'95 YJ Horn help... - JeepForum.com
post #1 of 3 Old 02-19-2018, 12:56 AM Thread Starter
JeepYJ44
'95 YJ Horn help...
The previous owner had swapped the factory horn for an air horn but it died recently and I decided to just replace it with an OEM one. Anyway, I'm a little bit confused regarding the ground, and the the +/- posts on the new horn I bought.
This one won't just plug and play with the factory harness since the air horn required them to splice into those wires.
I can hear the relay clicking but I'm not sure exactly what I'm missing here to finish things. I'll attach a few pictures of what I'm looking at, plus the new horn and what it came with.
Also, I noticed on some pictures the factory setup had 2 horns, which has me a bit confused too.
Any help would be appreciated.
IMG_20180218_214852529.jpg   IMG_20180218_214916919.jpg   IMG_20180218_214952685.jpg
JeepYJ44 is offline
post #2 of 3 Old 02-19-2018, 07:49 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
The OEM setup had two wires to the plug, obviously ground and +12V from the relay. When pressing the horn button, does your meter see voltage on either wire to the horn?
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #3 of 3 Old 02-21-2018, 07:12 PM
gtg413i
gtg413i's Avatar
2003 WJ
IIRC, one of the wires goes to a direct ground to the body. In some versions, the bolt screwing the horn to the body was the ground. The other wire is + which is fed from a relay under the dash that closes the positive circuit when the horn is pressed. Pressing the horn connects a thin metal plate to push a button to make a ground in the steering wheel column. You can pop off the horn cap to see it. Sometimes that thin piece gets corroded and sometimes the button it pushes has a spring that rusts out.
Brian's Black Betty Build:
gtg413i is offline
