94 YJ idle too high - JeepForum.com
post #1 of 12 Old 09-16-2019, 07:04 PM Thread Starter
Stormy663
Stormy663's Avatar
94 YJ idle too high
Is there any way to adjust the idle besides replacing the idle sensor? It idles between 1700 and 2000 rpm...way too high.
Stormy663 is offline
post #2 of 12 Old 09-16-2019, 08:00 PM
bruinjeeper
bruinjeeper's Avatar
sure there is no vacuum leak?
~YJOTM MAY '16, JULY '19~
bruinjeeper is offline
post #3 of 12 Old 09-16-2019, 08:27 PM Thread Starter
Stormy663
Stormy663's Avatar
Not as far as I can tell
post #4 of 12 Old 09-16-2019, 08:37 PM
bruinjeeper
have you done any testing? If so, how?
post #5 of 12 Old 09-17-2019, 06:00 AM
Siva283
Siva283's Avatar
I am voting vacuum leak and a pretty large one.
Ask me how I know...
Siva283 is offline
post #6 of 12 Old 09-19-2019, 07:51 PM Thread Starter
Stormy663
Stormy663's Avatar
I've checked all of the vacuum lines and have replaced any that looked cracked. I'm replacing the MAP sensor in hopes that will fix it.
post #7 of 12 Old 09-19-2019, 07:55 PM
bruinjeeper
spray carb cleaner along all your vacuum lines while its running to see if the idle changes...whenever and if it does - that area is where your leak is. do not over look the rubber elbows and connectors
post #8 of 12 Old 09-19-2019, 07:56 PM
bruinjeeper
wait... does it idle that high ALL the time, or just on start up?
post #9 of 12 Old 09-20-2019, 08:43 AM Thread Starter
Stormy663
Stormy663's Avatar
All the time. Higher at start up though.
post #10 of 12 Old 09-23-2019, 06:43 AM
Siva283
Siva283's Avatar
this tells me your IAC is moving and responding so you most likely have a vacuum leak. WIth your engine off if you hold down the brake pedal does it hiss? It should while the pedal is moving but once it stops the his should too. If it keeps hissing bad brake booster. Also as ruinjeeper said carb cleaner is your friend. Use it to find your vacuum leak
Siva283 is offline
post #11 of 12 Old 09-28-2019, 12:59 PM Thread Starter
Stormy663
Stormy663's Avatar
I have now checked all of the vacuum lines and replaced ones that were suspect. I have also replaced the MAP sensor. No change.
When I take the vacuum line off the MAP sensor, the idle goes down to 1000 but the idle is a bit rough. It is the only vacuum line that does this. All others have little to no effect.
Thoughts?
post #12 of 12 Old 10-03-2019, 05:55 PM Thread Starter
Stormy663
Stormy663's Avatar
The leak is at the rear intake manifold connection. Thanks for all if your input
