94 yj 4.0 Transmission skid plate - JeepForum.com
 1Likes
post #1 of 16 Old 03-10-2020, 06:47 PM Thread Starter
ashtodust2000
ashtodust2000's Avatar
I need to replace my transmission skid plate, What do you all recommend. Looking to spend around $250.
Bruiser 94 Jeep Wrangler YJ
ashtodust2000 is offline
post #2 of 16 Old 03-10-2020, 08:56 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
I'm guessing you mean the transfer case skid.
Barnes 4wd offers a flat, 2" drop or 3" drop (stock drop is 3") for ~$200 made from 1/4" A50 steel. You'll need to figure out how to attach whatever tranny you're running.
UCF skids are nice but most of them are more expensive since some are easily adapted. They also offer a DIY skid for ~$250.
I have made a few custom skids from mild steel plate. They ran ~$90 in steel & fairly easy to make and bend. I've also made a few custom 6061 T6 and 7075 T6 aluminum skids - they start to get pricy since you are buying aircraft quality aluminum.
We broke (sent pieces flying ~25') a 40T press bending 1/4" 7075 T6, so be careful.
ThomasYJ likes this.
Joe Dillard is offline
post #3 of 16 Old 03-11-2020, 11:47 AM
bpounds
bpounds's Avatar
Looking at your profile, I think maybe you are looking for a stock replacement. Maybe rusted out due to WI winters? A junkyard replacement should be easy to find for a lot less than $250. Or, if you're wanting something custom, Joe is the man with the plan for that.
Bill
Jeepers drive high!
1988 Wrangler,4.2L I-6, Howell EFI JP-1,CRT HEI Ign,AX15 ext slave conversion, Zone 2" lift + 1" BL + 1/2" booms, BFG 31 x 10.5, Bestop.
bpounds is offline
post #4 of 16 Old 03-11-2020, 02:44 PM
KfoySTL
I have a stock one with rust on two of the attachment points that would need some welding to repair it if you want a project. Headed to Chicago from St. Louis this weekend if you want it. Its free, obviously.
They make repair kits. I was just planning to cut and weld on some mild steel but fell into a used one in better shape when I bought some axles.
KfoySTL is offline
post #5 of 16 Old 03-11-2020, 03:38 PM Thread Starter
ashtodust2000
Thanks for the offer, unfortunately i have to work this weekend.
post #6 of 16 Old 03-11-2020, 03:48 PM Thread Starter
ashtodust2000
I don't need stock, mine rusted out bad. I checked the junk yards, but they are all bad, or the wrong years.
post #7 of 16 Old 03-11-2020, 03:56 PM Thread Starter
ashtodust2000
Yes
Thanks, just what I was looking for.
Now you have me thinking about making my own! I need to buy a welder for my frame rail replacements anyways.
Dang, good thing it didn't hit anyone.
post #8 of 16 Old 03-11-2020, 07:38 PM
Joe Dillard
Yep, there was a BIG bang from when the bed support grenaded from stress and went flying across the shop area. Those parts were probably 20-30# of 8" I beam ~30" long. Luckily we were standing aside when it failed.
This is what a typical 1" drop skid would look similar to that we'd make.
post #9 of 16 Old 03-12-2020, 09:53 AM
NotmyJK
My frame and bolt holes in the skid were rusted so I ended up using TJ frame repair sections and my old TJ skid. Worked out nicely.
2000 TJ sport
2008 Dodge dually
1972 Kaiser Jeep deuce and a half
2008 JK unlimited (wifes)
2001 Boxster (wifes)
1995 Ford F350 dually flatbed (wifes)
NotmyJK is offline
post #10 of 16 Old 03-12-2020, 03:38 PM Thread Starter
ashtodust2000
If you were nearby I would have you make one for me. Would you happen to have plans for a stock drop steel pan?
post #11 of 16 Old 03-12-2020, 03:39 PM Thread Starter
ashtodust2000
Nice job!
post #12 of 16 Old 03-12-2020, 07:19 PM
Joe Dillard
Nope - the request for a stockish skid simply isn't something most folks would want me to make given they can buy stock skids fairly cheap or get them free.
Most of the folks I have built them for want superior protection/strength, more ground clearance, along with something totally custom.
post #13 of 16 Old 03-16-2020, 03:19 PM Thread Starter
ashtodust2000
Sorry I meant stock 3" drop. But I need to do a 4" drop so I can eliminate the spacers.
I am thinking of a tubular style, Any comments on using a single tubular crossover with 4" drop?
post #14 of 16 Old 03-16-2020, 05:21 PM
Joe Dillard
You can make one similar to the one on the left here & place it on the frame wherever it suits you. I've made a few like this. This one happens to be a Genright.
As you can see, it's adjustable in length, orientation etc.
post #15 of 16 Old 03-18-2020, 03:13 PM Thread Starter
ashtodust2000
Ok i picked this up https://www.summitracing.com/parts/clp-cp9424 I couldn't beat the price.
