air filter conversion on 4.0l engine swap - JeepForum.com
 2Likes
  • 2 Post By timatoe
post #1 of 8 Old 04-19-2018, 04:46 PM Thread Starter
sparton77
Hi I am trying to find info for converting my 88 jeep yj air cleaner assembly to the air filter housing on the later yj or TJ models. I am trying to finish a rebuild that someone else started so I have the air filter box but not the know how. Any help would be appreciated
Some background on my project - Its a 88 jeep yj originally had a 4.2l that was swapped to a 4.0l from a jeep grand Cherokee . Also swapped to a AX15 transmission.
sparton77 is offline
post #2 of 8 Old 04-20-2018, 07:10 PM
NHfireLJ
NHfireLJ's Avatar
Its nothing special.... Theres a tube from air filter box to throttle body
Picture here for reference... https://www.ebay.com/itm/Jeep-Wrangl...nd!03842!US!-1
AUDREY...95 YJ UNLIMITED LS
LUCY...2005 Unlimited "LJ" Rubicon Sahara #495
SOLD
BETTY...94, Stroker 4.6,35"s, SOLD
style intake
NHfireLJ is offline
post #3 of 8 Old 04-20-2018, 07:17 PM
Shadownwpa
Shadownwpa's Avatar
Get the tube that goes to the box from the throttle body, connect them all up, and use that to figure out where your air box bracket should be. Connect accordingly.
https://www.jeepforum.com/forum/f22/shadownwpa-91ish-yj-build-thread-1857154/
Shadownwpa is offline
post #4 of 8 Old 04-22-2018, 11:41 PM Thread Starter
sparton77
Ok cool thanks. My last concern would be if the fender is the same shape on the 88 vs the 91 YJ. Im concerned the bracket will not fit up properly to where the air cleaner box should fit on my fender. I dont have the bracket yet otherwise I would just check myself.
post #5 of 8 Old 04-23-2018, 06:42 AM
NHfireLJ
NHfireLJ's Avatar
Fenders are all the same
SOLD
style intake
NHfireLJ is offline
post #6 of 8 Old 04-23-2018, 08:04 AM
timatoe
timatoe's Avatar
You're starting off here...
Before long you'll forget about what stock bracket fits where etc and start building stuff that works for you....
Chrisnvegas and fishadventure like this.
timatoe is offline
post #7 of 8 Old 04-23-2018, 01:21 PM
fishadventure
fishadventure's Avatar
Originally Posted by timatoe
You're starting off here... Before long you'll forget about what stock bracket fits where etc and start building stuff that works for you....
[size=3]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
post #8 of 8 Old 04-24-2018, 05:45 PM
Shadownwpa
Shadownwpa's Avatar
Eh.. Simple mod. Once you find all the parts I think you'll probably need a decent hammer (you know... for adjustments), a few self tapping screws, and a drill motor to run them in with and you're good.
