August 2018 YJOTM - VOTE NOW!! - JeepForum.com
View Poll Results: Who is your AUGUST 2018 YJOTM ELECT!?
janesy86 11 33.33%
bpounds 7 21.21%
daddyjeep87 4 12.12%
DirectMatrix 4 12.12%
CWBreeding 3 9.09%
paulhead 1 3.03%
BeepBeep_420 2 6.06%
SquareLamps 1 3.03%
Voters: 33. You may not vote on this poll
 15Likes
Closed Thread
post #1 of 40 Old 08-26-2018, 07:57 PM Thread Starter
bruinjeeper
bruinjeeper's Avatar
Up for grabs - bragging rights for August 2018 YJOTM and $200 gift cert. from Qtec. REMINDER: All YJOTM winners are automatically entered for the chance at being voted for the illustrious title of YJOTY as well as inclusion on the /f12 Calendar (tentatively at this point on the latter note). Let's Git'r DONE!
***1st rule of YJOTM is you do not vote for yourself. 2nd rule of YJOTM is you DO NOT VOTE FOR YOURSELF. 3rd rule? do NOT solicit votes from outside. Investigations have been held, and people have been disqualified. Just don't do it*** Having a good time is what it's all about! Good luck to all!
Username: janesy86
1995 Jeep Wrangler
Drivetrain Specs:
~ 4.7L Stroker, 24lb Mustang injectors, cold air intake
~ Dana 300 tcase w/ 4:1, 32 spline input/output, twinsticked
~ Chevy D60 front, 4.56 gears, Detroit locker, chromo shafts, Yukon lockouts
~ Chevy 14 bolt rear, 4.56 gears, Detroit locker, lightly shaved/trussed
~ NV4500 w/ 6.34 low first gear
Suspension/Steering/Brake/Tire Modifications:
~ 57" offset front leaves, 2" BDS front springs in rear (stretched to around 100" wheelbase)
~ WFO springless high steer behind axle w/ PSC hydro assist
~ Wristed anti-wrap bar tied in to tcase skid
~ Late model e-brake disc brake conversion
~ 40" Procomp MT2's
~ Battle Born 4x4 beadlocks
Armor:
~ Corner guards
~ Rock sliders
~ Barnes 4wd tcase skid
~ Custom diff covers F&R
~ Custom front bumper w/ grille hoop
~ Custom cage tied into frame
~ Poison Spyder fenders
~ Barnes 4wd rear bumper plate
Misc.:
~ Warn winch w/ synthetic rope
~ 12 Volt Guy in-cab winch control
~ Corbeau Suspension Seats F&R w/ 4 pt. harnesses
~ York OBA
~ Truck-Lite headlights
~ CJ-7 tailgate
~ Competition 10" LED light bar
With my LJ leaving the stable this past year, me being a "Jeep Addict", I couldn't not have a Jeep to my name. So I picked up a built YJ off a local buddy, as I didn’t have the time to get the LJ a bit more built to handle the wheeling I’m into. Over the past 8 months I have tweaked it a bit to make it "mine".
This rig should suit me very well with what I want in a rig and so far it has. I'm sure down the line it will go under the knife, linked & whatnot, but nothing too major for the foreseeable future. Just get out and wheel!
NF7 by Nick Janes, on Flickr
FnF4 by Nick Janes, on Flickr
yj1 by Nick Janes, on Flickr
YJ3 by Nick Janes, on Flickr
Username: bpounds
1988 YJ
Original 4.2L
Howell TBI fuel injection
CRT HEI ignition
Retro-fit AX-15 with external slave
Advanced Adapters SYE
True neutral TC mode shifter
Adams rear DC driveshaft
Brown Dog motor mounts
Zone 2" lift
1/2" shackle lift
Dirtworx rear bumper and tire carrier
Warn M8274 Winch
LED front fogs
LED rear backup lamp
22" light bar on custom mounts
Late model TJ side mirrors
Custom mirror relocation
Username: DaddyJeep87
-1987 YJ
-Specifications and modifications
From the ground up...
35x12.50 Cooper STT's on cheap steelies
Late 70's ford radius arm Dana44
-extended radius arms and Ballistic Joint on the frame end
-4.56 gears
-Detroit True Trac
Late 70's ford 9"
-disk brake conversion
-4 linked
-4.56 gears
-Detroit Locker
Custom built suspension, 5" or so higher than stock
-ADS 16" travel Nitrogen shocks all the way around
-Ballistic Fab shock hoops front and rear
-Rear lower links are 2"-1/4" wall DOM with Ballistic Joints on both ends
-Rear upper links are 1 1/2"-1/4" wall DOM with Ballistic Joints on both ends
-Wheel base stretched to 102"
Steering box moved forward 2"
Astro Pitman arm
High steer
ADS fuel cell behind the rear seat
Modified family style cage that is tied in to the rear shock hoops
Rear bumper built off of the frame with receiver hitch
Front bumper build out of 1/4" plate with integrated winch mount and Ballistic Fab D-ring mounts
Front fenders built out of 1 3/4"-.120" wall square tubing and 14 ga. plate
Trail Tubes stinger welded to front bumper and bolted to front fenders
Quadratec Q9500i winch
3/16" rocker guards bolted to the tub
'95 ish 5.7 TBI engine - stock, but cleaned up to look nice
'79 Turbo 350
'95 NP241C with ORD SYE kit
Custom built adapter from TH350 to NP241 (not complete yet)
Novak T-case shifter with XJ lever
Champion aluminum radiator
Optima red top
Custom built battery box
Home built drive shafts
Custom Krylon paint complete with old school hot rod flames. This was modeled after the Muscle Machines toy Jeeps if anyone remembers them
-Brief history of your jeep and how it came to be. (optional)
I originally bought this jeep in February of 1999. It ran like crap due to the stock carb, but that was soon replaced with a Holley 2 barrel. I put on a 4" Rough Country lift and some 31" BFG MT's and ran it like that for a lot of years. It eventually got a Howell TBI upgrade. After the frame rusted out and the tranny died it slowly got build into what it is today. I had a 5.2 rebuilt by my local VoTech school, but that didn't work out so well. I am now finishing up my GM drive train swap. Somewhere around 2001 is when It picked up the DaddyJeep name. My oldest son would hear me coming home from work and run to the door and say "daddyJeep" so it kind of stuck.
Username: DirectMatrix
1992 YJ
jeep name: Delilah
Its a long story, but the used car dealer that sold it to me wanted $4999, which would come with a "new" engine because the old one was "broken". I offered him $2000 without a new engine and he agreed. Even threw in a free flatbed tow back to my house. I had the "broken" engine running inside of 3 hours. Fuel issue. It ended up running for a few years before a valve broke off and it did need an engine, but that's another story.
I don't really consider this a build in the traditional offroading sense. More of a cascade and torrent of mods centered around fun projects I want to tackle, or have tackled, to make my YJ exactly the way I want it and learn a bunch of things along the way. I'm all about fit and finish that makes the Jeep appear mostly stock.
As she sits currently, she has the rebuilt 2.5L engine with about 40,000 miles on it and the majority of the Jeep is stock. All work was done by me, mostly with inspiration from things I found on JF. Upgraded items include:
Westlake SL369 - 31x10.50R15LT 109Q tires
complete overhaul of the fluids, suspension bushings and steering components
Chevy Tahoe overhead console/switch panel DIY
Ford Explorer front seats
Nissan Pathfinder tire carrier modified to fit
DIY fabricated drop down tailgate from Ford Econoline rear door hinges
aftermarket hood assist kit
Hidden Hitch towbar
DIY dual battery kit with fabricated battery tray
stainless brake lines throughout DIY bent myself
15>20 gallon fuel tank mod
4.0L throttle body mod
new mirror relocation brackets fabricated from a Mitsubishi Montero
handbrake mod from a ZJ
Gentex temp/compass dimmable rear view mirror from a Saturn View
Mishimoto electric fan
130amp Denso alternator upgrade plus DIY big 3 cable upgrade
Brown Dog motor mounts to keep those 4 pesky squirrels in place and under control.
Upcoming projects include:
Restore CJ hardtop
Restore fiberglass hard doors
finish wiring overhead console
finish installing Ford Explorer split fold rear seats
DIY lizardskin/monstaliner on the interior
I'm very close to getting her to be my garage-kept project car, rather than my daily driver and then I can really get to work!
Days after I brought her home. The starting point in other words.
Playing around in a rare southern VA snowstorm.
Still looking pretty stock
A few months ago, after I got the Rampage top mostly fitted.
Username: CWBreeding
1995 Jeep Wrangler YJ
Specifications and Modifications:
Drivetrain
-2.5L
-HPD30 front, Ford 8.8 rear, geared to 4.88
-ARB Air lockers front and rear
-AA SYE kit, Tom Woods CV driveshaft
-35" Goodyear Wrangler MT/R's w/ Kevlar
Suspension/Steering
-Power steering conversion and PS gearbox from a Dodge Durango with M.O.R.E. Steering box stabilizer bracket
-Rusty's Offroad heavy duty tie-rod and drag link
-4" Rubicon Express suspension lift with single leaf removed from each pack (decreases spring rate, improves ride quality, and gives lift of ~2.5-3"), 5/8" lift boomerang shackles rear, 2" body lift
Interior
-Bedlined tub
-Corbeau Baja SS bucket seats
-Tuffy center console
-Polk audio speakers in a floor mount speaker pod
Recovery
-Warn M8274 built in 1976 that I rebuilt as a summer project
Miscellaneous
-Poison Spyder DeFenders (steel)
-Smittybuilt bumpers front and rear
-TJ rear flares
-Ridgid Job Box for rear storage
-Cobra 75 WX/ST CB radio with Firestik Antenna
The Story:
I bought this Jeep when I was 15 and a freshman in high school, and it was bone stock. All the work that's been done to it has been done by me and my awesome dad, and it's how I learned the art of wrenchin'. The only exception to this would be the lockers that I just had a shop install due to time constraints and not having space to work at my apartment. Overall, it's been a long, slow build with lots of wheeling and a few broken parts thrown in the mix, and I wouldn't have it any other way.
Username: paulhead
1994 YJ
So I won YJOTM back in 2016 and thought I’d give it another shot. I’ve had a some new mods since then and believe I’m about “done” for now. Was thinking of doing a D44 in the front but I should have thought about that before investing (oxymoron, jeep, investment, HAHAHA!!) money into the D30 but I’m happy with where I’m at for now. Got back from beating the crap out of my rig at the Hammers a few months ago and I was impressed with my little beast.
Details are as follows:
94 YJ 4.0 3spd with trans cooler, Rustys motor mounts, Optima Redtop, '95 booster/MC upgrade
Transfer Case NV241OR (4:1) Rock Trac, Adams drive shafts front and rear
D30 , Yukon (Warn) hubs, Lockright, Beefy steering, Dynatrac u-bolt flip kit
Ford 8.8 w Yukon Grizzly locker, Superior Super 88 kit and Ruff Stuff spring under ubolt plates, 4.10 gearing
4” Zone springs,
35” General Grabber X3’s
Smitty winch, Hi lift, homemade 10lb CO2
Armor, Barnes 2" belly, Rustys dif covers, CCFAB
tube fenders, rockers
Cushy Grant steering wheel and Corbeau RS seats
Day 1 came with winch, 33" ATs and a 2" lift, stock everything else.
Final mode
Username: BeepBeep_420
1989 YJ
4.2 with Howell JP-1 TBI (Chevy TBI)
Team Rush Dizzy upgrade (Ford cap, unidentified upgrade coil)
Currently removing dead 2.5" springs and shocks (rear done, front this week), replacing with crown heavy duty springs (stock height), 5" shackles and Skyjacker BlackMax shocks.
15" Gambler wheels and 10.5x31" tires (and custom ride trimmed flares )
Had to drive 4 hours with an irate girlfriend to pick this up. My S-10 was destroyed when a huge Dodge Ram rammed me at 25 mph when I was stopped at a stoplight. That paid for this...
Been going through it troubleshooting alot of issues.
Tinted windows, installed stereo, kill switch, fuel lines, oil, plugs/wires/cap/rotor, diff fluid, tranny fluid, almost all sensors, lock cylinders, sway bar bushings and links, rear leafs, shackles and shocks (front this week), Hi-lift jack going on front bumper this week, fan clutch, master clutch cylinder, belts, vacuum leaks fixed, removed rear trackbar (front off this week), compression test wet/dry.
I think that covers most of what has been done. Still wanting to install a sound bar (only have passenger side speaker atm), console and possibly sound damping mats inside roof.
It's coming around though. Drives better and smoother than it did when I got it. Not a really impressive build but I have learned so much about Jeeps and auto mechanical issues in the last few months (I have done minor auto work on past cars).
Username: SquareLamps
1989 YJ
2.5L Low Output
AX-5
NP231J w/slip yoke elim
HP D30 w/ chromo shafts and Aussie Locker 5.13
Ford 8.8 w/Riddler Diff cover and welded tubes 5.13
4"RC with 5/8" shackles
33 x 12.5 Goodyear MTR 15" Pro comp D window Steelies
Superwinch X9 with remote under hood solenoids. Hi Lift jack, shackels, recovery straps
Smittybuilt SRC Front Bumper, Warn rock sliders, one off rear bumper/carrier
bucket race seats custom install
BeepBeep_420 likes this.
Stop whining about the 'ride' - If your YJ ain't wrangling your soul free, then might I suggest you buy a stationwagon... at least you can fit all your bull**** in the back.
~YJOTM MAY '16~
~YJOTM JULY '19~
bruinjeeper is offline
post #2 of 40 Old 08-26-2018, 08:06 PM Thread Starter
bruinjeeper
LOOK OVER YOUR CHOICES PEOPL, BUT PLEASE REFRAIN FROM VOTING - having a few technical issues.
@CWBreeding your image tags are (evidently) not working. Unsure why.
@paulhead two image tags are not working. Also unsure why.
*EDIT*: @paulhead fixed your tags by grabbing from your March entry.
@CWBreeding yours still are not working - i also noticed they are now missing from the March thread.
paulhead likes this.
~YJOTM MAY '16~
~YJOTM JULY '19~
post #3 of 40 Old 08-26-2018, 08:41 PM
paulhead
if it works fix it
paulhead's Avatar
weird, mine are going in and out still. THanx for putting it up! Frikin gnarly competition
Trying to weld has honed my grinding skills
paulhead is offline
post #4 of 40 Old 08-26-2018, 08:44 PM
Chrisnvegas
Chrisnvegas's Avatar
Wow, some sick machines.
(Sick is good, right?)
"Alferd Packer: “Stand up, you voracious, man-eating son of a *****, stand up! There was seven democrats in Hinsdale County and you up and ate five of them."
Chrisnvegas is offline
post #5 of 40 Old 08-27-2018, 02:19 AM
paulhead
if it works fix it
paulhead's Avatar
Just noticed this, we good yet?
paulhead is offline
post #6 of 40 Old 08-27-2018, 04:54 AM Thread Starter
bruinjeeper
ya. I suppose whoever wants to vote, can vote.
@CWBreeding ...plz get me your img links
~YJOTM MAY '16~
~YJOTM JULY '19~
post #7 of 40 Old 08-27-2018, 04:55 AM Thread Starter
bruinjeeper
apparently its not anymore. Sick is noe bad again... i believe the kids are using "disgusting" as a complimentary undertone these days. *shrugs and sighs*
Chrisnvegas likes this.
~YJOTM MAY '16~
~YJOTM JULY '19~
post #8 of 40 Old 08-27-2018, 05:26 AM
Stitch586
Stitch586's Avatar
Wow, some LIT machines.
FIFY...
Awesome and Chrisnvegas like this.
91 YJ 4.0/AX15/231J AA SYE/ Tom Woods CV
3.5" BDS Springs / .75" Booms / 1"BL
HP D30 /Akebono's /1 Ton GM Crossover Steering
Ford 8.8 / Trac loc LSD w/ disc brakes
35x12.5x16 Nitto Trail Grapplers
Walbro255 MetalCloaks
Kilo-Echo-8 * * *
Stitch586 is offline
post #9 of 40 Old 08-27-2018, 06:21 AM
jeep63
jeep63's Avatar
Agree! And, yes, sick is good (or so my 16yo son tells me!)
95 YJ-Sold
YJOTM 05/15,05/18
jeep63 is offline
post #10 of 40 Old 08-27-2018, 06:35 AM Thread Starter
bruinjeeper
This really is a bad @$$ group of rigs. A splash of everything.... Dirty, rough, finesse, class, simplicity/sophistication and strict adherence to direction.
Like i like my women
~YJOTM MAY '16~
~YJOTM JULY '19~
post #11 of 40 Old 08-27-2018, 06:58 AM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
CW's pics still aren't showing for me anyway. There's been real problems linking pics lately. Attachments are much more reliable. If you open a quote box, you can see there are pics for CW. But only you bruin, can edit the post.
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline
post #12 of 40 Old 08-27-2018, 07:55 AM
blynyrd66
Voted.
Good mix.
Wish CWBreeding's picks had shown up.
blynyrd66
1994 YJ, Heinz 57
1976CJ5, It's a bit of a mutt, too.
blynyrd66 is offline
post #13 of 40 Old 08-27-2018, 08:34 AM
Mr.B
Mr.B's Avatar
CwBreeding's pics.
Edit: If they don't show at least you can click on them.
Ham license:
Everyone is Welcome
Mr.B is offline
post #14 of 40 Old 08-27-2018, 10:38 AM
daddyjeep87
daddyjeep87's Avatar
1987 YJ Wrangler
I can see them. Thanks for getting them up here.
87 YJ, 5.7/TH350/NP241, Custom 4 link/ Radius Arms, ADS Nitrogen Shocks, 35" Cooper STT
Look for the YJ of The Month thread in the YJ Technical Forum. Vote for your favorite Jeeps.
YJOTM August 19
daddyjeep87 is offline
post #15 of 40 Old 08-27-2018, 10:39 AM
bobracing
Voted
All nice rigs.
92 YJ
https://www.jeepforum.com/forum/f22/open-mouth-insert-jeep-2878945/
bobracing is offline
Closed Thread
