93YJ Looking for some input - JeepForum.com
post #1 of 5 Old 04-05-2020, 04:41 PM Thread Starter
CBDaddy
CBDaddy's Avatar
I’ve got a 93YJ in the rear Grenaded. Put a new ring and pinion with 3. 55’s No I’m looking to re-gear the front to match everything comes back That ring and pinion kit won’t fit 93. Any suggestions?
CBDaddy is offline
post #2 of 5 Old 04-06-2020, 05:20 AM
bruinjeeper
bruinjeeper's Avatar
Did you gear higher or lower?
What original gearing ratio did your axles have?
Stop whining about the 'ride' - If your YJ ain't wrangling your soul free, then might I suggest you buy a stationwagon... at least you can fit all your bull**** in the back.
~YJOTM MAY '16~
~YJOTM JULY '19~
bruinjeeper is online now
post #3 of 5 Old 04-06-2020, 08:56 AM Thread Starter
CBDaddy
CBDaddy's Avatar
3.07 Were originally in it, they’re known to be weak to win the pinion bearing went I decided to replace with 354s, seemed like a good ratio for me. Still wanted highway drivability and a little better performance off-road. I’m running 33‘s And I’m now running about 1900 RPMs at 60 mph. Now I just need to find a set of gears for the front to match it up.
CBDaddy is offline
post #4 of 5 Old 04-06-2020, 10:00 AM
bruinjeeper
And the front is the stock Dana 30?
Where does it say the gears wont work. You originally came under the carrier break. Unsure why it would say that.
Maybe I'm wrong and someone will correct me.
~YJOTM MAY '16~
~YJOTM JULY '19~
post #5 of 5 Old 04-06-2020, 12:53 PM
TSEJEEPERS
TSEJEEPERS's Avatar
https://completeoffroad.com/i-158387...DWRANGLER%20YJ
Did you get the low pinion set?
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is online now
