happy to add assistance if needed.
Alex
Jeep Cares
JeepCares is online now
post #5 of 19 Old 10-08-2019, 12:45 PM
bruinjeeper
bruinjeeper's Avatar
Hi Awesome,
Alex
Jeep Cares
Whoa.
That was such a pleasantly worded message it was almost creepy.
93YJfalcon, Awesome and sptrmike like this.
Stop whining about the 'ride' - If your YJ ain't wrangling your soul free, then might I suggest you buy a stationwagon... at least you can fit all your bull**** in the back.
~YJOTM MAY '16~
~YJOTM JULY '19~
bruinjeeper is offline
post #6 of 19 Old 10-08-2019, 05:07 PM Thread Starter
Awesome
Awesome's Avatar
I mean, like, cool. Jeep is doing marketing.
But in the YJ section? For 25-35-year-old Jeeps?
bruinjeeper and mikewiz38 like this.
Awesome is offline
post #7 of 19 Old 10-09-2019, 07:35 AM
Siva283
Siva283's Avatar
Pretty sure if the dealer saw most of our Jeeps that wouldnt know what to do. Especially with some of these newer parts swappers. But how is the dealer gonna feel about a Jeep with very little jeep left.
Awesome likes this.
Ask me how I know...
Siva283 is offline
post #8 of 19 Old 10-09-2019, 11:44 PM
80cj
80cj's Avatar
1980 CJ5
Clutch release bearing? It rotates when the clutch pedal is depressed and should not rotate when the pedal is not depressed.
80cj is offline
post #9 of 19 Old 10-10-2019, 07:03 AM
letitloose06
This isn't always true. In the YJ setup, the clutch release bearing has a small amount of preload on it when the clutch is released, so it is in fact always spinning.
post #10 of 19 Old 10-10-2019, 12:33 PM
mark1305
mark1305's Avatar
You could drain and replace the transmission fluid to see what drains out and determine its possible a synchro has disintegrated. DAMHIK - actually, when I did all my fluids after buying my 89 with the AX-15, all the synchros drained out as shiny brass flakes. I'm now very proficient at double clutching and timing the different shifts.
Could be something totally unrelated, but draining the fluid could provide a telltale. Either synchro chips or shiny flakes from bearings.
mark1305 is offline
post #11 of 19 Old 10-10-2019, 05:21 PM
Boojo35
1987 YJ Wrangler
Currently working in a Chrysler Dodge Jeep Ram Fiat dealer. I wish people would bring in YJ's for repair rather than JK's and JL's.
Theoretically, nothing inside the transmission is moving under the circumstance you describe. The trans should be mechanically locked from the input all the way to the output shaft. With the pedal to the floor the only thing that is moving is the flywheel, pressure plate and release bearing. The direction of rotation of these does not change regardless of forward or reverse. The clutch disc may be binding on the input shaft splines of the trans but once again, forward or reverse theoretically should matter. The clutch always spins in the same direction. Maybe your shifter or boot is making contact at the floor board area and transmitting noise??? What really does not make sense at all though that the noise continues after you take it out of gear. That eliminates the shifter.
Reverse is usually not a synchronized gear. JS.
This type of stuff usually requires a chassis ear or a mechanics stethoscope but even those can transmit noises up and down the driveline and still make diagnosis difficult. I frequently use a piece of rubber fuel hose and put one end directly up to my ear hole and scan the area with the other end. It is very effective at isolating the area of a noise. It really helps to put an ear plug in the other ear.
If you cannot fix it with a hammer then it has to be an electrical problem.
Boojo35 is offline
post #12 of 19 Old 10-10-2019, 07:05 PM Thread Starter
Awesome
Awesome's Avatar
Well I drove the Jeep for two days and it didn't happen again. It's really super random. Next time it happens I'll see if I can get a video of it or something. Draining the fluid is probably a good idea just 'cause. I haven't replaced the fluid in ...... years.
Awesome is offline
post #13 of 19 Old 10-11-2019, 06:30 AM
Siva283
Siva283's Avatar
Check your bell housing bolt torque. When I bought my jeep it would do that anytime i hit the clutch. It started out random and got more and more often slowly. Turns out 2 bolts in the bell housing were gone and several others loose. When you hit the clutch one side of the transmission would actually pull away from the engine a quarter inch and it made a noice similair to want you described. Might be worth a check only takes 5 minutes.
Siva283 is offline
post #14 of 19 Old 10-11-2019, 06:32 AM
Siva283
Siva283's Avatar
Part of that was just me being a smart ***. your also not a parts swapper and actually do diagnosis. That seems to be a lost art on most not all but most of the new guys.
Siva283 is offline
post #15 of 19 Old 10-11-2019, 06:59 AM
gutthans
gutthans's Avatar
My two previous clutch replacements both had a very similar description. Reverse began a light 'grind' about 2 weeks before 1st gear had engagement problems, in each case. Disassembly revealed a worn-down disc, and possibly sticky release bearing. Ergo, I can NOT state which was the definitive cause.
As Boo pointed out, a length of rubber hose ( fuel, heater, or garden type) can be a good tool for isolating the approximate area of conflict. However, with a worn disc, visual inspection is required because the manifestation will occur in the gears (which are NOT the problem).
Check externally as suggested for obvious culprits. If you do drain fluid make certain to replace with a GL-3 or GL-4. The MOPAR manual misprinted GL-5 for the AX15, which will actually eat the brass synchro rings up. I have only found GL-3 on the internet but did discover that GL-4 is 'safe-rated and widely available in stores. Personally, I have gone with Pennzoil Synchromesh fluid and find that excellent in the transmission and transfer case.
gutthans is offline
