95 YJ Junkyard Transfer case - JeepForum.com
 1Likes
  • 1 Post By Siva283
post #1 of 3 Old 10-13-2020, 09:27 PM Thread Starter
paulvon
I have a friend with a 95 YJ, 2.4L engine, with manual transmission.
He has a bad NP231 transfer case. The trans should be the AX15.
I have not seen any YJ in the salvage yard. There are a number of XJ, ZJ that I can pick from.
Jeep over the years has used different spline counts and shaft designs. What years and configurations would drop in easier?
Thanks
1997 ZJ 4.0 L - Upgraded to heavy 93 sway bar
2004 WJ 4.7 L - 2 1/2" lift
2011 KK 3.7 L
paulvon is offline
post #2 of 3 Old 10-14-2020, 12:48 AM
Chumley1080
Check Deadjeep.com. It's a Jeep salvage yard in RI. Lots of stuff.
I got an AX15 from them, Very happy with customer service.
Chumley1080 is offline
post #3 of 3 Old 10-14-2020, 06:13 AM
Siva283
Siva283's Avatar
Thanks
If he has the 4 cylinder it is a 2.5. If its the 2.5 he has the AX5 transmission. You can get a Tcase from the junkyard from many vehicles you will need to swap the input from the broken one to the good one
BrokeJeepJoe likes this.
Siva283 is offline
