95 yj rear shock mounts - JeepForum.com
 1Likes
  • 1 Post By Boojo35
post #1 of 7 Old 01-11-2020, 03:49 PM Thread Starter
Dpenna1217
My rear upper shock mounts are rusted out .. i have already replace and welded the passenger side.. the drive side has the fuel line filter in the way .. should i siphon our all the gas, take fuel filter out and have fuel pump bleed out rest of gas to weld ? What are my options ? Thank you !
Dpenna1217 is offline
post #2 of 7 Old 01-11-2020, 03:49 PM Thread Starter
Dpenna1217
I really do not want to take the fuel tank out
post #3 of 7 Old 01-14-2020, 01:18 PM
NHfireLJ
NHfireLJ's Avatar
I just loosened all the fuel lines from the frame and wedged them out of the way and wrapped / covered in welding cloth....
but you can just disconnect the filter and cap the lines , plastic wrap and tape and secure out of the way... the line from the tank, just raise higher than fuel level to keep gravity from drawing the fuel out.... extend that line if needed temporarily.
AUDREY...95 YJ UNLIMITED LS
LUCY...2005 Unlimited "LJ" Rubicon Sahara #495
SOLD
BETTY...94, Stroker 4.6,35"s, SOLD
style intake
NHfireLJ is offline
post #4 of 7 Old 01-14-2020, 01:24 PM
jbolty
jbolty's Avatar
what he said, plus cover everything in water soaked towels to grab any sparks
jbolty is offline
post #5 of 7 Old 01-15-2020, 08:12 AM
fishadventure
fishadventure's Avatar
I personally wouldn’t open any lines up.
Covered, sparks wont harm the exterior of lines and filter. But fuel vapors ( removing fuel filter) can still ignite.
I’d also cover the fuel tank with wet cotton toweling so spatter sparks can’t rest on top of fuel rank or anything like that.
[size=“3”]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
post #6 of 7 Old 01-15-2020, 10:54 AM Thread Starter
Dpenna1217
Thank you guys ..i appreciate it very much !
post #7 of 7 Old 01-17-2020, 08:29 PM
Boojo35
1987 YJ Wrangler
I would do a body off frame restoration and an LS engine swap and make the shock mount one of the little details to take care of while it is apart.
NHfireLJ likes this.
If you cannot fix it with a hammer then it has to be an electrical problem.
Boojo35 is offline
