Apocalypse links and bonus stretch. - Page 6 - JeepForum.com
 142Likes
post #76 of 249 Old 03-03-2021, 07:52 PM Thread Starter
shaggyjim
Set two.
63651007120__1D6E90E3-4895-4396-A3C3-3FB591F6A5D5.jpg   63651038673__728519F5-3E07-4C38-9085-8834366A1B50.jpg   63651182077__5B72B139-9CDF-4FD9-9782-1AC119722703.jpg   63651359876__6CDFCA66-8FE8-46DE-8790-4C76D80049FC.jpg
bruinjeeper likes this.
shaggyjim is offline
post #77 of 249 Old 03-05-2021, 04:27 PM Thread Starter
shaggyjim
So I scored a 1350 drive shaft from a buddy at work for the cost of getting it out of his shop and it looks sweet but sadly I don't have a flange for my slip yolk. Does anyone know the spline count of the super short slip yoke eliminator I might need to order a flange.
post #78 of 249 Old 03-05-2021, 07:28 PM Thread Starter
shaggyjim
I spent last evening and tonight carving up some lower shock mounts and I'm just about done. I should be able to get the shocks installed tomorrow.
post #79 of 249 Old 03-05-2021, 07:52 PM
RockWoRM
RockWoRM's Avatar
K. You've got me scratching my brain fart head on this one? Is the lower DL in the pic the 1350? And you need a flange? Is that right? What has that got to do with a slip yoke?
'05 LJR, 6sp, RC long arm w/MC 6" coils, 5.13 D44's w/chromo shafts, MetalCloak fenders/sliders/body armor, 37x12.50 MTR's, Warn 9.5, RockHard swing out w/full spare. <><
RockWoRM is offline
post #80 of 249 Old 03-05-2021, 08:13 PM Thread Starter
shaggyjim
Well both shafts are 1350 u joints on the end but mine is the lower one and is 1330's at the CV. the one I was given is 1350's at the cv with the flange on it. So what I was thinking is the shaft I was given is a better drive shaft with full splines and bigger u joints and might just be the correct length for my stretch I might as well get a flanged output for my super short SYE. I just have no idea what my output spline count is.
EDIT: Are you guys still going to make it to Moab this spring?
post #81 of 249 Old 03-05-2021, 08:58 PM
bruinjeeper
Moderation in Moderation
bruinjeeper's Avatar
i have a frying pan... it's kind of flangey... it might work for that yolk
32 spline rear output 231J (even though i'm not even sure which case you run currently)
shaggyjim likes this.
~YJOTM MAY '16, JULY '19~
bruinjeeper is offline
post #82 of 249 Old 03-05-2021, 09:05 PM
bruinjeeper
beefy
post #83 of 249 Old 03-05-2021, 09:09 PM Thread Starter
shaggyjim
32 spline is great. Thank you Sir! Looks like a common flange so Ill put one on order tomorrow.
post #84 of 249 Old 03-05-2021, 09:17 PM
RockWoRM
RockWoRM's Avatar
K. Cool. Bruin beat me to it... 32 spline. And yeah, IMHO, the flange is stronger/better and adds length.
Absolutely on Moab. We have already made reservations @ Ken's Lake BLM campground. 20th thru the 30th of May. So if you can make a weekend, the 21, 21, 23'rd would be perfect. Or the whole week for that matter. I have to bug out the 29th.
RockWoRM is offline
post #85 of 249 Old 03-05-2021, 09:52 PM
timatoe
timatoe's Avatar
..... I might need to order a flange.
AA has a solution for that...
....EDIT: Are you guys still going to make it to Moab this spring?
Yeppers!! So ready!
timatoe is offline
post #86 of 249 Old 03-06-2021, 07:31 PM Thread Starter
shaggyjim
Well I went and started cutting up my frame today and fitting up the shock tower. I found a little binding in my lower shock mounts so I needed to work on that a little bit but I got the correct angle on the mounts and started installing. Everything was going great but I had some issues on the back of the tower because of the Barns cutout that I had to cut all the way out and replace with some 3/16's plate to get a firm weld to the top to the frame. I failed on the upper tower to frame weld spectacularly and then ran out of wire so Im going to have to clean it up and fix it tomorrow. All in all it was a great day.
63676394792__459ACB18-DF6E-4740-9E38-2DCD06B79C72.jpg   63676861330__E9AF9240-8076-4E11-A9B2-C6CB89C297E8.jpg
post #87 of 249 Old 03-06-2021, 08:27 PM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
It looks like it was answered, but I was going to say 32 spline. Also that looks like an f250 shaft which is 4.25 bolt circle and 2 pilot with m12x1.75 threads
YJUnlimited stretch, Links, SBC, Tons, Lockers, and stuff
March 2017 YJOTM/ 2017 YJOTY
87TPIYJ is offline
post #88 of 249 Old 03-06-2021, 09:22 PM
Waternut
Waternut's Avatar
I learned a year or so ago to buy welding wire online in two 10 lb rolls a time and have two C02 tanks on hand so I never run out at a bad time. The online wire usually costs about the same as two 2 lb rolls at the local welding store or big box store. My welds aren't as pretty as yours though so I wouldn't know if it's my machine, my technique, my gas, or my wire that causes my ugly welds but I'd wager on my technique/patience being the biggest problem by far...lol.
Waternut is offline
post #89 of 249 Old 03-07-2021, 07:50 AM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
We like to lift the body off the frame and remove the gas tank to be better able to reach that area for welding and multiple other access reasons along the way.
Like this:
We rake the tower towards the rear as well. Sometimes we dimple the tub or cut/patch the tub to allow for proper tower placement.
BTW: Are you planning on adding a swaybar/anti-rock back aft?
Joe Dillard is offline
post #90 of 249 Old 03-07-2021, 09:29 AM Thread Starter
shaggyjim
Originally Posted by 87TPIYJ View Post
It looks like it was answered, but I was going to say 32 spline. Also that looks like an f250 shaft which is 4.25” bolt circle and 2” pilot with m12x1.75” threads
Thats kind of what I was thinking when I got to looking at it and I well ask my buddy Monday at work to find out for sure. I hope it is, I can get ford parts nice and cheap form the dealer because my company does so much business with them.
I might look into that for the next round but I need something right now and Lows has a nice Veterans discount so I think I will pickup another spool there this time. Im still surprised how fast it went this time, I've had the same spool of wire in the old Weldpac 100 for like 15 years I at the speed I use flux core wire it most likely have the same wire in it when my son sells it at the estate sale on my passing. I have been working hard on patience and technique lately because aesthetics and I don't want @Awesome to be disappointed in me however the old saying "beauty is only skin deep, its what's inside that counts" is making me nervous after I finish each weld.
I probably should have lifted the body but I'm terrified of body mount bolts and I dont need another project just now with Moab coming up next month. I think I can just catch the back side if I sit up in the links. Ill find out today. So far I don't plan on a swaybar but it's not set in stone. I'm hoping the leaf springs hold it for the most part but when I link the front I might need to. This thing probably will never see the freeway again
