auto column gear indicator - Page 2 - JeepForum.com
post #16 of 21 Old 04-12-2009, 05:11 PM
Krochus
MY van is an 84 of course you'll need a unit from a 3 spd tranny but those are just as common. GM used this same style van from the mid 70's to the late 90's
Think Green recycle your YJ's sway and trac bars today!
Originally Posted by buickgnx88 View Post
"Jeep Wave threads, it's a newb thing, you wouldn't understand!"
Krochus is offline
post #17 of 21 Old 04-12-2009, 05:47 PM Thread Starter
oldfrt47
1987 YJ Wrangler
That looks very similar to the jeep!! Now I gotta find one.
Thanks for the pic.
"Never sweat the petty things and never pet the sweaty things."
'10 Camaro RS
'02 Liberty (wife's ride)
'06 Mini Cooper S (wife's other ride)
'98 GMC Sonoma (great little truck)
'69 Firebird (project never started--too car poor)
oldfrt47 is offline
post #18 of 21 Old 04-12-2009, 06:20 PM
Krochus
Thanks for the pic.
They should both be Saginaw columns, I wouldn't be a bit surprised if they used the exact same part
Krochus is offline
post #19 of 21 Old 04-12-2009, 06:21 PM
ChicagoYJ
Yes, I Understand!
ChicagoYJ's Avatar
oldfrt47 I had the same problem. Mines had the tabs busted.
Go to the junk yard and pull one off any old Chevy van or pick up.
That's what I did. I actually took it off a van.
Only thing with mine is that the indicator does not line up properly.
ChicagoYJ is offline
post #20 of 21 Old 04-12-2009, 06:23 PM
dodger889
dodger889's Avatar
just get a piece of wood shape it to what you want paint it day glow orange then you are all set.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #21 of 21 Old 06-06-2009, 08:44 AM Thread Starter
oldfrt47
1987 YJ Wrangler
SOLVED!! part numbers for auto column shifters
Finally got the stuff I needed to get the gear indicator on my 87 YJ replaced.Took a while as they were really hard to find in the parts book at the Chrysler place.Only reason the parts guy took so much trouble was cuz I brought my gorgeous wife with me!
There are 3 basic pieces needed; The shift indicator is the square-ish thing that fits behind the lens and has an orange tip to indicate which gear you're in. It's part number is 52003154. It fits into a square plastic box that attaches to the plastic collar that moves with the shfit lever.There is a square hole for it behind the indicator. It's part number is
83502571. That attaches to the aforementioned square hole using a clip that slides on the the collar and the little square box fits onto the clip. The clip's part number is 83502572.
The list states that it's for a 92 YJ but the parts I'm needing are the same.Hope this helps.
I will attach pics of the blow up diagram and parts list if someone will explain to me how to do it. It asks for a URL and I don't know how to go from there I just have the pics on my desktop. I'm just too old to figure out all this new fangled stuff!
'10 Camaro RS
oldfrt47 is offline
auto gear indicator light stays on speepdaedeesi YJ Wrangler Technical Forum 2 04-12-2009 04:31 PM
Positional gear shift on steering column Austin83 YJ Wrangler Technical Forum 3 02-03-2009 09:19 PM
42rle gear selector indicator off by one gear TJDaveX TJ Wrangler Technical Forum 4 03-22-2008 08:22 PM
Stock auto slider gear indicator? Deezul TJ Wrangler Technical Forum 3 11-28-2006 05:41 PM
Adjusting indicator on auto trans shifter? TravisB TJ Wrangler Technical Forum 8 08-31-2005 07:17 PM
