Air in gas tank - JeepForum.com
 2Likes
  • 1 Post By Boojo35
  • 1 Post By bhartwell59
post #1 of 14 Old 01-27-2020, 09:13 AM Thread Starter
bhartwell59
1987 YJ Wrangler
Air in gas tank
Hey all,
Have an '87 w/the Mopar FI kit (external fuel pump) installed.
Just replaced the fuel lines coming off the 20-gallon plastic gas tank sending unit. Also replaced the 2 vent valves on top of the tank. Hooked up the vent hoses to the T-fitting.
Went to fill my tank afterwards and had air come out (vs in) when I took the cap off. It's happened a couple of times since then.
I'm thinking there must a blockage upstream from the tank. Check the evap canister?
Thoughts?
Thanks!
4.2 '87 yj, 300,000+ miles, mopar mpi, 33" bfg mud KM2, skyjacker 4", 3.73 gears, arb lockers-f and r., tom wood's 2.07 sye conversion, tom wood's hd driveshaft, magnaflow cat/custom exhaust, 4wd rear bumper/swing-out tire carrier
bhartwell59 is offline
post #2 of 14 Old 01-27-2020, 04:06 PM
Awesome
Awesome's Avatar
Mine was doing that. Last time I had the Jeep on a lift I realized the return line was pinched between the tank and the body. I dropped the back of the tank and pushed the line back up on top of the tank. No idea if it's fixed yet, but it's something you might want to check.
The 4th 5-seater YJ in the world.
Awesome is offline
post #3 of 14 Old 01-27-2020, 04:20 PM Thread Starter
bhartwell59
1987 YJ Wrangler
just crawled underneath it and decided to see if the vent hoses were clear... from the rear to the evap: air going and coming. from the rear to the vent valves/hoses nothing. so i'm thinking a pinched vent hose.
i'll double-check the return line while i have the tank dropped a bit.
BTW-the air that escapes out is pretty major.
thanks!
post #4 of 14 Old 01-27-2020, 04:52 PM
Awesome
Awesome's Avatar
Mine was building pressure just sitting there. It was doing it all summer, but I was driving it more often then too. I don't drive it regularly.
Awesome is offline
post #5 of 14 Old 01-27-2020, 05:14 PM Thread Starter
bhartwell59
1987 YJ Wrangler
i would have thought the air building up would be a venting issue... how would the return line cause that?
post #6 of 14 Old 01-27-2020, 07:03 PM
Awesome
Awesome's Avatar
Awesome is offline
post #7 of 14 Old 01-27-2020, 08:11 PM
ayelander
ayelander's Avatar
I have the same thing going on. Cant figure it out. I just leave the gas cap loose. I can do that with the 350 CID.
93 CTYJ, 350 Chevy, SM465, NP 231J TC, Ford 8.8 Rear, D30 with Chromoly, 4" RE Spring lift, 5/8" Boom, 1" body lift, 35" MT's
ayelander is offline
post #8 of 14 Old 01-28-2020, 07:38 AM Thread Starter
bhartwell59
1987 YJ Wrangler
Ugh, all this because I needed to replace a cracked/leaking fuel hose.
I'll drop the tank a bit this weekend (again) and see what wonders await me.
post #9 of 14 Old 01-28-2020, 03:52 PM
Awesome
Awesome's Avatar
Yup, same. I replaced every fuel/vent hose except the two filler hoses. Afterward I was getting the tank pressure problem.
Awesome is offline
post #10 of 14 Old 01-28-2020, 05:20 PM
Boojo35
1987 YJ Wrangler
The YJ tank has two vents that vacuum hoses connect to and a tee that connects them and goes forward to the canister. The way that the vent hoses are connected and routed, it is very easy to crush them or pinch them between the crossember that the front of the tank bolts to. If the lines to these were replaced and a generous amount of hose was used for instance ( which is common, they will sit forward of their intended place).This will pinch them between the forward crossmember mounting the tank and the tank itself. It is real easy to see if you drop the tank. The second is where the tank lines are routed above that crossmember through a rubber locating grommet can be crushed by bad body mounts, etc.
timatoe likes this.
If you cannot fix it with a hammer then it has to be an electrical problem.
Boojo35 is online now
post #11 of 14 Old 01-28-2020, 05:58 PM Thread Starter
bhartwell59
1987 YJ Wrangler
That is precisely where I see my problem to be... that 3 hose holding "sandwich" between the crossmember and the tank. The rig runs so I know the fuel line is good and the return line went into that "sandwich" with little resistance.
It never occurred to me to check the vent line... and that's why I'm dropping the tank, partially, for the third time. Geez.
post #12 of 14 Old 01-28-2020, 09:05 PM
timatoe
timatoe's Avatar
I'd put money that it's pinched exactly like Boojo describe.
timatoe is online now
post #13 of 14 Old 02-02-2020, 08:00 AM Thread Starter
bhartwell59
1987 YJ Wrangler
Well, that was it... a folded over vent line going towards the front just past the T-fitting. Thanks all.
Back to our regularly scheduled program!
timatoe likes this.
post #14 of 14 Old 02-02-2020, 08:33 AM
Boojo35
1987 YJ Wrangler
Thanks for the report. Good to hear that it is fixed.
